AutoCAD 2018 API 历史记录参考 (ActiveX)
对 AutoCAD 2018 和基于 AutoCAD 2018 的产品中的 ActiveX API 所做的添加和更改。 枚举AcSaveAsType (Changed)
ac2018_dwg = 64 (New)
ac2018_dxf = 65 (New)
ac2018_Template = 66 (New)
acNative = 64 (Changed)
类AcadAcCmColor
Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.AcCmColor.22
AcadApplication
Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.Application.22
AcadLayerStateManager
Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.AcadLayerStateManager.22
AcadSecurityParams
Version number of the class has been incremented from 21 to 22; use the ProgID AutoCAD.SecurityParams.22
IAcadDatabase (Changed)
FileDependencies - Property (Obsolete)
IAcadFileDependencies (Obsolete)
Application - Property
Count - Property
CreateEntry - Method
IndexOf - Method
Item - Method
RemoveEntry - Method
UpdateEntry - Method
IAcadFileDependency (Obsolete)
AffectsGraphics - Property
Feature - Property
FileName - Property
FileSize - Property
FingerprintGuid - Property
FoundPath - Property
FullFileName - Property
Index - Property
IsModified - Property
ReferenceCount - Property
TimeStamp - Property
VersionGuid - Property
相关概念 |
GMT+8, 2026-10-26 19:06
