关于查询光线 (VBA/ActiveX)
2024-5-18 17:50| 发布者: admin| 查看: 845| 评论: 0|原作者: admin|来自: AutoCAD
创建后,您可以查询射线以确定用于创建对象的点。
该属性可用于获取光线的第一个点。虽然用于创建光线的第二个点不与对象一起存储,但可以使用该属性来获取光线的方向向量。BasePointDirectionVector
添加、查询和编辑 Ray 对象
下面的示例代码使用两点 (5, 0, 0) 和 (1, 1, 0) 创建一个对象。然后,它查询当前基点和方向向量,并在消息框中显示结果。然后更改方向向量,查询并显示基点和新方向向量。Ray
Sub Ch3_EditRay()
  Dim rayObj As AcadRay
  Dim basePoint(0 To 2) As Double
  Dim secondPoint(0 To 2) As Double
  ' Define the ray
  basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
  secondPoint(0) = 4#: secondPoint(1) = 4#: secondPoint(2) = 0#
  ' Creates a Ray object in model space
  Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, secondPoint)
  ' Find the current status of the Ray
  MsgBox "The base point of the ray is: " & _
  rayObj.basePoint(0) & ", " & _
  rayObj.basePoint(1) & ", " & _
  rayObj.basePoint(2) & vbCrLf & _
  "The directional vector for the ray is: " & _
  rayObj.DirectionVector(0) & ", " & _
  rayObj.DirectionVector(1) & ", " & _
  rayObj.DirectionVector(2), , "Edit Ray"
  ' Change the directional vector for the ray
  Dim newVector(0 To 2) As Double
  newVector(0) = -1
  newVector(1) = 1
  newVector(2) = 0
  rayObj.DirectionVector = newVector
  ThisDrawing.Regen False
GMT+8, 2026-11-15 12:49
