AcAxOleLinkManager
AcAxOleLinkManager用于管理从驻留数据库对象到其 COM 对象的链接。这是通过将瞬态电抗器连接到 .瞬态反应器有一个变量,其中包含指向 的 的指针 的 对象。该瞬态电抗器也用于在修改时调用。AcDbObjectIUnknownIAcadBaseObject::OnModified()AcDbObject AutoCAD 在每个任务中维护一个实例。若要获取指向 OLE 链接管理器的指针,请使用该函数。在 oleaprot.h 文件中声明的类如下所述:AcAxOleLinkManagerAcAxGetOleLinkManager()AcAxOleLinkManager // AcAxOleLinkManager is used to maintain the link between ARX
// objects and their respective COM wrapper.
class AcAxOleLinkManager
public:
// Given a pointer to a database-resident object, return
// the IUnknown of the COM wrapper. NULL is returned if
// no wrapper is found.
virtual IUnknown* GetIUnknown(AcDbObject* pObject) = 0;
// Set the link between a database-resident object and a
// COM wrapper. If the IUnknown is NULL, then the link
// is removed.
virtual Adesk::Boolean SetIUnknown(AcDbObject* pObject,
IUnknown* pUnknown) = 0;
// Given a pointer to a database object, return
virtual IUnknown* GetIUnknown(AcDbDatabase* pDatabase) = 0;
// Set the link between a database object and a COM wrapper.
// If the IUnknown is NULL, then the link is removed.
virtual Adesk::Boolean SetIUnknown(AcDbDatabase* pDatabase,
// Given a pointer to a database object, return the
// IDispatch of the document object. NULL is returned if
// the database does not belong to a particular document.
virtual IDispatch* GetDocIDispatch(AcDbDatabase* pDatabase)= 0;
// Set the link between a database object and the IDispatch
// of the document it belongs to. If the IDispatch is NULL, then
// the link is removed.
virtual Adesk::Boolean SetDocIDispatch(AcDbDatabase* pDatabase,
IDispatch* pDispatch) = 0;
GMT+8, 2026-10-27 05:23
