ObjectARX 开发指南
向处理程序添加代码
2023-1-1 02:42| 发布者: admin| 查看: 1342| 评论: 0|来自: AutoCAD
添加处理程序后,即可添加代码来处理对话框。本节总结了每个处理程序对完整列表执行的操作。
向 MFC 对话框的处理程序添加代码
  1. 添加实用程序函数以转换、显示和验证值。使用 theandcontrols 来执行此操作:CAcUiNumericCAcUiAngleEdit
    // Utility functions
    void AsdkAcUiDialogSample::DisplayPoint()
        m_ctrlXPtEdit.SetWindowText(m_strXPt);
        m_ctrlXPtEdit.Convert();
        m_ctrlYPtEdit.SetWindowText(m_strYPt);
        m_ctrlYPtEdit.Convert();
        m_ctrlZPtEdit.SetWindowText(m_strZPt);
        m_ctrlZPtEdit.Convert();
    bool AsdkAcUiDialogSample::ValidatePoint()
        if (!m_ctrlXPtEdit.Validate())
            return false;
        if (!m_ctrlYPtEdit.Validate())
            return false;
        if (!m_ctrlZPtEdit.Validate())
            return false;
        return true;
    void AsdkAcUiDialogSample::DisplayAngle()
        m_ctrlAngleEdit.SetWindowText(m_strAngle);
        m_ctrlAngleEdit.Convert();
    bool AsdkAcUiDialogSample::ValidateAngle()
        if (!m_ctrlAngleEdit.Validate())
            return false;
        return true;
  2. 添加实用程序函数以循环访问两个符号表,并在两个列表框中显示名称:
    void AsdkAcUiDialogSample::DisplayBlocks()
        AcDbBlockTable *pBlockTable;
        acdbHostApplicationServices()->workingDatabase()
            ->getSymbolTable(pBlockTable, AcDb::kForRead);
        // Iterate through the block table and display
        // the names in the list box.
        const char *pName;
        AcDbBlockTableIterator *pBTItr;
        if (pBlockTable->newIterator(pBTItr) == Acad::eOk) {
            while (!pBTItr->done()) {
                AcDbBlockTableRecord *pRecord;
                if (pBTItr->getRecord(pRecord, AcDb::kForRead)
                    == Acad::eOk) {
                    pRecord->getName(pName);
                    m_ctrlBlockListBox.InsertString(-1, pName);
                    pRecord->close();
                pBTItr->step();
        pBlockTable->close();
    void AsdkAcUiDialogSample::DisplayRegApps()
        AcDbRegAppTable *pRegAppTable;
            ->getSymbolTable(pRegAppTable, AcDb::kForRead);
        // Iterate through the reg app table and display the
        // names in the list box.
        const char *pName;
        AcDbRegAppTableIterator *pItr;
        if (pRegAppTable->newIterator(pItr) == Acad::eOk) {
            while (!pItr->done()) {
                AcDbRegAppTableRecord *pRecord;
                if (pItr->getRecord(pRecord, AcDb::kForRead)
                    == Acad::eOk) {
                    m_ctrlRegAppComboBox.InsertString(-1, pName);
                    pRecord->close();
                pItr->step();
        pRegAppTable->close();
  3. Add the declarations for the functions and variables to the class definition in the header file
        void DisplayPoint();
        bool ValidatePoint();
        void DisplayAngle();
        bool ValidateAngle();
        void DisplayBlocks();
        void DisplayRegApps();
        CString m_strAngle;
        CString m_strXPt;
        CString m_strYPt;
        CString m_strZPt;
  4. Add the button handlers for picking a point and angle using the AutoCAD editor. The , , and functions are used to hide the dialog, allow the call to and , and finally, either cancel or redisplay the dialog based on how the user picked:BeginEditorCommand()CompleteEditorCommand()CancelEditorCommand()acedGetPointacedGetAngle
    // AsdkAcUiDialogSample message handlers
    void AsdkAcUiDialogSample::OnButtonPoint()
        // Hide the dialog and give control to the editor
        BeginEditorCommand();
        ads_point pt;
        // Get a point
        if (acedGetPoint(NULL, "\nPick a point: ", pt) == RTNORM) {
            // If the point is good, continue
            CompleteEditorCommand();
            m_strXPt.Format("%g", pt[X]);
            m_strYPt.Format("%g", pt[Y]);
            m_strZPt.Format("%g", pt[Z]);
            DisplayPoint();
        } else {
            // otherwise cancel the command (including the dialog)
            CancelEditorCommand();
    void AsdkAcUiDialogSample::OnButtonAngle()
        // Set up the default point for picking an angle
        // based on the m_strXPt, m_strYPt, and m_strZPt values
        ads_point pt;
        acdbDisToF(m_strXPt, -1, &pt[X]);
        acdbDisToF(m_strYPt, -1, &pt[Y]);
        acdbDisToF(m_strZPt, -1, &pt[Z]);
        double angle;
        // Get a point from the user
        if (acedGetAngle
            (pt, "\nPick an angle: ", &angle) == RTNORM) {
            // If we got an angle, go back to the dialog
            // Convert the acquired radian value to degrees since
            // the AcUi control can convert that to the other
            // formats.
            m_strAngle.Format("%g", angle*(180.0/PI));
            DisplayAngle();
        } else {
  5. Implement the edit box handlers. These functions convert the values to the current Units settings:
    void AsdkAcUiDialogSample::OnKillfocusEditAngle()
        // Get and update text the user typed in.
