数据链路代码示例
下面的代码示例提供了一种方法,说明如何正确设计代码以将 AutoCAD 表格数据链接到 Excel 电子表格。此处的示例假定文件的名称为“Sheet 1”。 // Create a data link and set it to the cell(2,2) of a selected table.
void createAndSetDataLink()
// Select a table
AcDbTable *pTbl = NULL;
if(NULL == (pTbl =
AcDbTable::cast(selectEntity(_T("\nSelect a table: ")))))
acutPrintf(ACRX_T("\nSelected entity was not a table!"));
return;
// Get an Excel file
struct resbuf *result;
int rc;
if ( (result = acutNewRb(RTSTR)) == NULL)
pTbl->close();
acutPrintf(ACRX_T("\nUnable to allocate buffer!"));
return;
result->resval.rstring=NULL;
rc = acedGetFileD(ACRX_T("Excel File"), // Title
ACRX_T("c:/temp"), // Default pathname
ACRX_T("xls"), //Default extension
16, // Control flags
result); // The path selected by the user.
if (rc != RTNORM)
pTbl->close();
acutPrintf(ACRX_T("\nError in selecting an EXCEL file!"));
return;
// Retrieve the file name from the ResBuf.
ACHAR fileName[MAX_PATH];
_tcscpy(fileName, result->resval.rstring);
rc = acutRelRb(result);
static ACHAR sMyDataLink[MAX_PATH] = ACRX_T("MyDataLinkTest");
// Get the Data Link Manager.
Acad::ErrorStatus es;
AcDbDataLinkManager* pDlMan = acdbHostApplicationServices()->workingDatabase()->getDataLinkManager();
assert(pDlMan);
AcDbObjectId idDL;
AcDbDataLink *pDL = NULL;
// Check if a Data Link with the name already exists. If so, remove it.
if( pDlMan->getDataLink(sMyDataLink, pDL, AcDb::kForRead) == Acad::eOk && pDL)
pDL->close();
es = pDlMan->removeDataLink(sMyDataLink, idDL);
if( es != Acad::eOk )
pTbl->close();
acutPrintf(ACRX_T("\nError in removing the Data Link!"));
return;
// Create the Data Link with the name.
es = pDlMan->createDataLink(ACRX_T("AcExcel"), sMyDataLink, ACRX_T("This is a test for Excel type data link."), fileName, idDL);
pTbl->close();
acutPrintf(ACRX_T("\nError in creating Data Link!\nPlease check if there is a sheet named 'Sheet1' in the XLS file."));
return;
// Open the Data Link.
es = acdbOpenObject<AcDbDataLink>(pDL, idDL, AcDb::kForWrite);
if ( es != Acad::eOk || !pDL )
pTbl->close();
acutPrintf(ACRX_T("\nError in opening the Data Link object!"));
return;
// Set options of the Data Link
es = pDL->setOption(AcDb::kDataLinkOptionPersistCache);
es = pDL->setUpdateOption(pDL->updateOption() | AcDb::kUpdateOptionAllowSourceUpdate);
// Close the Data Link.
pDL->close();
// Set data link to the table object at cell(2,2).
es = pTbl->setDataLink(2, 2, idDL, true);
pTbl->close();
acutPrintf(ACRX_T("\nError in setting Data Link to the selected table!\nPlease check if there is a sheet named 'Sheet1' in the XLS file."));
return;
// Don't forget to close the table object.
es = pTbl->close();
父主题: |
GMT+8, 2026-10-28 18:27
