创建简单块表记录
下面的示例演示如何创建新的块表记录并将其追加到块表中。然后,它创建一行并将其附加到新的块表记录中。 void
makeABlock()
// Create and name a new block table record.
AcDbBlockTableRecord *pBlockTableRec
= new AcDbBlockTableRecord();
pBlockTableRec->setName("ASDK-NO-ATTR");
// Get the block table.
AcDbBlockTable *pBlockTable = NULL;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForWrite);
// Add the new block table record to the block table.
AcDbObjectId blockTableRecordId;
pBlockTable->add(blockTableRecordId, pBlockTableRec);
pBlockTable->close();
// Create and add a line entity to the component's
// block record.
AcDbLine *pLine = new AcDbLine();
AcDbObjectId lineId;
pLine->setStartPoint(AcGePoint3d(3, 3, 0));
pLine->setEndPoint(AcGePoint3d(6, 6, 0));
pLine->setColorIndex(3);
pBlockTableRec->appendAcDbEntity(lineId, pLine);
pLine->close();
pBlockTableRec->close();
父主题: |
GMT+8, 2026-10-27 05:19
