代码示例:编写需求加载键
2024-5-18 16:57| 发布者: admin| 查看: 804| 评论: 0|原作者: admin|来自: AutoCAD
代码示例:编写需求加载键
以下示例(来自 ObjectARX SDK polysamp 示例程序)演示了如何为注册组和命令的 ObjectARX 应用程序编写需求加载密钥:
void updateRegistry()
// Fill the AppInfo structure with our demand loading details.
    AcadAppInfo appInfo;
    appInfo.setAppName("AsdkPolyCAD"); // Application name
    appInfo.setModuleName(acedGetAppName());// Module path
    appInfo.setAppDesc("AsdkPolyCAD"); // Description
    appInfo.setLoadReason(// Specify when we want these to load
        AcadApp::LoadReasons(
        AcadApp::kOnCommandInvocation |
        AcadApp::kOnLoadRequest));
// Write the appInfo to the registry.
    appInfo.writeToRegistry();
// Write the group name.
    appInfo.writeGroupNameToRegistry("ASDK_POLYGON");
// Write out all our commands (Global,Local).
    appInfo.writeCommandNameToRegistry("ASDK_POLY","POLY");
    appInfo.writeCommandNameToRegistry("ASDK_DRAGPOLY","DRAGPOLY");
    appInfo.writeCommandNameToRegistry("ASDK_POLYEDIT","POLYEDIT");
    appInfo.writeCommandNameToRegistry("ASDK_TRANSACT","TRANSACT");
    appInfo.writeCommandNameToRegistry("ASDK_HILITPOLY","HILITPOLY");
    appInfo.writeCommandNameToRegistry("ASDK_HILITSOLID","HILITSOLID");
    appInfo.writeCommandNameToRegistry("ASDK_CREATEINSERT","CREATEINSERT");
    appInfo.writeCommandNameToRegistry("ASDK_HILITINSERT","HILITINSERT");
注意:Object Enabler 使用 ObjectARX 注册表格式的缩写版本。有关详细信息,请参阅“Object Enabler”中的“Registering Object Enabler for Demand Loading”部分。
  1. 需求加载
GMT+8, 2026-10-27 03:44
