网孔
网格是存储顶点的参数化矩形网格的有效方法。网格的几何图形按行顺序指定为行数、列数和顶点列表: virtual Adesk::Boolean AcGiWorldGeometry::mesh( const Adesk::UInt32 rows, const Adesk::UInt32 columns, const AcGePoint3d* pVertexList, const AcGiEdgeData* pEdgeData = NULL, const AcGiFaceData* pFaceData = NULL, const AcGiVertexData* pVertexData = NULL) const = 0; 该函数具有三个可选参数,用于将属性数据附加到边、面或顶点。对于网格中的边,可以附加颜色、图层、线型、GS 标记和可见性属性。例如,您可以使用将不同的颜色附加到网格的每个边。在颜色列表中,首先列出所有行边的颜色,然后列出所有列边的颜色。下图显示了示例网格的边属性数据的顺序:mesh()AcGiEdgeData::setColors()
![]() 以下示例代码创建网格并使用边数据和人脸数据指定颜色。它构造了一个带有青色行和绿色列的四乘四网格。 Adesk::Boolean
AsdkMeshSamp::subWorldDraw(AcGiWorldDraw* pW)
Adesk::UInt32 i, j, k;
Adesk::UInt32 numRows = 4;
Adesk::UInt32 numCols = 4;
AcGePoint3d *pVerts =
new AcGePoint3d[numRows * numCols];
for (k = 0, i = 0; i < numRows; i++) {
for (j = 0; j < numCols; j++, k++) {
pVerts[k].x = (double)j;
pVerts[k].y = (double)i;
pVerts[k].z = 0.;
// Construct an array of colors to be applied to each
// edge of the mesh. Here, let the rows be cyan and
// the columns be green.
AcGiEdgeData edgeInfo;
Adesk::UInt32 numRowEdges = numRows * (numCols - 1);
Adesk::UInt32 numColEdges = (numRows - 1) * numCols;
Adesk::UInt32 numEdges = numRowEdges + numColEdges;
short *pEdgeColorArray = new short[numEdges];
for (i = 0; i < numEdges; i++) {
pEdgeColorArray[i] =
i < numRowEdges ? kCyan : kGreen;
edgeInfo.setColors(pEdgeColorArray);
// Make the first face transparent and the rest
// different colors.
Adesk::UInt32 numFaces = (numRows - 1)
* (numCols - 1);
Adesk::UInt8 *pFaceVisArray =
new Adesk::UInt8[numFaces];
short *pFaceColorArray = new short[numFaces];
AcGiFaceData faceInfo;
faceInfo.setVisibility(pFaceVisArray);
for (i = 0; i < numFaces; i++) {
pFaceVisArray [i] =
i ? kAcGiVisible : kAcGiInvisible;
pFaceColorArray[i] = (short)(i + 1);
faceInfo.setColors(pFaceColorArray);
// If the fill type is kAcGiFillAlways, then a shell,
// mesh, or polygon will be interpreted as faces;
// otherwise, they will be interpreted as edges.
// Output mesh as faces.
pW- >subEntityTraits().setFillType(kAcGiFillAlways);
pW->geometry ().mesh(numRows, numCols, pVerts, NULL,
&faceInfo);
// Output mesh as edges over the faces.
pW- >subEntityTraits().setFillType(kAcGiFillNever);
&edgeInfo);
delete [] pVerts;
delete [] pEdgeColorArray;
delete [] pFaceColorArray;
delete [] pFaceVisArray;
return Adesk::kTrue;
对于网格中的面,可以附着颜色、图层、GS 标记、法线和可见性特征。要为网格中的面指定属性,请按行顺序列出面的值,如下图所示: ![]() 网格的顶点数据按顶点列表中的顺序列出。可以设置的属性是法线和方向。AcGiVertexData 父主题: |
GMT+8, 2026-10-27 05:45
