2024-5-18 16:59| 发布者: admin| 查看: 602| 评论: 0|原作者: admin|来自: AutoCAD
组件所需的最低注册量如下:HKEY_CLASSES_ROOT
[HKEY_CLASSES_ROOT\CLSID\{<App CLSID xxxxxxxx-xxxx-xxxx-xxxx- xxxxxxxxxxxx>}\InProcServer32] @="<full path to application>\mycomponent.arx"
评论
GMT+8, 2026-11-15 12:49
