Activate 方法 (ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 702| 评论: 0|原作者: admin|来自: AutoCAD
使指定的图形处于活动状态。
object.Activate
类别: 文档
此方法应用到的对象。
返回值 (RetVal)
无返回值。
Sub Example_ActivateMethod()
    ' This example creates two new drawings and activates each drawing in turn.
    Dim NewDrawing1 As AcadDocument
    Dim Newdrawing2 As AcadDocument
    Set NewDrawing1 = ThisDrawing.Application.Documents.Add("")
    Set Newdrawing2 = ThisDrawing.Application.Documents.Add("")
    Dim drawing As AcadDocument
    For Each drawing In ThisDrawing.Application.Documents
        drawing.Activate
        MsgBox "Drawing " & drawing.name & " is active."
    Next drawing
Not available
GMT+8, 2026-10-27 19:59
