恢复状态
2024-5-18 17:47| 发布者: admin| 查看: 549| 评论: 0|原作者: admin|来自: AutoCAD
恢复状态
如果指定了 ,则在调用 UNDO 命令时调用对象的函数。该函数是 上的虚函数。派生类可以实现此函数,以解释撤消文件管理器存储的特定于类的信息并读取它。该函数必须确保类执行修改。如果不是,它必须是 super-message,如以下示例所示。kFalseautoUndoapplyPartialUndo()applyPartialUndo()AcDbObjectapplyPartialUndo()
如果要实现部分撤消机制,请务必调用以下函数,以便默认情况下不进行录制。
assertWriteEnabled(kFalse, kFalse);
举个例子,下面是 AsdkPoly 的函数:applyPartialUndo()
Acad::ErrorStatus
AsdkPoly::applyPartialUndo(AcDbDwgFiler* filer,
                           AcRxClass* classObj)
    // The first thing to check is whether the class matches
    // ours. If it doesn't, we call the base class's
    // applyPartialUndo(); hopefully, one of them will
    // take care of it.
    if (classObj != AsdkPoly::desc())
        return AcDbCurve::applyPartialUndo(filer, classObj);
    // Read the op-code and call the appropriate "set"
    // method to undo what was done. The "set" does the
    // filing again for redo.
    Adesk::Int16 shortCode;
    filer->readItem(&shortCode);
    PolyOpCodeForPartialUndo code;
    code = (PolyOpCodeForPartialUndo)shortCode;
    Adesk::UInt32 value32;
    switch (code) {
    case kSetNumSides:
        filer->readItem(&value32);
        AOK(setNumSides(value32));
        break;
    default:
        assert(Adesk::kFalse);
        break;
    return Acad::eOk;
  1. 部分撤消
GMT+8, 2026-10-27 16:51
