subErase、subOpen、subClose 和 subCancel
、 和 函数 都具有以前缀 sub 开头的对应虚函数。可以重写这些辅助函数,以便为派生类提供额外的功能。辅助函数由非虚拟的“master”函数调用。例如,调用 .签名如下:erase()open()close()cancel()erase()subErase()subErase() virtual Acad::ErrorStatus subErase(Adesk::Boolean pErasing); 重写附属函数
最好不要更改附属函数中的任何状态。如果必须更改状态,请尝试在调用同一函数的父类实现后更改它(以防返回错误代码)。如果必须在调用父类函数之前更改状态,则请准备好在父类返回错误状态时撤消它。 下面的示例演示擦除对象时调用的函数的实现。该函数检查对其他对象的硬指针引用,并擦除它们。subErase()subErase() class AsdkEllipse : public AcDbEllipse
// This class extends AcDbEllipse by adding in functionality
// to store a dynamic array of hard pointer object IDs.
// The subErase() member function has been overridden and
// implemented, so when an object of this class is
// erased, the objects pointed to by the hard pointer IDs
// stored within the object will also be erased.
public:
ACRX_DECLARE_MEMBERS(AsdkEllipse);
AsdkEllipse() {};
AsdkEllipse(const AcDbObjectIdArray& ellipses)
: mEllipseIds(ellipses) {};
AsdkEllipse(const AcGePoint3d& center,
const AcGeVector3d& unitNormal,
const AcGeVector3d& majorAxis,
double radiusRatio,
double startAngle = 0.0,
double endAngle = 6.28318530717958647692);
AsdkEllipse(const AcDbObjectIdArray& ellipses,
double radiusRatio,
AcDbObjectId ellipseId(unsigned short which);
Acad::ErrorStatus setEllipseId(
const AcDbObjectId& objId, unsigned short which);
Acad::ErrorStatus setEllipseIds(
const AcDbObjectIdArray& Ids);
Acad::ErrorStatus appendId(const AcDbObjectId& objId);
Acad::ErrorStatus appendIds(
const AcDbObjectIdArray& objIds);
inline Adesk::Boolean removeId(
// AcDbObject overrides.
virtual Acad::ErrorStatus dwgInFields(
AcDbDwgFiler* filer);
virtual Acad::ErrorStatus dwgOutFields(
AcDbDwgFiler* filer) const;
virtual Acad::ErrorStatus dxfInFields(
AcDbDxfFiler* filer);
virtual Acad::ErrorStatus dxfOutFields(
AcDbDxfFiler* filer) const;
virtual Acad::ErrorStatus wblockClone(
AcRxObject* pOwnerObject,
AcDbObject*& pClonedObject,
AcDbIdMapping& idMap,
Adesk::Boolean isPrimary = Adesk::kTrue) const;
// AcDbEntity overrides.
virtual void list() const;
private:
AcDbObjectIdArray mEllipseIds;
static int mInFlux; // == 1 when first object's
// subErase is erasing.
ACRX_DXF_DEFINE_MEMBERS(AsdkEllipse, AcDbEllipse,
AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
0,\
ASDKELLIPSE, REFERENC);
// Static class data member definition.
int AsdkEllipse::mInFlux = Adesk::kFalse;
AsdkEllipse::AsdkEllipse(const AcGePoint3d& center,
double radiusRatio,
double startAngle,
double endAngle) :
AcDbEllipse(center, unitNormal, majorAxis, radiusRatio,
startAngle, endAngle)
AsdkEllipse::AsdkEllipse(const AcDbObjectIdArray& ellipses,
double radiusRatio,
double startAngle,
double endAngle) :
startAngle, endAngle), mEllipseIds(ellipses)
AcDbObjectId
AsdkEllipse::ellipseId(unsigned short which)
assertReadEnabled();
if (which > mEllipseIds.length())
return AcDbObjectId::kNull;
return mEllipseIds[which];
Acad::ErrorStatus
AsdkEllipse::setEllipseId(const AcDbObjectId& objId,
assertWriteEnabled();
return Acad::eInvalidIndex;
mEllipseIds[which] = objId;
return Acad::eOk;
Acad::ErrorStatus
AsdkEllipse::setEllipseIds(const AcDbObjectIdArray& objIds)
if (objIds.length() == 0)
return Acad::eNullObjectId;
mEllipseIds = objIds;
return Acad::eOk;
Acad::ErrorStatus
AsdkEllipse::appendId(const AcDbObjectId& objId)
if (objId == AcDbObjectId::kNull)
mEllipseIds.append(objId);
return Acad::eOk;
Acad::ErrorStatus
AsdkEllipse::appendIds(const AcDbObjectIdArray& objIds)
mEllipseIds.append(objIds);
return Acad::eOk;
AsdkEllipse::removeId(const AcDbObjectId& objId)
return mEllipseIds.remove(objId);
// This implementation of subErase opens and erases all
// objects that this entity has hard pointer references
// to. The effect is that when one AsdkEllipse is erased,
// all the others it has hard pointers to also erase as
// a "group".
