全局函数扩展字典示例
以下示例使用全局 ObjectARX 函数创建 xrecord 并将其添加到与 key 关联的字典中。ASDK_REC int
createXrecord()
struct resbuf *pXrec, *pEnt, *pDict, *pTemp, *pTemp2;
ads_point dummy, testpt = {1.0, 2.0, 0.0};
ads_name xrecname, ename, extDict = {0L, 0L};
// Have the user select an entity. Then get its data.
if (acedEntSel("\nselect entity: ", ename, dummy)
!= RTNORM)
acutPrintf("\nNothing selected");
acedRetVoid();
return RTNORM;
pEnt = acdbEntGet(ename);
// Now check to see if the entity already has an
// extension dictionary.
for (pTemp = pEnt; pTemp->rbnext != NULL;
pTemp = pTemp->rbnext)
if (pTemp->restype == 102) {
if (!strcmp("{ACAD_XDICTIONARY",
pTemp->resval.rstring))
ads_name_set(pTemp->rbnext->resval.rlname, extDict);
break;
// If no extension dictionary exists, add one.
if (extDict[0] == 0L) {
pDict = acutBuildList(RTDXF0, "DICTIONARY", 100,
"AcDbDictionary", 0);
acdbEntMakeX(pDict, extDict);
acutRelRb(pDict);
pDict = acutBuildList(102, "{ACAD_XDICTIONARY", 360,
extDict, 102, "}", 0);
for (pTemp = pEnt; pTemp->rbnext->restype != 100;
for (pTemp2 = pDict; pTemp2->rbnext != NULL;
pTemp2 = pTemp2->rbnext)
pTemp2->rbnext = pTemp->rbnext;
pTemp->rbnext = pDict;
acdbEntMod(pEnt);
acutRelRb(pEnt);
// At this point the entity has an extension dictionary.
// Create a resbuf list of the xrecord's entity information
// and data.
pXrec = acutBuildList(RTDXF0, "XRECORD",
100, "AcDbXrecord",
1, "This is a test Xrecord list", //AcDb::kDxfText
10, testpt, //AcDb::kDxfXCoord
40, 3.14159, //AcDb::kDxfReal
50, 3.14159, //AcDb::kDxfAngle
60, 1, //AcDb::kDxfColor
70, 180, //AcDb::kDxfInt16
0);
// Create the xrecord with no owner set. The xrecord's
// new entity name will be placed into the xrecname
// argument.
acdbEntMakeX (pXrec, xrecname);
acutRelRb (pXrec);
// Set the xrecord's owner to the extension dictionary
acdbDictAdd(extDict, "ASDK_XRECADS", xrecname);
acedRetVoid();
return RTNORM;
// Accesses the xrecord associated with the key ASDK_XRECADS in
// the extension dictionary of a user-selected entity. Then
// list out the contents of this xrecord using the printList
// function.
int
listXrecord()
struct resbuf *pXrec, *pEnt, *pTemp;
ads_point dummy;
ads_name ename, extDict = {0L, 0L};
// Have the user select an entity; then get its data.
if (acedEntSel("\nselect entity: ", ename, dummy) != RTNORM) {
acedRetVoid();
return RTNORM;
// Get the entity name of the extension dictionary.
for (pTemp = pEnt;pTemp->rbnext != NULL;pTemp = pTemp->rbnext) {
if (!strcmp("{ACAD_XDICTIONARY", pTemp->resval.rstring)){
break;
acutPrintf("\nNo extension dictionary present.");
return RTNORM;
pXrec = acdbDictSearch(extDict, "ASDK_XRECADS", 0);
if(pXrec) {
printList(pXrec);
acutRelRb(pXrec);
acedRetVoid();
return RTNORM;
父主题: |
GMT+8, 2026-10-27 05:16
