关于创建浮出控件工具栏 (VBA/ActiveX)
2024-5-18 17:51| 发布者: admin| 查看: 671| 评论: 0|原作者: admin|来自: AutoCAD
若要将浮出控件工具栏按钮添加到工具栏,请使用该方法。此方法创建一个新对象并将其添加到指定的工具栏中。AddToolbarButtonToolbarItem
该方法采用五个参数作为输入:Index、Name、HelpString、Macro 和 FlyoutButton。通过将 FlyoutButton 参数设置为 TRUE,新按钮将创建为浮出控件按钮。此方法的返回值将是新的浮出控件工具栏。然后,可以像普通工具栏一样填充浮出控件工具栏。AddToolbarButton
创建浮出控件工具栏按钮
本示例创建两个工具栏。第一个工具栏包含浮出控件按钮。第二个工具栏附加到第一个工具栏上的浮出控件按钮。
Sub Ch6_AddFlyoutButton()
 Dim currMenuGroup As AcadMenuGroup
 Set currMenuGroup = ThisDrawing.Application. _
 MenuGroups.Item(0)
 ' Create the first toolbar
 Dim FirstToolbar As AcadToolbar
 Set FirstToolbar = currMenuGroup.Toolbars. _
 Add("FirstToolbar")
 ' Add a flyout button to the first menu on the menu bar
 Dim FlyoutButton As AcadToolbarItem
 Set FlyoutButton = FirstToolbar.AddToolbarButton _
 ("", "Flyout", "Demonstrates a flyout button", _
 "OPEN", True)
 ' Create the second toolbar. This will be attached to
 ' the first toolbar through the flyout button.
 Dim SecondToolbar As AcadToolbar
 Set SecondToolbar = currMenuGroup.Toolbars. _
 Add("SecondToolbar")
 ' Add a button to the next toolbar
 Dim newButton As AcadToolbarItem
 Dim openMacro As String
 ' Assign the macro the VB equivalent of "ESC ESC _open "
 openMacro = Chr(3) + Chr(3) + "_open "
 Set newButton = SecondToolbar.AddToolbarButton _
 ("", "NewButton", "Open a file.", openMacro)
 ' Attach the second toolbar to the flyout
 ' button on the first toolbar
 FlyoutButton.AttachToolbarToFlyout currMenuGroup.Name, _
 SecondToolbar.Name
 ' Display the first toolbar, hide the second toolbar
 FirstToolbar.Visible = True
 SecondToolbar.Visible = False
GMT+8, 2026-10-28 01:29
