AutoCAD 2013 API 历史记录参考 (ActiveX)
对 AutoCAD 2013 和基于 AutoCAD 2013 的产品中的 ActiveX API 所做的添加和更改。 枚举AcSaveAsType (Changed)
ac2013_dwg = 60 (New)
ac2013_dxf = 61 (New)
ac2013_Template = 62 (New)
acNative = 60 (Changed)
AcPointCloudColorType (Changed)
acTrueColor = 0 (New)
acByColor = 1 (New)
AcPointCloudIntensityStyle (New)
acIntensityGrayscale = 0
acIntensityRainbow = 1
acIntensityRed = 2
acIntensityGreen = 3
acIntensityBlue = 4
acIntensityEditableFlag = 5
类IAcadEntity (Changed)
EntityTransparency - Property (Moved from IAcadEntity2)
IAcad3DSolid (Changed)
CheckInterference - Method (Added solid interfere parameter)
IAcadSpline (Changed)
KnotParameterization - Property (Moved from IAcadSpline2)
SplineFrame - Property (Moved from IAcadSpline2)
SplineMethod - Property (Moved from IAcadSpline2)
Degree2 - Property (Moved from IAcadSpline2)
Closed2 - Property (Moved from IAcadSpline2)
IAcadHatch (Changed)
BackgroundColor - Property (Moved from IAcadHatch2)
IAcadRasterImage (Changed)
transparency - Property (Renamed, previously Transparency)
IAcadDynamicBlockReferenceProperty (Changed)
show - Property (Renamed, previously Show)
IAcadSurface (Changed)
WireframeType - Property (Moved from IAcadSurface2)
MaintainAssociativity - Property (Moved from IAcadSurface2)
ShowAssociativity - Property (Moved from IAcadSurface2)
EdgeExtensionDistances - Property (Moved from IAcadSurface2)
SurfTrimAssociativity - Property (Moved from IAcadSurface3)
IAcadLoftedSurface (Changed)
StartSmoothMagnitude - Property (Moved from IAcadLoftedSurface2)
EndSmoothMagnitude - Property (Moved from IAcadLoftedSurface2)
StartSmoothContinuity - Property (Moved from IAcadLoftedSurface2)
EndSmoothContinuity - Property (Moved from IAcadLoftedSurface2)
Periodic - Property (Moved from IAcadLoftedSurface2)
IAcadPointCloud (Changed)
ShowIntensity - Property (New)
IntensityColorScheme - Property (New)
Width - Property (New)
Length - Property (New)
Height - Property (New)
Name - Property (New)
Path - Property (New)
ShowClipped - Property (New)
IAcadPreferencesFiles (Changed)
ActiveInvProject - Property (New)
以下类已删除/与其父类合并: IAcadEntity2 - Removed (Moved to IAcadEntity) IAcadRasterImage2 - Removed (Moved to IAcadRasterImage) IAcad3DFace2 - Removed (Moved to IAcad3DFace) IAcad3DPolyline2 - Removed (Moved to IAcad3DPolyline) IAcadRegion2 - Removed (Moved to IAcadRegion) IAcad3DSolid2 - Removed (Moved to IAcad3DSolid) IAcadArc2 - Removed (Moved to IAcadArc) IAcadAttribute2 - Removed (Moved to IAcadAttribute) IAcadBlockReference2 - Removed (Moved to IAcadBlockReference) IAcadCircle2 - Removed (Moved to IAcadCircle) IAcadEllipse2 - Removed (Moved to IAcadEllipse) IAcadHatch2 - Removed (Moved to IAcadHatch) IAcadLeader2 - Removed (Moved to IAcadLeader) IAcadMLeader2 - Removed (Moved to IAcadMLeader) IAcadLWPolyline2 - Removed (Moved to IAcadLWPolyline) IAcadLine2 - Removed (Moved to IAcadLine) IAcadMText2 - Removed (Moved to IAcadMText) IAcadPoint2 - Removed (Moved to IAcadPoint) IAcadPolyline2 - Removed (Moved to IAcadPolyline) IAcadPolygonMesh2 - Removed (Moved to IAcadPolygonMesh) IAcadRay2 - Removed (Moved to IAcadRay) IAcadShape2 - Removed (Moved to IAcadShape) IAcadSolid2 - Removed (Moved to IAcadSolid) IAcadSpline2 - Removed (Moved to IAcadSpline) IAcadText2 - Removed (Moved to IAcadText) IAcadTolerance2 - Removed (Moved to IAcadTolerance) IAcadTrace2 - Removed (Moved to IAcadTrace) IAcadXline2 - Removed (Moved to IAcadXline) IAcadPViewport2 - Removed (Moved to IAcadPViewport) IAcadPolyfaceMesh2 - Removed (Moved to IAcadPolyfaceMesh) IAcadMLine2 - Removed (Moved to IAcadMLine) IAcadExternalReference2 - Removed (Moved to IAcadExternalReference) IAcadTable2 - Removed (Moved to IAcadTable) IAcadOle2 - Removed (Moved to IAcadOle) IAcadHelix2 - Removed (Moved to IAcadHelix) IAcadSurface2 - Removed (Moved to IAcadSurface) IAcadSurface3 - Removed (Moved to IAcadSurface) IAcadPlaneSurface2 - Removed (Moved to IAcadPlaneSurface) IAcadPlaneSurface3 - Removed (Moved to IAcadPlaneSurface) IAcadExtrudedSurface2 - Removed (Moved to IAcadExtrudedSurface) IAcadExtrudedSurface3 - Removed (Moved to IAcadExtrudedSurface) IAcadRevolvedSurface2 - Removed (Moved to IAcadRevolvedSurface) IAcadRevolvedSurface3 - Removed (Moved to IAcadRevolvedSurface) IAcadSweptSurface2 - Removed (Moved to IAcadSweptSurface) IAcadSweptSurface3 - Removed (Moved to IAcadSweptSurface) IAcadLoftedSurface2 - Removed (Moved to IAcadLoftedSurface) IAcadLoftedSurface3 - Removed (Moved to IAcadLoftedSurface) IAcadWipeout2 - Removed (Moved to IAcadWipeout) IAcadSubDMesh2 - Removed (Moved to IAcadSubDMesh) IAcadNurbSurface2 - Removed (Moved to IAcadNurbSurface) IAcadDimAligned2 - Removed (Moved to IAcadDimAligned) IAcadDimAngular2 - Removed (Moved to IAcadDimAngular) IAcadDimDiametric2 - Removed (Moved to IAcadDimDiametric) IAcadDimOrdinate2 - Removed (Moved to IAcadDimOrdinate) IAcadDimRadial2 - Removed (Moved to IAcadDimRadial) IAcadDimRotated2 - Removed (Moved to IAcadDimRotated) IAcadDim3PointAngular2 - Removed (Moved to IAcadDim3PointAngular) IAcadDimArcLength2 - Removed (Moved to IAcadDimArcLength) IAcadDimRadialLarge2 - Removed (Moved to IAcadDimRadialLarge) 相关概念 |
GMT+8, 2026-10-28 01:10
