关于覆盖维度文本 (VBA/ActiveX)
可以使用 TextOverride 属性替换显示的维度值。使用此属性,可以完全替换维度的显示值,也可以将文本追加到该值。 修改尺寸文本本示例将一些文本追加到值中,以便同时显示字符串和维度值。 Sub Ch5_OverrideDimensionText()
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
' Define the dimension
point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
location(0) = 7.5: location(1) = 5#: location(2) = 0#
Set dimObj = ThisDrawing.ModelSpace. _
AddDimAligned(point1, point2, location)
' Change the text string for the dimension
dimObj.TextOverride = "The value is <>"
dimObj.Update
父主题: |
GMT+8, 2026-10-28 00:07
