使用绘图 API
应用程序可以选择使用绘图 API 配置时间功能和/或绘图时间功能。它们还可以包括多页文档、打印到文件、错误处理和覆盖默认打印进度对话框的规定。 注意:
每当通过绘图 API 访问绘图引擎时,如果 BACKGROUNDPLOT 系统变量设置为 0,系统将在前台绘制,如果 BACKGROUNDPLOT 系统变量设置为 1、2 或 3,则系统将在后台绘制。 使用基本配置时和绘图时 API
以下代码演示了 API 和默认打印进度对话框的基本用法,绘图进度对话框中对此进行了进一步讨论。 AcPlPlotEngine* pEngine = NULL;
if(Acad::eOk==AcPlPlotFactory::createPublishEngine(pEngine))
// Here is the progress dialog for the current plot process...
AcPlPlotProgressDialog *pPlotProgDlg=acplCreatePlotProgressDialog(
acedGetAcadFrame()->m_hWnd,false,1);
pPlotProgDlg->setPlotMsgString(
AcPlPlotProgressDialog::PlotMSGIndex::kDialogTitle,
"Plot API Progress");
AcPlPlotProgressDialog::PlotMSGIndex::kCancelJobBtnMsg,
"Cancel Job");
AcPlPlotProgressDialog::PlotMSGIndex::kCancelSheetBtnMsg,
"Cancel Sheet");
AcPlPlotProgressDialog::PlotMSGIndex::kSheetSetProgressCaption,
"Job Progress");
AcPlPlotProgressDialog::PlotMSGIndex::kSheetProgressCaption,
"Sheet Progress");
pPlotProgDlg->setPlotProgressRange(0,100);
pPlotProgDlg->onBeginPlot();
pPlotProgDlg->setIsVisible(true);
es = pEngine->beginPlot(pPlotProgDlg);
AcPlPlotPageInfo pageInfo;
// Used to describe how the plot is to be made.
AcPlPlotInfo plotInfo;
// First, set the layout to the specified layout
// (which is the current layout in this sample).
plotInfo.setLayout(layoutId);// This is required.
// Now, override the layout settings with the plot settings
// we have been populating.
plotInfo.setOverrideSettings(pPlotSettings);
// We need to validate these settings.
AcPlPlotInfoValidator validator;
validator.setMediaMatchingPolicy(
AcPlPlotInfoValidator::MatchingPolicy::kMatchEnabled);
es = validator.validate(plotInfo);
// Begin document. The version we call is dependent
// on the plot-to-file status.
const char *szDocName=acDocManager->curDocument()->fileName();
if(m_bPlotToFile)
es = pEngine->beginDocument(plotInfo, szDocName,
NULL, 1, true, m_csFilename);
else
es = pEngine->beginDocument(plotInfo, szDocName);
// Follow through sending commands to the engine,
// and notifications to the progress dialog.
pPlotProgDlg->onBeginSheet();
pPlotProgDlg->setSheetProgressRange(0, 100);
pPlotProgDlg->setSheetProgressPos(0);
es = pEngine->beginPage(pageInfo, plotInfo, true);
es = pEngine->beginGenerateGraphics();
es = pEngine->endGenerateGraphics();
es = pEngine->endPage();
pPlotProgDlg->setSheetProgressPos(100);
pPlotProgDlg->onEndSheet();
pPlotProgDlg->setPlotProgressPos(100);
es = pEngine->endDocument();
es = pEngine->endPlot();
// Destroy the engine
pEngine->destroy();
pEngine = NULL;
// and the progress dialog.
pPlotProgDlg->destroy();
else
// Ensure the engine is not already busy...
AfxMessageBox("Plot Engine is Busy...");
父主题: |
GMT+8, 2026-10-27 04:15
