ObjectARX 开发指南
扩展 AutoCAD 内置选项卡对话框
2023-1-1 02:55| 发布者: admin| 查看: 1388| 评论: 0|来自: AutoCAD
使用类向导或其他一些方法创建从中子类化的选项卡。在对话框的属性中,将对话框的样式更改为“子项”,将边框更改为“调整大小”。实现覆盖。替换对话框的所有源文件中出现的所有项。对于选项卡扩展,删除已分配的选项卡对象(请参阅下面的示例)。CDialogPostNcDestroy()CDialogCAdUiTabExtensionPostNcDestroy()
在处理程序中添加调用中,其中 是应用程序的基本文件名,是要添加到的可扩展选项卡式对话框的已发布名称。AcRx::kInitAppMsgacrxEntryPoint()acedRegisterExtendedTab("MYAPPNAME.ARX", "DIALOGNAME")MYAPPNAMEDIALOGNAME
实现一个处理程序并在那里添加选项卡。论点是点。使用 member 函数以获取正在初始化的对话框的名称,如果应用程序要添加到此对话框,请调用 的成员函数来添加选项卡。如果对话框可调整大小,并且您希望调整某些控件的大小,请在调用 to 后添加调整大小代码。AcRx::kInitDialogMsgacrxEntryPoint()(void*)appIdacrxEntryPoint()CAdUiTabExtensionManagerGetDialogName()CAdUiTabExtensionManagerAddTab()CAdUiTabExtensionManagerAddTab()
例如:
extern "C" AcRx::AppRetCode acrxEntryPoint(
    AcRx::AppMsgCode msg, void* appId)
    switch (msg) {
    case AcRx::kInitAppMsg:
        acrxDynamicLinker->unlockApplication(appId);
        acrxDynamicLinker->registerAppMDIAware(appId);
        initApp();
        break;
    case AcRx::kUnloadAppMsg:
        unloadApp();
        break;
    case AcRx::kInitDialogMsg:
    // A dialog is initializing that we are interested in adding
    // tabs to.
        addMyTabs((CAdUiTabExtensionManager*)pkt);
        break;
    default:
        break;
    return AcRx::kRetOK;
void initApp()
    InitMFC();
    // Do other initialization tasks here.
    acedRegCmds->addCommand(
        "MYARXAPP",
        "MYARXAPP",
        "MYARXAPP",
        ACRX_CMD_MODAL,
        &MyArxAppCreate);
    // Here is where we register the fact that we want to add
    // a tab to the Options dialog.
    acedRegisterExtendedTab("MYARXAPP.ARX", "OptionsDialog");
// CMyTab1 is subclassed from CAcUiTabExtension.
static CMyTab1* pTab1;
void addMyTabs(CAdUiTabExtensionManager* pXtabManager)
    // Allocate an extended tab if it has not been done already
    // and add it through the CAdUiTabExtensionManager.
    pTab1 = new CMyTab1;
    pXtabManager->AddTab(_hdllInstance, IDD_TAB1,
        "My Tab1", pTab1);
    // If the main dialog is resizable, add your control
    // resizing directives here.
    pTab1->StretchControlXY(IDC_EDIT1, 100, 100);
然后,对于类实现:CMyTab1
void CMyTab1::PostNcDestroy()
// Override to delete added tab.
    delete pTab1;
    pTab1 = NULL;
    CAcUiTabExtension::PostNcDestroy();
GMT+8, 2026-10-26 01:56
