ObjectARX 开发指南
多头交易示例
2023-1-1 05:40| 发布者: admin| 查看: 2417| 评论: 0|来自: AutoCAD
这个简单的示例演示如何从另一个数据库中签出实体,在当前数据库中修改它们,然后将其签回原始数据库。作为长事务过程一部分的调用以粗体显示。
void
refEditApiExample()
AcDbObjectId transId;
AcDbDatabase* pDb;
TCHAR *fname;
struct resbuf *rb;
    // Get a dwg file from the user.
    rb = acutNewRb(RTSTR);
    int stat = acedGetFileD(_T("Pick a drawing"), NULL, _T("dwg"),
 0, rb);
if ((stat != RTNORM) || (rb == NULL)) {
        acutPrintf(_T("\nYou must pick a drawing file."));        return;    }
fname = (TCHAR*)acad_malloc((_tcslen(rb->resval.rstring) + 1) *
 sizeof(TCHAR));
    _tcscpy(fname, rb->resval.rstring);
    acutRelRb(rb);
// Open the dwg file.
    pDb = new AcDbDatabase(Adesk::kFalse);
    if (pDb->readDwgFile(fname) != Acad::eOk) {
        acutPrintf(_T("\nSorry, that drawing is probably already
          open."));
        return;
    // Get the Block Table and then the model space record.
    AcDbBlockTable *pBlockTable;
    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pOtherMsBtr;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pOtherMsBtr,
      AcDb::kForRead);
    pBlockTable->close();
    // Create an iterator.
    AcDbBlockTableRecordIterator *pIter;
    pOtherMsBtr->newIterator(pIter);
    // Set up an object ID array.
    AcDbObjectIdArray objIdArray;
    // Iterate over the model space BTR. Look specifically
    // for lines and append their object ID to the array.
    for (pIter->start(); !pIter->done(); pIter->step()) {
        AcDbEntity *pEntity;
        pIter->getEntity(pEntity, AcDb::kForRead);
        // Look for only AcDbLine objects and add them to the
        // object ID array.
        if (pEntity->isKindOf(AcDbLine::desc())) {
            objIdArray.append(pEntity->objectId());
        pEntity->close();
    delete pIter;
    pOtherMsBtr->close();
    if (objIdArray.isEmpty()) {
        acad_free(fname);
        acutPrintf(_T("\nYou must pick a drawing file that contains
          lines."));
        return;
    // Now get the current database and the object ID for the
    // current database's model space BTR.
    AcDbBlockTable *pThisBlockTable;
    acdbHostApplicationServices()->workingDatabase()->
      getSymbolTable(pThisBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pThisMsBtr;
    pThisBlockTable->getAt(ACDB_MODEL_SPACE, pThisMsBtr,
      AcDb::kForWrite);
    pThisBlockTable->close();
    AcDbObjectId id = pThisMsBtr->objectId();
    pThisMsBtr->close();
    // Create the long transaction. This will check all the entities
    // out of the external database.
    AcDbIdMapping errorMap;
    acapLongTransactionManagerPtr()->checkOut(transId, objIdArray,
      id, errorMap);
    // Now modify the color of these entities.
    int colorIndex;
    acedGetInt(_T("\nEnter color number to change entities to: "),
      &colorIndex);
    AcDbObject* pObj;
    if (acdbOpenObject(pObj, transId, AcDb::kForRead) == Acad::eOk) {
        // Get a pointer to the transaction.
        AcDbLongTransaction* pLongTrans =
          AcDbLongTransaction::cast(pObj);
        if (pLongTrans != NULL) {
            // Get a work set iterator.
            AcDbLongTransWorkSetIterator* pWorkSetIter;
            pLongTrans->newWorkSetIterator(pWorkSetIter);
            // Iterate over the entities in the work set and change
            // the color.
            for (pWorkSetIter->start(); !pWorkSetIter->done();
               pWorkSetIter->step()) {
                acdbOpenAcDbEntity(pEntity, pWorkSetIter->objectId(),
                  AcDb::kForWrite);
                pEntity->setColorIndex(colorIndex);
                pEntity->close();
            delete pWorkSetIter;
        pObj->close();
    // Pause to see the change.
    TCHAR str[132];
    acedGetString(0, _T("\nSee the new colors. Press return to check
      the object into the original database"), str);
    // Check the entities back in to the original database.
    acapLongTransactionManagerPtr()->checkIn(transId, errorMap);
    // Save the original database, since we have made changes.
    pDb->saveAs(fname);
    // Close/Delete the database
    delete pDb;
    pDb = NULL;
    acad_free(fname);
GMT+8, 2026-10-29 00:06