Acad::ErrorStatus
AsdkEllipse::subErase(Adesk::Boolean pErasing)
Acad::ErrorStatus es = AcDbEllipse::subErase(pErasing);
if (es != Acad::eOk)
return es;
if (mInFlux == Adesk::kFalse) {
mInFlux = Adesk::kTrue;
AsdkEllipse *pEllipse;
int es;
for (int i = 0; i < mEllipseIds.length(); i++) {
es = acdbOpenObject(pEllipse, mEllipseIds[i],
AcDb::kForWrite, Adesk::kTrue);
continue;
pEllipse->erase(pErasing);
pEllipse->close();
return Acad::eOk;
Acad::ErrorStatus
AsdkEllipse::dwgInFields(AcDbDwgFiler* filer)
AcDbEllipse::dwgInFields(filer);
mEllipseIds.setLogicalLength(0);
int idCount;
filer->readInt32((long*)&idCount);
AcDbHardPointerId objId;
for (int i = 0; i < idCount; i++) {
filer->readItem(&objId);
return filer->filerStatus();
Acad::ErrorStatus
AsdkEllipse::dwgOutFields(AcDbDwgFiler* filer) const
AcDbEllipse::dwgOutFields(filer);
filer->writeInt32(mEllipseIds.length());
filer->writeHardPointerId(mEllipseIds[i]);
Acad::ErrorStatus
AsdkEllipse::dxfInFields(AcDbDxfFiler* filer)
Acad::ErrorStatus es = AcDbEllipse::dxfInFields(filer);
if (es != Acad::eOk) {
return es;
// Check to see if we're at the right subclass data
// marker.
if (!filer->atSubclassData("AsdkEllipse")) {
return Acad::eBadDxfSequence;
struct resbuf inbuf;
AcDbObjectId objId;
int idCount;
filer->readItem(&inbuf);
if (inbuf.restype == AcDb::kDxfInt32) {
idCount = inbuf.resval.rint;
} else {
filer->pushBackItem();
filer->setError(Acad::eInvalidDxfCode,
"\nError: expected group code %d",
AcDb::kDxfInt32);
es = filer->readItem(&inbuf);
filer->setError(Acad::eMissingDxfField,
"\nError: expected more group code %d's",
AcDb::kDxfHardPointerId);
if (inbuf.restype == AcDb::kDxfHardPointerId) {
acdbGetObjectId(objId, inbuf.resval.rlname);
} else {
Acad::ErrorStatus
AsdkEllipse::dxfOutFields(AcDbDxfFiler* filer) const
AcDbEllipse::dxfOutFields(filer);
filer->writeItem(AcDb::kDxfSubclass, "AsdkEllipse");
filer->writeInt32(AcDb::kDxfInt32,
filer->writeObjectId(AcDb::kDxfHardPointerId,
mEllipseIds[i]);
void
AsdkEllipse::list() const
AcDbEllipse::list();
acutPrintf("\nClass:\t%s", isA()->name());
acutPrintf("\nReferenceId[%d]:\t%ld", i,
(mEllipseIds[i]).asOldId());
Acad::ErrorStatus
AsdkEllipse::wblockClone(AcRxObject* pOwnerObject,
Adesk::Boolean isPrimary) const
static AcDbObjectId btr, pspace = AcDbObjectId::kNull;
AcTransaction *pTrans = NULL;
pClonedObject = NULL;
if (pspace == AcDbObjectId::kNull) {
AcDbBlockTable *pTable;
database()->getSymbolTable(pTable, AcDb::kForRead);
pTable->getAt(ACDB_PAPER_SPACE, pspace);
pTable->close();
if ( idMap.deepCloneContext() == AcDb::kDcXrefBind
&& ownerId() == pspace)
return Acad::eOk;
// Have we already done this entity ?
