协议扩展示例
此协议扩展示例分为三个部分:
// This is the AsdkEntTemperature protocol extension abstract base
// class. Notice that this is the lowest level that uses
// the ACRX macros.
class AsdkEntTemperature : public AcRxObject
public:
ACRX_DECLARE_MEMBERS(AsdkEntTemperature);
virtual double reflectedEnergy(AcDbEntity*) const = 0;
ACRX_NO_CONS_DEFINE_MEMBERS(AsdkEntTemperature, AcRxObject);
// This is the default implementation to be attached to AcDbEntity
// as a catch-all. This guarantees that this protocol extension will
// be found for any entity, so the search up the AcRxClass tree will
// not fail and abort AutoCAD.
class AsdkDefaultTemperature : public AsdkEntTemperature
public:
virtual double reflectedEnergy(AcDbEntity* pEnt) const;
double
AsdkDefaultTemperature::reflectedEnergy(
acutPrintf(
"\nThis entity has no area, and no reflection.\n");
return -1.0;
// AsdkEntTemperature implementation for Regions
class AsdkRegionTemperature : public AsdkEntTemperature
public:
double
AsdkRegionTemperature::reflectedEnergy(
AcDbRegion *pRegion = AcDbRegion::cast(pEnt);
if (pRegion == NULL)
acutPrintf("\nThe impossible has happened!");
// Compute the reflected energy as the region area multiplied
// by a dummy constant.
double retVal;
if (pRegion->getArea(retVal) != Acad::eOk)
return -1.0;
return retVal * 42.0;
// AsdkEntTemperature implementation for circles
class AsdkCircleTemperature : public AsdkEntTemperature
public:
double
AsdkCircleTemperature::reflectedEnergy(
AcDbCircle *pCircle = AcDbCircle::cast(pEnt);
// Compute the reflected energy in a manner distinctly
// different than for AcDbRegion.
return pCircle->radius() * 6.21 * 42.0;
// This function has the user select an entity and then
// calls the reflectedEnergy() function in the protocol
// extension class attached to that entity's class.
void
energy()
AcDbEntity *pEnt;
AcDbObjectId pEntId;
ads_name en;
ads_point pt;
if (acedEntSel("\nSelect an Entity: ", en, pt)
!= RTNORM)
acutPrintf("Nothing Selected\n");
return;
acdbGetObjectId(pEntId, en);
acdbOpenObject(pEnt, pEntId, AcDb::kForRead);
// call the protocol extension class's method
double eTemp = ACRX_X_CALL(pEnt,
AsdkEntTemperature)->reflectedEnergy(pEnt);
acutPrintf("\nEnergy == %f\n", eTemp);
pEnt->close();
// Pointers for protocol extension objects. These pointers
// are global so that they can be accessed during
// initialization and cleanup.
AsdkDefaultTemperature *pDefaultTemp;
AsdkRegionTemperature *pRegionTemp;
AsdkCircleTemperature *pCircleTemp;
// Initialization function called from acrxEntryPoint() during
// kInitAppMsg case. This function is used to add commands
// to the command stack and to add protocol extension
// objects to classes.
void
initApp()
acrxRegisterService("AsdkTemperature");
AsdkEntTemperature::rxInit();
acrxBuildClassHierarchy();
pDefaultTemp = new AsdkDefaultTemperature();
pRegionTemp = new AsdkRegionTemperature();
pCircleTemp = new AsdkCircleTemperature();
// Add the protocol extension objects to the appropriate
// AcRxClass objects.
AcDbEntity::desc()->addX(AsdkEntTemperature::desc(),
pDefaultTemp);
AcDbRegion::desc()->addX(AsdkEntTemperature::desc(),
pRegionTemp);
AcDbCircle::desc()->addX(AsdkEntTemperature::desc(),
pCircleTemp);
acedRegCmds->addCommand("ASDK_TEMPERATURE_APP",
"ASDK_ENERGY", "ENERGY", ACRX_CMD_TRANSPARENT,
energy);
void
unloadApp()
delete acrxServiceDictionary->remove("AsdkTemperature");
acedRegCmds->removeGroup("ASDK_TEMPERATURE_APP");
// Remove protocol extension objects from the AcRxClass
// object tree. This must be done before removing the
// AsdkEntTemperature class from the ACRX runtime class
// hierarchy, so the AsdkEntTemperature::desc()
// still exists.
AcDbEntity::desc()->delX(AsdkEntTemperature::desc());
delete pDefaultTemp;
AcDbRegion::desc()->delX(AsdkEntTemperature::desc());
delete pRegionTemp;
AcDbCircle::desc()->delX(AsdkEntTemperature::desc());
delete pCircleTemp;
// Remove the AsdkEntTemperature class from the ARX
// runtime class hierarchy.
deleteAcRxClass(AsdkEntTemperature::desc());
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch (msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppMDIAware(appId);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
return AcRx::kRetOK;
父主题: |
GMT+8, 2026-10-27 05:32
