多头交易示例
这个简单示例演示如何从另一个数据库中签出实体,在当前数据库中修改它们,然后将它们签回原始数据库。作为长事务处理的一部分的调用以粗体字表示。 void
refEditApiExample()
AcDbObjectId transId;
AcDbDatabase* pDb;
TCHAR *fname;
struct resbuf *rb;
// Get a dwg file from the user.
rb = acutNewRb(RTSTR);
int stat = acedGetFileD(_T("Pick a drawing"), NULL, _T("dwg"),
0, rb);
if ((stat != RTNORM) || (rb == NULL)) {
acutPrintf(_T("\nYou must pick a drawing file.")); return; }
fname = (TCHAR*)acad_malloc((_tcslen(rb->resval.rstring) + 1) *
sizeof(TCHAR));
_tcscpy(fname, rb->resval.rstring);
acutRelRb(rb);
// Open the dwg file.
pDb = new AcDbDatabase(Adesk::kFalse);
if (pDb->readDwgFile(fname) != Acad::eOk) {
acutPrintf(_T("\nSorry, that drawing is probably already
open."));
return;
// Get the Block Table and then the model space record.
AcDbBlockTable *pBlockTable;
pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
AcDbBlockTableRecord *pOtherMsBtr;
pBlockTable->getAt(ACDB_MODEL_SPACE, pOtherMsBtr,
AcDb::kForRead);
pBlockTable->close();
// Create an iterator.
AcDbBlockTableRecordIterator *pIter;
pOtherMsBtr->newIterator(pIter);
// Set up an object ID array.
AcDbObjectIdArray objIdArray;
// Iterate over the model space BTR. Look specifically
// for lines and append their object ID to the array.
for (pIter->start(); !pIter->done(); pIter->step()) {
AcDbEntity *pEntity;
pIter->getEntity(pEntity, AcDb::kForRead);
// Look for only AcDbLine objects and add them to the
// object ID array.
if (pEntity->isKindOf(AcDbLine::desc())) {
objIdArray.append(pEntity->objectId());
pEntity->close();
delete pIter;
pOtherMsBtr->close();
if (objIdArray.isEmpty()) {
acad_free(fname);
acutPrintf(_T("\nYou must pick a drawing file that contains
lines."));
return;
// Now get the current database and the object ID for the
// current database's model space BTR.
AcDbBlockTable *pThisBlockTable;
acdbHostApplicationServices()->workingDatabase()->
getSymbolTable(pThisBlockTable, AcDb::kForRead);
AcDbBlockTableRecord *pThisMsBtr;
pThisBlockTable->getAt(ACDB_MODEL_SPACE, pThisMsBtr,
AcDb::kForWrite);
pThisBlockTable->close();
AcDbObjectId id = pThisMsBtr->objectId();
pThisMsBtr->close();
// Create the long transaction. This will check all the entities
// out of the external database.
AcDbIdMapping errorMap;
acapLongTransactionManagerPtr()->checkOut(transId, objIdArray,
id, errorMap);
// Now modify the color of these entities.
int colorIndex;
acedGetInt(_T("\nEnter color number to change entities to: "),
&colorIndex);
AcDbObject* pObj;
if (acdbOpenObject(pObj, transId, AcDb::kForRead) == Acad::eOk) {
// Get a pointer to the transaction.
AcDbLongTransaction* pLongTrans =
AcDbLongTransaction::cast(pObj);
if (pLongTrans != NULL) {
// Get a work set iterator.
AcDbLongTransWorkSetIterator* pWorkSetIter;
pLongTrans->newWorkSetIterator(pWorkSetIter);
// Iterate over the entities in the work set and change
// the color.
for (pWorkSetIter->start(); !pWorkSetIter->done();
pWorkSetIter->step()) {
acdbOpenAcDbEntity(pEntity, pWorkSetIter->objectId(),
AcDb::kForWrite);
pEntity->setColorIndex(colorIndex);
pEntity->close();
delete pWorkSetIter;
pObj->close();
// Pause to see the change.
TCHAR str[132];
acedGetString(0, _T("\nSee the new colors. Press return to check
the object into the original database"), str);
// Check the entities back in to the original database.
acapLongTransactionManagerPtr()->checkIn(transId, errorMap);
// Save the original database, since we have made changes.
pDb->saveAs(fname);
// Close/Delete the database
delete pDb;
pDb = NULL;
acad_free(fname);
父主题: |
GMT+8, 2026-10-27 10:28