AcDbIdPair idPair(objectId(), (AcDbObjectId)NULL,
Adesk::kTrue);
if (idMap.compute(idPair) == TRUE && idPair.value()
!= NULL)
return Acad::eOk;
AcDbBlockTableRecord *pBTR
= AcDbBlockTableRecord::cast(pOwnerObject);
if (pBTR != NULL) {
if (isPrimary == Adesk::kTrue)
btr = pBTR->objectId();
else
btr = AcDbObjectId::kNull;
} else if (btr != AcDbObjectId::kNull) {
pTrans = actrTransactionManager->startTransaction();
pTrans->getObject((AcDbObject*&)pBTR, btr,
AcDb::kForWrite);
pOwnerObject = pBTR;
= AcDbEllipse::wblockClone(pOwnerObject,
pClonedObject, idMap, btr != AcDbObjectId::kNull);
if (pTrans)
actrTransactionManager->endTransaction();
acutPrintf("\nWblockClone error status: %s", acadErrorStatusText(es) );
return Acad::eOk;
void
createEllipses()
const ellipseCount = 10;
pEllipse = new AsdkEllipse(AcGePoint3d(4.0, 4.0, 0.0),
AcGeVector3d(0.0, 0.0, 1.0),
AcGeVector3d(2.0, 0.0, 0.0),
0.5);
AcDbVoidPtrArray ellipses;
ellipses.append(pEllipse);
// Now use the getTransformedCopy() function with a
// scaling matrix (in X & Y only) to create new
// AsdkEllipses, each 0.5 units larger than the last in
// the X & Y direction, but identical in the Z
// direction. This would be similar to the
// getOffsetCurves() function, but that function
// returns AcDbSpline entities instead of AcDbEllipses.
double j = 1.1;
AcGeMatrix3d scale;
for (int i = 0; i < ellipseCount; i++, j += 0.1) {
scale.setToScaling(j, pEllipse->center());
scale.entry[2][2] = 1.0; // Z scaling == 1
// getTransformed copy uses this->clone() to create
// a new object, which the ent pointer is assigned
// to point to. Therefore, ent should NOT point to an
// existing entity or there will be a memory leak!
// Since this->clone() is used, the AsdkEllipse class
// must override this member function to
// be sure that an AsdkEllipse is created instead
// of just an AcDbEllipse.
AsdkEllipse *pNextEllipse;
((AsdkEllipse*)ellipses[0])->getTransformedCopy(
scale, (AcDbEntity*&)pNextEllipse);
ellipses.append(pNextEllipse);
AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
AcDb::kForWrite);
pBlockTable->close();
AcDbObjectIdArray ellipseIds;
AcDbObjectId tempId;
for (i = 0; i < ellipses.length(); i++) {
pBlockTableRecord->appendAcDbEntity(tempId,
(AsdkEllipse*)ellipses[i]);
ellipseIds.append(tempId);
pBlockTableRecord->close();
// Set up the hard pointers and close the ellipses.
// Add in all the IDs.
((AsdkEllipse*)ellipses[i])
->setEllipseIds(ellipseIds);
// Now remove the object ID of the "*this" ellipse
// so it doesn't reference itself.
((AsdkEllipse*)ellipses[i])->removeId(
((AsdkEllipse*)ellipses[i])->objectId());
((AsdkEllipse*)ellipses[i])->close();
void
initApp()
acedRegCmds->addCommand("ASDK_ELLIPSES",
"ASDK_ELLIPSES", "ELLIPSES",
ACRX_CMD_MODAL, createEllipses);
AsdkEllipse::rxInit();
acrxBuildClassHierarchy();
void
unloadApp()
acedRegCmds->removeGroup("ASDK_ELLIPSES");
// Remove the AsdkEllipse class from the ACRX runtime
// class hierarchy. If this is done while the database is
// still active, it should cause all objects of class
// AsdkEllipse to be turned into proxies.
deleteAcRxClass(AsdkEllipse::desc());
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
switch (msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(appId);
acrxDynamicLinker->registerAppMDIAware(appId);
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
return AcRx::kRetOK;
父主题: |
GMT+8, 2026-10-27 04:34
