超链接示例
以下函数列出与实体关联的超链接,并允许在其位置添加新的超链接。(不显示错误检查。 void AddHyperlink()
ads_name en;
ads_point pt;
AcDbEntity * pEnt;
AcDbObjectId pEntId;
// Prompt user to select entity.
acedEntSel("\nSelect an Entity: ", en, pt);
// Get Object id.
acdbGetObjectId(pEntId, en);
// Open object for write.
acdbOpenObject(pEnt, pEntId, AcDb::kForWrite);
// The hyperlink collection object is created inside
// of getHyperlinkCollection below.
// It is our responsibility to delete it.
AcDbHyperlinkCollection * pcHCL = NULL;
// Get the hyperlink collection associated with the entity.
ACRX_X_CALL(pEnt, AcDbEntityHyperlinkPE)->
getHyperlinkCollection(pEnt, pcHCL, false, true);
// If a hyperlink exists already, say so.
if (pcHCL->count() != 0)
AcDbHyperlink * pcHO;
acutPrintf("\nThe following hyperlink info already exists
on this entity:");
// Iterate through collection and print existing hyperlinks.
int i = 0;
for (i = 0; i < pcHCL->count(); i++)
// Get point to current hyperlink object.
pcHO = pcHCL->item(i);
acutPrintf("\nHyperlink name: %s", pcHO->name());
acutPrintf("\nHyperlink location: %s",
pcHO->subLocation());
acutPrintf("\nHyperlink description: %s",
pcHO->description());
acutPrintf("\n** All will be replaced.**");
// Remove existing hyperlinks from collection.
// RemoveAt will delete objects too.
for (i = pcHCL->count() - 1; i >= 0; i--)
pcHCL->removeAt(i);
// Get new hyperlinks for this entity.
for (;;)
acutPrintf("\nEnter null name, location, and description to
terminate input requests.");
// Prompt user for name and description.
char sName[100], sLocation[100], sDescription[100];
if (acedGetString(TRUE, "\nEnter hyperlink name: ", sName)
!= RTNORM)
acutPrintf("Invalid input\n");
if (acedGetString(TRUE, "\nEnter hyperlink location: ",
sLocation) != RTNORM)
if (acedGetString(TRUE, "\nEnter hyperlink description: ",
sDescription) != RTNORM)
// Add hyperlink or exit prompting.
if (strcmp(sName, "") || strcmp(sLocation, "") ||
strcmp(sDescription, ""))
pcHCL->addTail(sName, sDescription, sLocation);
else
break;
// Add these hyperlinks to the selected entity (opened above).
setHyperlinkCollection(pEnt, pcHCL);
// Delete the collection. The collection will delete all its
// contained hyperlink objects.
delete pcHCL;
// Close the object.
pEnt->close();
父主题: |
GMT+8, 2026-10-27 10:28
