AutoCAD 2016 API 历史记录参考 (ActiveX)
2024-5-18 17:50| 发布者: admin| 查看: 768| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2016 和基于 AutoCAD 2016 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcSectionState2 (New)
        acSectionState2Plane = 1
        acSectionState2Slice = 2
        acSectionState2Boundary = 4
        acSectionState2Volume = 8
AcadSecurityParamsConstants (Obsolete)
        ACADSECURITYPARAMS_ALGID_RC4 = 26625
AcadSecurityParamsType (Changed)
        ACADSECURITYPARAMS_ENCRYPT_DATA = 1 (Obsolete)
        ACADSECURITYPARAMS_ENCRYPT_PROPS = 2 (Obsolete)
类
IAcadDocument (Changed)
        SaveAs - Method (Support for adding password protection has been removed)
IAcadPointCloudEx (Changed)
        Segmentation - Property (New)
IAcadSection (Changed)
        SectionPlaneOffset - Property (New)
        SliceDepth - Property (New)
        State2 - Property (New)
IAcadSecurityParams (Changed)
        Action - Property (Constants ACADSECURITYPARAMS_ENCRYPT_DATA and ACADSECURITYPARAMS_ENCRYPT_PROPS are no longer supported)
        Algorithm - Property (Obsolete)
        KeyLength - Property (Obsolete)
        Password - Property (Obsolete)
        ProviderName - Property (Obsolete)
        ProviderType - Property (Obsolete)
IAcadShadowDisplay - Interface is only supported by the MentalRay renderer
GMT+8, 2026-10-26 13:45
