ObjectARX 开发指南
相关分类
创建字典
2023-1-1 03:30| 发布者: admin| 查看: 1633| 评论: 0|来自: AutoCAD
下面的示例创建一个新字典 (ASDK_DICT) 并将其添加到命名对象字典中。然后它创建自定义类(派生自)的两个新对象,并使用函数将它们添加到字典中。AsdkMyClassAcDbObjectsetAt()
注意:您需要在使用函数添加对象后关闭对象。setAt()
// This function creates two objects of class AsdkMyClass.
// It fills them in with the integers 1 and 2, and then adds
// them to the dictionary associated with the key ASDK_DICT. If this
// dictionary doesn't exist, it is created and added to the named
// object dictionary.
void
createDictionary()
    AcDbDictionary *pNamedobj;
    acdbHostApplicationServices()->workingDatabase()->
        getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
    // Check to see if the dictionary we want to create is
    // already present. If not, create it and add
    // it to the named object dictionary.
    AcDbDictionary *pDict;
    if (pNamedobj->getAt("ASDK_DICT", (AcDbObject*&) pDict,
        AcDb::kForWrite) == Acad::eKeyNotFound)
        pDict = new AcDbDictionary;
        AcDbObjectId DictId;
        pNamedobj->setAt("ASDK_DICT", pDict, DictId);
    pNamedobj->close();
    if (pDict) {
        // Create new objects to add to the new dictionary,
        // add them, then close them.
        AsdkMyClass *pObj1 = new AsdkMyClass(1);
        AsdkMyClass *pObj2 = new AsdkMyClass(2);
        AcDbObjectId rId1, rId2;
        pDict->setAt("OBJ1", pObj1, rId1);
        pDict->setAt("OBJ2", pObj2, rId2);
        pObj1->close();
        pObj2->close();
        pDict->close();
GMT+8, 2026-10-29 16:00
