查看代码 (AutoLISP)
现在看一下该函数的代码:gp:calculate-Draw-TileRow (defun gp:calculate-Draw-TileRow (startPoint TileRadius
TileSpace pathWidth pathAngle
offsetFromCenter ObjectCreationStyle /
HalfWidth TileDiameter
ObjectCreationFunction angp90 angm90
firstCenterPt TileCenterPt TileList)
(setq HalfWidth (- (/ pathWidth 2.00) TileRadius)
Tilespacing (+ (* TileRadius 2.0) TileSpace)
TileDiameter (* TileRadius 2.0)
angp90 (+ PathAngle (Degrees->Radians 90))
angm90 (- PathAngle (Degrees->Radians 90))
firstCenterPt (polar startPoint angp90 offsetFromCenter)
tileCenterPt firstCenterPt
ObjectCreationStyle(strcase ObjectCreationStyle)
(cond
((equal ObjectCreationStyle "ACTIVEX")
gp:Create_activeX_Circle
((equal ObjectCreationStyle "ENTMAKE")
gp:Create_entmake_Circle
((equal ObjectCreationStyle "COMMAND")
gp:Create_command_Circle
(T
(alert (strcat "ObjectCreationStyle in function gp:calculate-Draw-TileRow"
"\nis invalid. Contact developer for assistance."
"\n ObjectCreationStyle set to ACTIVEX"
(setq ObjectCreationStyle "ACTIVEX")
;; Draw the circles to the left of the center.
(while (< (distance startPoint tileCenterPt) HalfWidth)
;; Add each tile to the list to return.
(setq tileList
(cons
(ObjectCreationFunction tileCenterPt TileRadius)
tileList
;; Calculate the center point for the next tile.
(setq tileCenterPt
(polar tileCenterPt angp90 TileSpacing)
);_ end of while
;; Draw the circles to the right of the center.
(setq tileCenterPt
(polar firstCenterPt angm90 TileSpacing)
(setq tileList
(cons
tileList
(setq tileCenterPt
(polar tileCenterPt angm90 TileSpacing)
);_ end of while
;; Return the list of tiles.
tileList
) ;_ end of defun
AutoLISP 代码逻辑遵循伪代码,并添加了以下内容: (setq ObjectCreationFunction
(cond
(T
(alert
(strcat
"\nis invalid. Contact the developer for assistance."
) ;_ end of strcat
) ;_ end of alert
) ;_ end of cond
) ;_ end of setq
还记得允许用户使用 ActiveX、函数或函数绘制图块(圆圈)的规范吗?变量被分配三个函数之一,具体取决于参数(从和通过传递)。下面是将在 gpdraw.lsp 中定义的三个函数:entmakecommandObjectCreationFunctionObjectCreationStyle C:GPath gp:Calculate-and-Draw-Tiles (defun gp:Create_activeX_Circle (center radius)
(vla-addCircle *ModelSpace*
(vlax-3d-point center) ; convert to ActiveX-compatible 3D point
radius
) ;_ end of defun
(defun gp:Create_entmake_Circle (center radius)
(entmake
(list (cons 0 "CIRCLE") (cons 10 center) (cons 40 radius))
(vlax-ename->vla-object (entlast))
(defun gp:Create_command_Circle (center radius)
(command "._circle" center radius)
第一个函数使用 ActiveX 函数绘制一个圆,并返回一个 ActiveX 对象。 第二个函数使用 绘制一个圆。它返回转换为 ActiveX 对象的实体名称。entmake 第三个函数使用 绘制一个圆。它还返回转换为 ActiveX 对象的实体名称。command |
GMT+8, 2026-10-27 16:00
