struct resbuf
2024-5-18 16:58| 发布者: admin| 查看: 760| 评论: 0|原作者: admin|来自: AutoCAD
struct resbuf
以下结果缓冲区结构 , 与并集 , 一起定义,用于容纳各种 AutoCAD 和 ObjectARX 数据类型,如下所示:resbufads_u_val
union ads_u_val {
    ads_real rreal;
    ads_real rpoint[3];
    short rint; // Must be declared short, not int.
    char *rstring;
    long rlname[2];
    long rlong;
    struct ads_binary rbinary;
struct resbuf {
    struct resbuf *rbnext; // Linked list pointer
    short restype;
    union ads_u_val resval;
注意:整数字段类似于二进制数据字段;两者都保存扩展的实体数据。longresval.rlongresval.rbinary
下图显示了结果缓冲区列表的示意图形式:
GMT+8, 2026-10-27 08:59
