示例:在对象依赖项中构建
下面的示例演示如何使用反应器在数据库对象之间建立依赖关系。在此示例中,当您更改一行时,另一行也会更改。 class AsdkObjectToNotify : public AcDbObject
// AsdkObjectToNotify - customized AcDbObject for persistent
// reactor to notify.
public:
ACRX_DECLARE_MEMBERS(AsdkObjectToNotify);
AsdkObjectToNotify() {};
void eLinkage(AcDbObjectId i, double f=1.0)
{mId=i; mFactor=f; };
void modified(const AcDbObject*);
Acad::ErrorStatus dwgInFields(AcDbDwgFiler*);
Acad::ErrorStatus dwgOutFields(AcDbDwgFiler*) const;
Acad::ErrorStatus dxfInFields(AcDbDxfFiler*);
Acad::ErrorStatus dxfOutFields(AcDbDxfFiler*) const;
private:
AcDbObjectId mId;
double mFactor;
ACRX_DXF_DEFINE_MEMBERS(AsdkObjectToNotify, AcDbObject,
AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
0, ASDKOBJECTTONOTIFY, persreac);
// This function is called every time the line it's
// "watching" is modified. When it's called, it opens the
// other line of the pair and changes that line's length to
// match the new length of the line that's just been
// modified.
void
AsdkObjectToNotify::modified(const AcDbObject* pObj)
AcDbLine *pLine = AcDbLine::cast(pObj);
if (!pLine) {
const char* cstr = pObj->isA()->name();
acutPrintf("This is a %s.\n", cstr);
acutPrintf("I only work with lines. Sorry.\n");
return;
acutPrintf("\nReactor attached to %lx calling %lx.\n",
pLine->objectId(), mId);
// This open fails during notification caused by a
// reactor being added to the entity or when this
// notification is in reaction to a change due to the
// other line's reactor changing this line. This
// properly prevents an infinite recursive loop
// between the two lines and their reactors.
AcDbLine *pLine2;
if (acdbOpenObject((AcDbObject*&)pLine2, mId,
AcDb::kForWrite) == Acad::eOk)
// Gets length of line entity we're being notified
// has just been modified.
AcGePoint3d p = pLine->startPoint();
AcGePoint3d q = pLine->endPoint();
AcGeVector3d v = q-p;
double len = v.length();
// Updates other entity to match.
p = pLine2->startPoint();
q = pLine2->endPoint();
v = q-p;
v = len * mFactor * v.normal();
pLine2->setEndPoint(p+v);
pLine2->close();
// Files an object's information in.
Acad::ErrorStatus
AsdkObjectToNotify::dwgInFields(AcDbDwgFiler* filer)
assertWriteEnabled();
AcDbObject::dwgInFields(filer);
filer->readItem(&mFactor);
filer->readItem((AcDbSoftPointerId*) &mId);
return filer->filerStatus();
// Files an object's information out.
Acad::ErrorStatus
AsdkObjectToNotify::dwgOutFields(AcDbDwgFiler* filer) const
assertReadEnabled();
AcDbObject::dwgOutFields(filer);
filer->writeItem(mFactor);
filer->writeItem((AcDbSoftPointerId&)mId);
// Files an object's information in from DXF and AutoLISP.
Acad::ErrorStatus
AsdkObjectToNotify::dxfInFields(AcDbDxfFiler* filer)
Acad::ErrorStatus es;
if ((es = AcDbObject::dxfInFields(filer))
!= Acad::eOk)
return es;
// Checks if we're at the right subclass data marker.
if(!filer->atSubclassData("AsdkObjectToNotify")) {
return Acad::eBadDxfSequence;
struct resbuf rbIn;
while (es == Acad::eOk) {
if ((es = filer->readItem(&rbIn)) == Acad::eOk) {
if (rbIn.restype == AcDb::kDxfReal) {
mFactor = rbIn.resval.rreal;
} else if (rbIn.restype
== AcDb::kDxfSoftPointerId)
// ObjectIds are filed in as ads_names.
acdbGetObjectId(mId, rbIn.resval.rlname);
} else { // invalid group
return(filer->pushBackItem());
// Files an object's information out to DXF and AutoLISP.
