获取所选实体的子实体路径后,此过程最困难的部分就完成了。现在,您只需要调用函数并传入子实体路径。如果在没有任何参数的情况下调用函数,则默认设置是突出显示整个实体。highlight()highlight() 以下示例代码演示了用于选择实体、获取子实体路径以及突出显示与 GS 标记关联的不同类型的子实体所描述的步骤。此代码还演示了另一个有用的子实体函数: virtual AcDbEntity* AcDbEntity::subentPtr(const AcDbFullSubentPath& id) const; 此函数返回指向指定路径描述的子实体副本的指针,然后可以将其添加到数据库中(如示例中所示)。 注意:当您创建新的子类时,您应该为它们提供自己的实现,并通过覆盖相应的虚函数,并分别(请参阅从 AcDbEntity 派生)。但是,该函数是在级别实现的,通常不会被覆盖。但是,如果它被重写,则此函数的任何新实现都必须调用以执行突出显示。AcDbEntitygetSubentPathsAtGsMarker()getGsMarkersAtSubentPath(),subentPtr()subGetSubentPathsAtGsMarker()subGetGsMarkersAtSubentPath(),subSubentPtr()highlight()AcDbEntityAcDbEntity::highlight()
// This function calls getObjectAndGsMarker() to get the
// object ID of a solid and its gsmarker. It then calls
// highlightEdge(), highlightFaces(), and highlightAll() to
// highlight the selected edge, all faces surrounding that
// edge, and then the whole solid.
void
highlightTest()
AcDbObjectId objId;
int marker;
if (getObjectAndGsMarker(objId, marker) != Acad::eOk)
return;
highlightEdge(objId, marker);
highlightFaces(objId, marker);
highlightAll(objId);
// This function uses acedSSGet() to let the user select a
// single entity. It then passes this selection set to
// acedSSNameX() to get the gsmarker. Finally, the entity name
// in the selection set is used to obtain the object ID of
// the selected entity.
Acad::ErrorStatus
getObjectAndGsMarker(AcDbObjectId& objId, int& marker)
ads_name sset;
if (acedSSGet("_:S", NULL, NULL, NULL, sset) != RTNORM) {
acutPrintf("\nacedSSGet has failed");
return Acad::eInvalidAdsName;
// Get the entity from the selection set and its
// subentity ID. This code assumes that the user
// selected only one item, a solid.
struct resbuf *pRb;
if (acedSSNameX(&pRb, sset, 0) != RTNORM) {
acedSSFree(sset);
return Acad::eAmbiguousOutput;
acedSSFree(sset);
// Walk the list to the third item, which is the selected
// entity's entity name.
struct resbuf *pTemp;
int i;
for (i=1, pTemp = pRb;i<3;i++, pTemp = pTemp->rbnext)
ads_name ename;
ads_name_set(pTemp->resval.rlname, ename);
// Move on to the fourth list element, which is the gsmarker.
pTemp = pTemp->rbnext;
marker = pTemp->resval.rint;
acutRelRb(pRb);
acdbGetObjectId(objId, ename);
return Acad::eOk;
// This function accepts an object ID and a gsmarker.
// The object is opened, the gsmarker is used to get the
// AcDbFullSubentIdPath, which is then used to highlight
// and unhighlight the edge used to select the object.
// Next, the object's subentPtr() function is used to get
// a copy of the edge. This copy is then added to the
// database. Finally, the object is closed.
// Since the copy of the subentity was added to the database
// as a new AcDbLine entity, it remains visible in the drawing
// editor after the command exits and will be reported by the
// AutoCAD LIST command.
void
highlightEdge(const AcDbObjectId& objId, const int marker)
char dummy[133]; // space for acedGetString pauses below
AcDbEntity *pEnt;
acdbOpenAcDbEntity(pEnt, objId, AcDb::kForRead);
// Get the subentity ID for the edge that is picked
AcGePoint3d pickpnt;
AcGeMatrix3d xform;
int numIds;
AcDbFullSubentPath *subentIds;
pEnt->getSubentPathsAtGsMarker(AcDb::kEdgeSubentType,
marker, pickpnt, xform, numIds, subentIds);
// At this point the subentId's variable contains the
// address of an array of AcDbFullSubentPath objects.
// The array should be one element long, so the picked
// edge's AcDbFullSubentPath is in subentIds[0].
// For objects with no edges (such as a sphere), the
// code to highlight an edge is meaningless and must
// be skipped.
if (numIds > 0) {
// Highlight the edge.
pEnt->highlight(subentIds[0]);
// Pause to let user see the effect.
acedGetString(0, "\npress <RETURN> to continue...",
dummy);
// Unhighlight the picked edge.
pEnt->unhighlight(subentIds[0]);
// Get a copy of the edge, and add it to the database.
AcDbEntity *pEntCpy = pEnt->subentPtr(subentIds[0]);
AcDbObjectId objId;
addToModelSpace(objId, pEntCpy);
delete []subentIds;
pEnt->close();
// and unhighlight faces that share the edge used to
// select the object. The object is then closed.
void
highlightFaces(const AcDbObjectId& objId, const int marker)
char dummy[133];
AcDbEntity *pEnt;
// Get the subentIds for the faces.
AcGeMatrix3d xform;
int numIds;
pEnt->getSubentPathsAtGsMarker(AcDb::kFaceSubentType,
// Walk the subentIds list, highlighting each face subentity.
for (int i = 0;i < numIds; i++) {
pEnt->highlight(subentIds[i]); // Highlight face.
// Pause to let the user see the effect.
dummy);
pEnt->unhighlight(subentIds[i]);
delete []subentIds;
pEnt->close();
// This function accepts an object ID. The object is opened,
// and its highlight() and unhighlight() functions are
// used with no parameters, to highlight and
// unhighlight the edge used to select the object. The
// object is then closed.
void
highlightAll(const AcDbObjectId& objId)
char dummy[133];
AcDbEntity *pEnt;
// Highlight the whole solid.
pEnt->highlight();
dummy);
pEnt->unhighlight();
pEnt->close();
Acad::ErrorStatus
addToModelSpace(AcDbObjectId &objId, AcDbEntity* pEntity)
AcDbBlockTable *pBlockTable;
AcDbBlockTableRecord *pSpaceRecord;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForRead);
pBlockTable->getAt(ACDB_MODEL_SPACE, pSpaceRecord,
AcDb::kForWrite);
pSpaceRecord->appendAcDbEntity(objId, pEntity);
pBlockTable->close();
pEntity->close();
pSpaceRecord->close();
return Acad::eOk;
GMT+8, 2026-11-20 17:18
