关于创建复合区域 (VBA/ActiveX)
您可以通过减去、合并或查找区域或 3D 实体的交点来创建复合区域。 然后,可以拉伸或旋转复合区域以创建复杂的实体。若要创建复合区域,请使用以下方法。Boolean 当您从一个区域中减去另一个区域时,您可以从第一个区域调用该方法。这是要从中减去的区域。例如,若要计算楼层平面图需要多少地毯,请从楼层空间的外部边界调用该方法,并将未铺设地毯的区域(如柱子和柜台)用作布尔参数列表中的对象。BooleanBoolean 对区域执行的操作由 Boolean 方法的 BooleanType 参数确定。BooleanType 参数可以是下列参数之一:
创建复合区域Sub Ch4_CreateCompositeRegions()
' Create two circles, one representing a room,
' the other a pillar in the center of the room
Dim RoomObjects(0 To 1) As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 4
center(1) = 4
center(2) = 0
radius = 2#
Set RoomObjects(0) = ThisDrawing.ModelSpace.AddCircle(center, radius)
radius = 1#
Set RoomObjects(1) = ThisDrawing.ModelSpace.AddCircle(center, radius)
' Create a region from the two circles
Dim regions As Variant
regions = ThisDrawing.ModelSpace.AddRegion(RoomObjects)
' Copy the regions into the region variables for ease of use
Dim RoundRoomObj As AcadRegion
Dim PillarObj As AcadRegion
If regions(0).Area > regions(1).Area Then
' The first region is the room
Set RoundRoomObj = regions(0)
Set PillarObj = regions(1)
Else
' The first region is the pillar
Set PillarObj = regions(0)
Set RoundRoomObj = regions(1)
End If
' Subtract the pillar space from the floor space to
' get a region that represents the total carpet area.
RoundRoomObj.Boolean acSubtraction, PillarObj
' Use the Area property to determine the total carpet area
MsgBox "The carpet area is: " & RoundRoomObj.Area
查找具有属性的结果区域的区域。Area 父主题: |
GMT+8, 2026-10-28 03:22