        m_ctrlAngleEdit.GetWindowText(m_strAngle);
    void AsdkAcUiDialogSample::OnKillfocusEditXpt()
        m_ctrlXPtEdit.GetWindowText(m_strXPt);
    void AsdkAcUiDialogSample::OnKillfocusEditYpt()
        m_ctrlYPtEdit.GetWindowText(m_strYPt);
    void AsdkAcUiDialogSample::OnKillfocusEditZpt()
        m_ctrlZPtEdit.GetWindowText(m_strZPt);
  6. Implement the combo box handler to allow the user to type in a string, and then register the user's string as an application name. This step, though of little practical value, demonstrates the use of a combo box:
    void AsdkAcUiDialogSample::OnKillfocusComboRegapps()
        CString strFromEdit;
        m_ctrlRegAppComboBox.GetWindowText(strFromEdit);
        if (m_ctrlRegAppComboBox.FindString(-1, strFromEdit) == CB_ERR)
            if (acdbRegApp(strFromEdit) == RTNORM)
                m_ctrlRegAppComboBox.AddString(strFromEdit);
  7. Handle data validation in the handler for this example. (Of course, it could be done elsewhere.) Also notice that the handler stores the data in the user profile (registry) using the function:OnOk()OnOk()SetDialogData()
    void AsdkAcUiDialogSample::OnOK()
        if (!ValidatePoint()) {
            AfxMessageBox("Sorry, Point out of desired range.");
            m_ctrlXPtEdit.SetFocus();
            return;
        if (!ValidateAngle()) {
            AfxMessageBox("Sorry, Angle out of desired range.”);
            m_ctrlAngleEdit.SetFocus();
            return;
        CAcUiDialog::OnOK();
        // Store the data into the registry
        SetDialogData("ANGLE", m_strAngle);
        SetDialogData("POINTX", m_strXPt);
        SetDialogData("POINTY", m_strYPt);
        SetDialogData("POINTZ", m_strZPt);
  8. Finally, the function takes care of initialization, including the resizing and data persistency requirements:OnInitDialog()
    BOOL AsdkAcUiDialogSample::OnInitDialog()
        // Set the dialog name for registry lookup and storage
        SetDialogName("AsdkAcUiSample:AsdkAcUiDialog");
        CAcUiDialog::OnInitDialog();
        DLGCTLINFO	dlgSizeInfo[]= {
            { IDC_STATIC_GROUP1, ELASTICX, 20 },
            { IDC_STATIC_GROUP1, ELASTICY, 100 },
            { IDC_EDIT_XPT, ELASTICX, 20 },
            { IDC_EDIT_YPT, ELASTICX, 20 },
            { IDC_EDIT_ZPT, ELASTICX, 20 },
            { IDC_EDIT_ANGLE, ELASTICX, 20 },
            { IDC_STATIC_GROUP2, MOVEX, 20 },
            { IDC_STATIC_GROUP2, ELASTICY, 100 },
            { IDC_STATIC_GROUP2, ELASTICX, 80 },
            { IDC_LIST_BLOCKS, MOVEX, 20 },
            { IDC_LIST_BLOCKS, ELASTICY, 100 },
            { IDC_STATIC_TEXT2, MOVEX, 20 },
            { IDC_STATIC_TEXT2, MOVEY, 100 },
            { IDC_LIST_BLOCKS, ELASTICX, 80 },
            { IDC_STATIC_TEXT2, ELASTICX, 80 },
            { IDC_STATIC_GROUP3, MOVEY, 100 },
            { IDC_STATIC_GROUP3, ELASTICX, 20 },
            { IDC_COMBO_REGAPPS, MOVEY, 100 },
            { IDC_COMBO_REGAPPS, ELASTICX, 20 },
            { IDC_STATIC_TEXT3, MOVEY, 100 },
            { IDC_STATIC_TEXT3, ELASTICX, 20 },
            { IDOK,MOVEX, 100 },
            { IDCANCEL, MOVEX, 100 },
        const DWORD numberofentries =
            sizeof dlgSizeInfo / sizeof DLGCTLINFO;
        SetControlProperty(dlgSizeInfo, numberofentries);
        // Must be within a 100-unit cube centered about 0,0,0.
        m_ctrlXPtEdit.SetRange(-50.0, 50.0);
        m_ctrlYPtEdit.SetRange(-50.0, 50.0);
        m_ctrlZPtEdit.SetRange(-50.0, 50.0);
        // Must be between 0 and 90 degrees.
        m_ctrlAngleEdit.SetRange(0.0, 90.0 /*(PI/2.0)*/);
        // Assign a title for the dialog.
        SetWindowText("AcUiDialog Sample");
        // Load the default bitmaps.
        m_ctrlPickButton.AutoLoad();
        m_ctrlAngleButton.AutoLoad();
        // Get and display the preserved data from the registry.
        if (!GetDialogData("ANGLE", m_strAngle))
            m_strAngle = "0.0";
        if (!GetDialogData("POINTX", m_strXPt))
            m_strXPt = "0.0";
        if (!GetDialogData("POINTY", m_strYPt))
            m_strYPt = "0.0";
        if (!GetDialogData("POINTZ", m_strZPt))
            m_strZPt = "0.0";
        DisplayPoint();
        DisplayAngle();
        DisplayBlocks();
        DisplayRegApps();
        // return TRUE unless you set the focus to a control
        return TRUE;
GMT+8, 2026-10-27 05:26
