关于定义工具栏按钮图像 (VBA/ActiveX)
若要定义要在工具栏按钮上使用的图像,请使用 and 方法。SetBitmapsGetBitmaps 该方法采用两个参数:SmallIconName 和 LargeIconName。SetBitmaps
查询现有工具栏以查找按钮的图标名称Sub Ch6_GetButtonImages() Dim Button As AcadToolbarItem Dim Toolbar0 As AcadToolbar Dim MenuGroup0 As AcadMenuGroup Dim SmallButtonName As String Dim LargeButtonName As String Dim msg As String Dim ButtonType As String ' Get the first toolbar in the first menu group Set MenuGroup0 = ThisDrawing.Application. _ MenuGroups.Item(0) Set Toolbar0 = MenuGroup0.Toolbars.Item(0) ' Clear the string variables SmallButtonName = "" LargeButtonName = "" ' Create a header for the message box and ' display the toolbar to be queried msg = "Toolbar: " + Toolbar0.Name + vbCrLf Toolbar0.Visible = True ' Iterate through the toolbar and collect data ' for each button in the toolbar. If the toolbar is ' a normal button or a flyout, collect the small ' and large button names for the button. For Each Button In Toolbar0 ButtonType = Choose(Button.Type + 1, "Button", _ "Separator", "Control", "Flyout") msg = msg & ButtonType & ": " If Button.Type = acToolbarButton Or _ Button.Type = acToolbarFlyout Then Button.GetBitmaps SmallButtonName, _ LargeButtonName msg = msg + SmallButtonName + ", " _ + LargeButtonName End If msg = msg + vbCrLf Next Button ' Display the results MsgBox msg End Sub |
GMT+8, 2026-10-30 22:49
