MDI 感知示例应用程序
以下示例显示了一个可识别 MDI 的简单 ObjectARX 应用程序。这是使用数据库反应器中的示例代码,其中添加了代码以使应用程序 MDI 可感知。 class AsdkDbReactor;
class AsdkDocReactor: public AcApDocManagerReactor
public:
virtual void documentToBeActivated(AcApDocument* pDoc);
virtual void documentCreated(AcApDocument* pDoc);
virtual void documentToBeDestroyed(AcApDocument* pDoc);
class AsdkPerDocData
friend class AsdkAppDocGlobals;
public:
AsdkPerDocData(AcApDocument* pDoc);
private:
AcApDocument* m_pDoc;
AsdkPerDocData* m_pNext;
long m_EntAcc; // Entity count
AsdkDbReactor* m_pDbr; // Pointer to database reactor
public:
AsdkAppDocGlobals(AcApDocument* pDoc);
void setGlobals(AcApDocument* pDoc);
void removeDocGlobals(AcApDocument *pDoc);
void removeAllDocGlobals(AsdkPerDocData* pTarget);
void unload();
long &entityCount();
void incrementEntityCount();
void decrementEntityCount();
AsdkDbReactor *dbReactor();
void setDbReactor(AsdkDbReactor *pDb);
private:
AsdkPerDocData *m_pHead;
AsdkPerDocData *m_pData;
AsdkDocReactor *m_pDocReactor;
AsdkAppDocGlobals *gpAsdkAppDocGlobals;
// Custom AcDbDatabaseReactor class for Database
// event notification.
class AsdkDbReactor : public AcDbDatabaseReactor
public:
virtual void objectAppended(const AcDbDatabase* dwg,
const AcDbObject* dbObj);
virtual void objectModified(const AcDbDatabase* dwg,
virtual void objectErased(const AcDbDatabase* dwg,
const AcDbObject* dbObj, Adesk::Boolean pErased);
// This is called whenever an object is added to the database.
void
AsdkDbReactor::objectAppended(const AcDbDatabase* db,
const AcDbObject* pObj)
printDbEvent(pObj, "objectAppended");
acutPrintf(" Db==%lx\n", (long) db);
gpAsdkAppDocGlobals->incrementEntityCount();
acutPrintf("Entity Count = %d\n",
gpAsdkAppDocGlobals->entityCount());
// This is called whenever an object in the database is modified.
void
AsdkDbReactor::objectModified(const AcDbDatabase* db,
printDbEvent(pObj, "objectModified");
// This is called whenever an object is erased from the database.
void
AsdkDbReactor::objectErased(const AcDbDatabase* db,
const AcDbObject* pObj, Adesk::Boolean pErased)
if (pErased)
printDbEvent(pObj, "objectErased");
gpAsdkAppDocGlobals->decrementEntityCount();
else
printDbEvent(pObj, "object(Un)erased");
// Prints the message passed in by pEvent; then
// proceeds to call printObj() to print the information about
// the object that triggered the notification.
void
printDbEvent(const AcDbObject* pObj, const char* pEvent)
acutPrintf(" Event: AcDbDatabaseReactor::%s ", pEvent);
printObj(pObj);
// Prints out the basic information about the object pointed
// to by pObj.
void
printObj(const AcDbObject* pObj)
if (pObj == NULL)
acutPrintf("(NULL)");
return;
AcDbHandle objHand;
char handbuf[17];
// Get the handle as a string.
pObj->getAcDbHandle(objHand);
objHand.getIntoAsciiBuffer(handbuf);
acutPrintf(
"\n (class==%s, handle==%s, id==%lx, db==%lx)",
pObj->isA()->name(), handbuf,
pObj->objectId().asOldId(), pObj->database());
// Document swapping functions
void
AsdkDocReactor::documentToBeActivated(AcApDocument *pDoc)
gpAsdkAppDocGlobals->setGlobals(pDoc);
void
AsdkDocReactor::documentCreated(AcApDocument *pDoc)
void
AsdkDocReactor::documentToBeDestroyed(AcApDocument *pDoc)
gpAsdkAppDocGlobals->removeDocGlobals(pDoc);
AsdkPerDocData::AsdkPerDocData(AcApDocument *pDoc)
m_pDoc = pDoc;
m_pNext = NULL;
m_EntAcc = 0;
m_pDbr = NULL;
AsdkAppDocGlobals::AsdkAppDocGlobals(AcApDocument *pDoc)
m_pData = m_pHead = NULL;
m_pDocReactor = new AsdkDocReactor();
acDocManager->addReactor(m_pDocReactor);
// Iterate through the list until the documents's global data is
// found. If it is not found, create a new set of document globals.
