分配和检索扩展数据 (.NET)
可以使用扩展数据 (xdata) 作为将信息与图形中的对象链接的方法。 将 xdata 分配给选择集中的所有对象本示例提示用户从图形中选取对象。所选对象将放置到选择集中,并且指定的 xdata 将附加到该选择集中的所有对象。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("AttachXDataToSelectionSetObjects")> _
Public Sub AttachXDataToSelectionSetObjects()
' Get the current database and start a transaction
Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
acCurDb = Application.DocumentManager.MdiActiveDocument.Database
Dim appName As String = "MY_APP"
Dim xdataStr As String = "This is some xdata"
' Request objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection()
' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
' Open the Registered Applications table for read
Dim acRegAppTbl As RegAppTable
acRegAppTbl = acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForRead)
' Check to see if the Registered Applications table record for the custom app exists
Dim acRegAppTblRec As RegAppTableRecord
If acRegAppTbl.Has(appName) = False Then
acRegAppTblRec = New RegAppTableRecord
acRegAppTblRec.Name = appName
acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForWrite)
acRegAppTbl.Add(acRegAppTblRec)
acTrans.AddNewlyCreatedDBObject(acRegAppTblRec, True)
End If
' Define the Xdata to add to each selected object
Using rb As New ResultBuffer
rb.Add(New TypedValue(DxfCode.ExtendedDataRegAppName, appName))
rb.Add(New TypedValue(DxfCode.ExtendedDataAsciiString, xdataStr))
Dim acSSet As SelectionSet = acSSPrompt.Value
' Step through the objects in the selection set
For Each acSSObj As SelectedObject In acSSet
' Open the selected object for write
Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, _
OpenMode.ForWrite)
' Append the extended data to each object
acEnt.XData = rb
Next
End Using
End If
' Save the new object to the database
acTrans.Commit()
' Dispose of the transaction
End Using
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("AttachXDataToSelectionSetObjects")]
public void AttachXDataToSelectionSetObjects()
// Get the current database and start a transaction
Database acCurDb;
acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
string appName = "MY_APP";
string xdataStr = "This is some xdata";
// Request objects to be selected in the drawing area
PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection();
// If the prompt status is OK, objects were selected
if (acSSPrompt.Status == PromptStatus.OK)
// Open the Registered Applications table for read
RegAppTable acRegAppTbl;
acRegAppTbl = acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForRead) as RegAppTable;
// Check to see if the Registered Applications table record for the custom app exists
if (acRegAppTbl.Has(appName) == false)
using (RegAppTableRecord acRegAppTblRec = new RegAppTableRecord())
acRegAppTblRec.Name = appName;
acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForWrite);
acRegAppTbl.Add(acRegAppTblRec);
acTrans.AddNewlyCreatedDBObject(acRegAppTblRec, true);
// Define the Xdata to add to each selected object
using (ResultBuffer rb = new ResultBuffer())
rb.Add(new TypedValue((int)DxfCode.ExtendedDataRegAppName, appName));
rb.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, xdataStr));
SelectionSet acSSet = acSSPrompt.Value;
// Step through the objects in the selection set
foreach (SelectedObject acSSObj in acSSet)
// Open the selected object for write
Entity acEnt = acTrans.GetObject(acSSObj.ObjectId,
OpenMode.ForWrite) as Entity;
// Append the extended data to each object
acEnt.XData = rb;
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub AttachXDataToSelectionSetObjects()
' Create the selection set
Dim sset As Object
Set sset = ThisDrawing.SelectionSets.Add("SS1")
' Prompt the user to select objects
sset.SelectOnScreen
' Define the xdata
Dim appName As String, xdataStr As String
appName = "MY_APP"
Dim xdataType(0 To 1) As Integer
Dim xdata(0 To 1) As Variant
' Define the values for each array
' 1001 indicates the appName
xdataType(0) = 1001
xdata(0) = appName
' 1000 indicates a string value
xdataType(1) = 1000
xdata(1) = xdataStr
' Loop through all entities in the selection
' set and assign the xdata to each entity
Dim ent As Object
For Each ent In sset
ent.SetXData xdataType, xdata
Next ent
查看选择集中所有对象的 xdata此示例显示与上一个示例一起附加的 xdata。如果附加字符串以外的 xdata(类型 1000),则需要修改此代码。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ViewXData")> _
Public Sub ViewXData()
Dim msgstr As String = ""
' Open the selected object for read
OpenMode.ForRead)
' Get the extended data attached to each object for MY_APP
Dim rb As ResultBuffer = acEnt.GetXDataForApplication(appName)
' Make sure the Xdata is not empty
If Not IsNothing(rb) Then
' Get the values in the xdata
For Each typeVal As TypedValue In rb
msgstr = msgstr & vbCrLf & typeVal.TypeCode.ToString() & ":" & typeVal.Value
Next
Else
msgstr = "NONE"
End If
' Display the values returned
MsgBox(appName & " xdata on " & VarType(acEnt).ToString() & ":" & vbCrLf & msgstr)
msgstr = ""
Next
End If
' Ends the transaction and ensures any changes made are ignored
acTrans.Abort()
End Using
[CommandMethod("ViewXData")]
public void ViewXData()
Database acCurDb;
string msgstr = "";
// Open the selected object for read
OpenMode.ForRead) as Entity;
// Get the extended data attached to each object for MY_APP
ResultBuffer rb = acEnt.GetXDataForApplication(appName);
// Make sure the Xdata is not empty
if (rb != null)
// Get the values in the xdata
foreach (TypedValue typeVal in rb)
msgstr = msgstr + "\n" + typeVal.TypeCode.ToString() + ":" + typeVal.Value;
else
msgstr = "NONE";
// Display the values returned
Application.ShowAlertDialog(appName + " xdata on " + acEnt.GetType().ToString() + ":\n" + msgstr);
msgstr = "";
// Ends the transaction and ensures any changes made are ignored
acTrans.Abort();
VBA/ActiveX 代码参考Sub ViewXData()
' Find the selection created in previous example
Dim sset As Object
Set sset = ThisDrawing.SelectionSets.Item("SS1")
' Define the xdata variables to hold xdata information
Dim xdataType As Variant
Dim xdata As Variant
Dim xd As Variant
' Define index counter
Dim xdi As Integer
xdi = 0
' Loop through the objects in the selection set
' and retrieve the xdata for the object
Dim ent As AcadEntity
appName = "MY_APP"
msgstr = ""
xdi = 0
' Retrieve the appName xdata type and value
ent.GetXData appName, xdataType, xdata
' If the xdataType variable is not initialized, there
' was no appName xdata to retrieve for that entity
If VarType(xdataType) <> vbEmpty Then
For Each xd In xdata
msgstr = msgstr & vbCrLf & xdataType(xdi) & ": " & xd
xdi = xdi + 1
Next xd
End If
' If the msgstr variable is NULL, there was no xdata
If msgstr = "" Then msgstr = vbCrLf & "NONE"
MsgBox appName & " xdata on " & ent.ObjectName & ":" & vbCrLf & msgstr
Next ent
父主题: |
GMT+8, 2026-10-27 04:13