Acad::ErrorStatus
AsdkObjectToNotify::dxfOutFields(AcDbDxfFiler* filer) const
AcDbObject::dxfOutFields(filer);
filer->writeItem(AcDb::kDxfSubclass,
"AsdkObjectToNotify");
filer->writeItem(AcDb::kDxfReal, mFactor);
filer->writeItem(AcDb::kDxfSoftPointerId, mId);
// Creates two lines and two AsdkObjectToNotify objects and
// ties them all together.
void
assocLines()
AcDbDatabase *pDb =
acdbHostApplicationServices()->workingDatabase();
AcDbObjectId aId, bId;
AcDbLine *pLineA = new AcDbLine;
pLineA->setDatabaseDefaults(pDb);
pLineA->setStartPoint(AcGePoint3d(1, 1, 0));
pLineA->setEndPoint(AcGePoint3d(2, 1, 0));
addToModelSpace(aId, pLineA);
acutPrintf( "Line A is %lx from 1,1 to 2,1.\n",
pLineA->objectId());
AcDbLine *pLineB = new AcDbLine;
pLineB->setDatabaseDefaults(pDb);
pLineB->setStartPoint(AcGePoint3d(1, 2, 0));
pLineB->setEndPoint(AcGePoint3d(2, 2, 0));
addToModelSpace(bId, pLineB);
acutPrintf("Line B is %lx from 1,2 to 2,2.\n",
pLineB->objectId());
// Opens the named object dictionary, and checks if there is
// an entry with the key "ASDK_DICT". If not, creates a
// dictionary and add it.
AcDbDictionary *pNamedObj;
AcDbDictionary *pNameList;
pDb->getNamedObjectsDictionary(pNamedObj,
AcDb::kForWrite);
if (pNamedObj->getAt("ASDK_DICT",
(AcDbObject*&)pNameList, AcDb::kForWrite)
== Acad::eKeyNotFound)
pNameList = new AcDbDictionary;
AcDbObjectId DictId;
pNamedObj->setAt("ASDK_DICT", pNameList, DictId);
pNamedObj->close();
// Creates the AsdkObjectToNotify for line A.
AsdkObjectToNotify *pObj = new AsdkObjectToNotify();
pObj->eLinkage(bId);
AcDbObjectId objId;
if ((pNameList->getAt("object_to_notify_A", objId))
pNameList->setAt("object_to_notify_A", pObj, objId);
pObj->close();
} else {
delete pObj;
acutPrintf("object_to_notify_A already exists\n");
// Sets up persistent reactor link between line A
// and AsdkObjectToNotify.
pLineA->addPersistentReactor(objId);
pLineA->close();
// Creates the AsdkObjectToNotify for line B.
pObj->eLinkage(aId);
if ((pNameList->getAt("object_to_notify_B", objId))
pNameList->setAt("object_to_notify_B", pObj, objId);
pObj->close();
} else {
delete pObj;
acutPrintf("object_to_notify_B already exists\n");
pNameList->close();
// Sets up persistent reactor link between line B
pLineB->addPersistentReactor(objId);
pLineB->close();
// Adds an entity to model space, but does not close
// the entity.
void
addToModelSpace(AcDbObjectId &objId, AcDbEntity* pEntity)
AcDbBlockTable *pBlockTable;
AcDbBlockTableRecord *pSpaceRecord;
->getSymbolTable(pBlockTable, AcDb::kForRead);
pBlockTable->getAt(ACDB_MODEL_SPACE, pSpaceRecord,
AcDb::kForWrite);
pBlockTable->close();
pSpaceRecord->appendAcDbEntity(objId, pEntity);
pSpaceRecord->close();
return;
// This is the initialization function called from acrxEntryPoint()
// during the kInitAppMsg case. This function is used to add
// commands to the command stack.
void
initApp()
acedRegCmds->addCommand("ASDK_ALINES", "ASDK_ALINES",
"ALINES", ACRX_CMD_MODAL, assocLines);
AsdkObjectToNotify::rxInit();
acrxBuildClassHierarchy();
// This is the clean-up function called from acrxEntryPoint() during
// the kUnloadAppMsg case. This function removes this application's
// command set from the command stack.
void
unloadApp()
acedRegCmds->removeGroup("ASDK_ALINES");
// Removes the AsdkObjectToNotify class from the ACRX
// runtime class hierarchy. If this is done while the
// database is still active, it should cause all objects
// of class AsdkObjectToNotify to be turned into proxies.
deleteAcRxClass(AsdkObjectToNotify::desc());
// ObjectARX entry point
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch (msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppMDIAware(appId);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
return AcRx::kRetOK;
父主题: |
GMT+8, 2026-10-28 03:07
