克隆来自不同所有者的对象
2024-5-18 16:58| 发布者: admin| 查看: 705| 评论: 0|原作者: admin|来自: AutoCAD
克隆来自不同所有者的对象
如果要克隆来自不同所有者的一组对象,则需要将对象 ID 集划分为每个所有者的单独组。(克隆的对象及其所有者应属于同一数据库。在本节的示例中,将要克隆的模型空间对象添加到 中,将要克隆的图纸空间对象添加到:objListMSobjListPS
objListMS.append(objId);
objListPS.append(objId);
然后,使用相同的 ID 映射调用该函数两次。必须使用单个 ID 映射进行所有克隆,才能正确完成参考翻译。在第一次调用时,该参数设置为 。在第二次(最后一次)调用时,默认为 :deepCloneObjects()deferXlationkTruedeepCloneObjects()deferXlationkFalse
acdbHostApplicationServices()->workingDatabase()->
    deepCloneObjects(mslist, modelSpaceId, idMap, Adesk::kTrue);
    deepCloneObjects(pslist, paperSpaceId, idMap);
此时,克隆结束,所有参考文献都已翻译。以下代码深度克隆属于不同所有者的对象:
void
cloneDiffOwnerObjects()
    // Step 1: Obtain the set of objects to be cloned.
    // For the two owners we'll use model space and
    // paper space, so we must perform two acedSSGet() calls.
    // calls.
    acutPrintf("\nSelect entities to be cloned to"
        " Model Space");
    ads_name ssetMS;
    acedSSGet(NULL, NULL, NULL, NULL, ssetMS);
    long lengthMS;
    acedSSLength(ssetMS, &lengthMS);
        " Paper Space");
    ads_name ssetPS;
    if (acedSSGet(NULL, NULL, NULL, NULL, ssetPS)
        != RTNORM && lengthMS == 0)
        acutPrintf("\nNothing selected");
        return;
    long lengthPS;
    acedSSLength(ssetPS, &lengthPS);
    // Step 2: Add obtained object IDs to the lists of
    // objects to be cloned: one list for objects to
    // be owned by model space and one for those to
    // be owned by paper space.
    AcDbObjectId ownerId = AcDbObjectId::kNull;
    // For model space
    AcDbObjectIdArray  objListMS;
    for (int i = 0; i < lengthMS; i++) {
        ads_name ent;
        acedSSName(ssetMS, i, ent);
        AcDbObjectId objId;
        acdbGetObjectId(objId, ent);
        // Check to be sure this has the same owner as the first
        // object.
        AcDbObject *pObj;
        acdbOpenObject(pObj, objId, AcDb::kForRead);
        if (pObj->ownerId() == ownerId)
        else if (i == 0) {
            ownerId = pObj->ownerId();
        pObj->close();
    acedSSFree(ssetMS);
    // For paper space
    AcDbObjectIdArray  objListPS;
    for (i = 0; i < lengthPS; i++) {
        ads_name ent;
        acedSSName(ssetPS, i, ent);
        AcDbObjectId objId;
        // object.
        AcDbObject *pObj;
        else if (i == 0) {
        pObj->close();
    acedSSFree(ssetPS);
    // Step 3: Get the object ID of the desired owners for
    // the cloned objects.  We're using model space and
    // paper space for this example.
    AcDbBlockTable *pBlockTable;
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbObjectId  modelSpaceId, paperSpaceId;
    pBlockTable->getAt(ACDB_MODEL_SPACE, modelSpaceId);
    pBlockTable->getAt(ACDB_PAPER_SPACE, paperSpaceId);
    pBlockTable->close();
    // Step 4:  Create a new ID map.
    AcDbIdMapping idMap;
    // Step 5: Call deepCloneObjects().
        ->deepCloneObjects(objListMS, modelSpaceId, idMap,
        Adesk::kTrue);
        ->deepCloneObjects(objListPS, paperSpaceId, idMap);
    // Now we can go through the ID map and do whatever we'd
    // like to the original and/or clone objects.
    // For this example we'll print out the object IDs of
    // the new objects resulting from the cloning process.
    AcDbIdMappingIter iter(idMap);
    for (iter.start(); !iter.done(); iter.next()) {
        AcDbIdPair idPair;
        iter.getMap(idPair);
        if (!idPair.isCloned())
            continue;
        acutPrintf("\nObjectId is: %Ld",
            idPair.value().asOldId());
GMT+8, 2026-10-27 04:59