void
AsdkAppDocGlobals::setGlobals(AcApDocument *pDoc)
AsdkPerDocData *p_data = m_pHead, *prev_data = m_pHead;
while (p_data != NULL)
if (p_data->m_pDoc == pDoc)
m_pData = p_data;
break;
prev_data = p_data;
p_data = p_data->m_pNext;
if (p_data == NULL)
if (m_pHead == NULL)
m_pHead = m_pData = new AsdkPerDocData(pDoc);
else
prev_data->m_pNext = m_pData = new AsdkPerDocData(pDoc);
// Delete the globals associated with pDoc.
void
AsdkAppDocGlobals::removeDocGlobals(AcApDocument *pDoc)
if (p_data == m_pHead)
m_pHead = p_data->m_pNext;
else
prev_data->m_pNext = p_data->m_pNext;
if (m_pData == p_data)
m_pData = m_pHead;
delete p_data;
break;
prev_data = p_data;
// Delete all the doc globals in the list (recursively).
void
AsdkAppDocGlobals::removeAllDocGlobals(AsdkPerDocData *p_target)
if (p_target == NULL)
return;
if (p_target->m_pNext != NULL)
removeAllDocGlobals(p_target->m_pNext);
if (p_target->m_pDbr != NULL)
acdbHostApplicationServices()->workingDatabase(
)->removeReactor(p_target->m_pDbr);
delete p_target->m_pDbr;
p_target->m_pDbr = NULL;
delete p_target;
// Application was unloaded - delete everything associated with this
// document.
void AsdkAppDocGlobals::unload()
acDocManager->removeReactor(m_pDocReactor);
delete m_pDocReactor;
removeAllDocGlobals(m_pHead);
m_pHead = m_pData = NULL;
long &
AsdkAppDocGlobals::entityCount()
return m_pData->m_EntAcc;
void
AsdkAppDocGlobals::incrementEntityCount()
m_pData->m_EntAcc++;
void
AsdkAppDocGlobals::decrementEntityCount()
m_pData->m_EntAcc--;
AsdkDbReactor *
AsdkAppDocGlobals::dbReactor()
return m_pData->m_pDbr;
void
AsdkAppDocGlobals::setDbReactor(AsdkDbReactor *pDb)
m_pData->m_pDbr = pDb;
// Adds a reactor to the database to monitor changes.
// This can be called multiple times without any ill
// effects because subsequent calls will be ignored.
void
watchDb()
AsdkDbReactor *pDbr;
if (gpAsdkAppDocGlobals->dbReactor() == NULL)
pDbr = new AsdkDbReactor();
gpAsdkAppDocGlobals->setDbReactor(pDbr);
)->addReactor(pDbr);
acutPrintf(
" Added Database Reactor to "
"acdbHostApplicationServices()->workingDatabase().\n");
// Removes the database reactor.
void
clearReactors()
if ((pDbr = gpAsdkAppDocGlobals->dbReactor()) != NULL)
)->removeReactor(pDbr);
delete pDbr;
gpAsdkAppDocGlobals->setDbReactor(NULL);
// ObjectARX entry point function
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch (msg) {
case AcRx::kInitAppMsg:
acrxUnlockApplication(appId);
acrxRegisterAppMDIAware(appId);
gpAsdkAppDocGlobals = new AsdkAppDocGlobals(curDoc());
gpAsdkAppDocGlobals->setGlobals(curDoc());
acedRegCmds->addCommand("ASDK_NOTIFY_TEST",
"ASDK_WATCH",
"WATCH",
ACRX_CMD_TRANSPARENT,
watchDb);
"ASDK_CLEAR",
"CLEAR",
clearReactors);
break;
case AcRx::kUnloadAppMsg:
if (gpAsdkAppDocGlobals != NULL)
gpAsdkAppDocGlobals->unload();
delete gpAsdkAppDocGlobals;
gpAsdkAppDocGlobals = NULL;
acedRegCmds->removeGroup("ASDK_NOTIFY_TEST");
break;
return AcRx::kRetOK;
父主题: |
GMT+8, 2026-10-27 11:08
