渲染预设 (.NET)
渲染预设允许您定义在屏幕上渲染 3D 对象或在布局输出期间应使用的设置。 设置渲染预设电流本示例设置渲染预设电流 VB.NET' Sets the Draft render preset current - RapidRT example
<CommandMethod("RRTRenderPresetsSetCurrent")> _
Public Shared Sub RRTRenderPresetsSetCurrent()
Dim itemDesc As ComponentModel.ICustomTypeDescriptor = Nothing
For Each itemDesc In Application.UIBindings.Collections.RenderPresets
Dim presetName As String = itemDesc.GetProperties.Find("Name", False).GetValue(itemDesc)
If presetName.ToUpper() = "DRAFT" Then
Application.UIBindings.Collections.RenderPresets.CurrentItem = itemDesc
Exit For
End If
Next
C#// Sets the Draft render preset current - RapidRT example
[CommandMethod("RRTRenderPresetsSetCurrent")]
public void RRTRenderPresetsSetCurrent()
foreach (System.ComponentModel.ICustomTypeDescriptor itemDesc in Application.UIBindings.Collections.RenderPresets)
String presetName = itemDesc.GetProperties().Find("Name", false).GetValue(itemDesc) as String;
if (presetName.ToUpper() == "LOW")
Application.UIBindings.Collections.RenderPresets.CurrentItem = itemDesc;
设置渲染预设电流(基于 AutoCAD 2015 及更早版本的产品)本示例设置渲染预设电流 VB.NET' Sets the Draft render preset current - MentalRay example
<CommandMethod("MRRenderPresetsSetCurrent")> _
Public Shared Sub MRRenderPresetsSetCurrent()
Application.UIBindings.RenderEngineMR.CurrentRenderPresetName = "Draft"
C#// Sets the Draft render preset current - MentalRay example
[CommandMethod("MRRenderPresetsSetCurrent")]
public void MRRenderPresetsSetCurrent()
Application.UIBindings.RenderEngineMR.CurrentRenderPresetName = "Draft";
列出可用的渲染预设有两种类型的渲染预设:标准预设和自定义预设。标准渲染预设(低、中、高、茶歇质量、午餐质量和隔夜质量)无法修改,因为它们是使用应用程序定义的。所有渲染预设都作为对象存储在“ACAD_RENDER_RAPIDRT_SETTINGS”命名字典中。RapidRTRenderSettings 第二个命名字典“ACAD_RENDER_PLOT_SETTINGS”用于存储渲染预设的副本,以便将其分配给 or 对象。ViewportPlotSettings 本示例列出存储在当前图形中的渲染预设。 VB.NET' Standard .NET namespaces
Imports System
Imports System.Runtime.InteropServices
' Main AutoCAD namespaces
Imports Autodesk.AutoCAD.PlottingServices
Imports Autodesk.AutoCAD.Windows
Imports Autodesk.AutoCAD.GraphicsInterface
' Lists the available render presets - RapidRT example
<CommandMethod("RRTRenderPresetsList")> _
Public Shared Sub RRTRenderPresetsList()
' Get the current document and database, and start a transaction
Dim namedObjs As DBDictionary = acTrans.GetObject(acCurDb.NamedObjectsDictionaryId, OpenMode.ForRead)
Try
' Step through and list each of the render presets
Dim renderSetting As RapidRTRenderSettings = Nothing
If namedObjs.Contains("ACAD_RENDER_RAPIDRT_SETTINGS") = True Then
Dim renderSettings As DBDictionary = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_RAPIDRT_SETTINGS"), OpenMode.ForRead)
acDoc.Editor.WriteMessage(vbLf & "Render presets: ")
For Each entry As DBDictionaryEntry In renderSettings
renderSetting = acTrans.GetObject(entry.Value, OpenMode.ForRead)
' Output the names of the available render preset
acDoc.Editor.WriteMessage(vbLf & " " & renderSetting.Name)
Next
Else
acDoc.Editor.WriteMessage(vbLf & "No render presets available.")
End If
Catch es As Autodesk.AutoCAD.Runtime.Exception
End Try
' Discard any changes
acTrans.Abort()
End Using
C#// Standard .NET namespaces
using System;
using System.Runtime.InteropServices;
// Main AutoCAD namespaces
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.GraphicsInterface;
// Lists the available render presets - RapidRT example
[CommandMethod("RRTRenderPresetsList")]
public void RRTRenderPresetsList()
// Get the current document and database, and start a transaction
DBDictionary namedObjs = acTrans.GetObject(acCurDb.NamedObjectsDictionaryId,
OpenMode.ForRead) as DBDictionary;
try
// Step through and list each of the render presets
RapidRTRenderSettings renderSetting = null;
if (namedObjs.Contains("ACAD_RENDER_RAPIDRT_SETTINGS") == true)
DBDictionary renderSettings = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_RAPIDRT_SETTINGS"),
acDoc.Editor.WriteMessage("\nRender presets: ");
foreach (DBDictionaryEntry entry in renderSettings)
renderSetting = acTrans.GetObject(entry.Value, OpenMode.ForRead) as RapidRTRenderSettings;
// Output the names of the available render preset
acDoc.Editor.WriteMessage("\n " + renderSetting.Name);
else
acDoc.Editor.WriteMessage("\nNo render presets available.");
catch (Autodesk.AutoCAD.Runtime.Exception Ex)
Application.ShowAlertDialog("The following exception was caught:\n" +
Ex.Message);
finally
// Discard any changes
acTrans.Abort();
列出可用的渲染预设(基于 AutoCAD 2015 及更早版本的产品)本示例列出存储在当前图形中的渲染预设。 标准渲染预设(草稿、低、中、高和演示)无法修改,因为它们是使用应用程序定义的。自定义渲染预设作为对象存储在“ACAD_RENDER_SETTINGS”命名字典中。MentalRayRenderSettings 注意:为了向后兼容,保留了以下示例代码。从基于 AutoCAD 2016 的产品开始,渲染设置由 RapidRTRenderSettings 类表示,而不是像早期版本中那样由 MentalRayRenderSettings 表示。
Imports System
' Lists the available render presets - MentalRay example
<CommandMethod("MRRenderPresetsList")> _
Public Shared Sub MRRenderPresetsList()
Try
acDoc.Editor.WriteMessage(vbLf & "Default render presets: ")
' List the default render presets
acDoc.Editor.WriteMessage(vbLf & " Draft")
acDoc.Editor.WriteMessage(vbLf & " Low")
acDoc.Editor.WriteMessage(vbLf & " Medium")
acDoc.Editor.WriteMessage(vbLf & " High")
acDoc.Editor.WriteMessage(vbLf & " Presentation")
' Step through and list each of the custom render presets
Dim renderSetting As MentalRayRenderSettings = Nothing
If namedObjs.Contains("ACAD_RENDER_SETTINGS") = True Then
Dim renderSettings As DBDictionary = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_SETTINGS"), OpenMode.ForRead)
acDoc.Editor.WriteMessage(vbLf & "Custom render presets: ")
Next
Else
acDoc.Editor.WriteMessage(vbLf & "No custom render presets available.")
End If
End Try
acTrans.Abort()
End Using
using System;
// Lists the available render presets - MentalRay example
[CommandMethod("MRRenderPresetsList")]
public void MRRenderPresetsList()
try
acDoc.Editor.WriteMessage("\nDefault render presets: ");
// List the default render presets
acDoc.Editor.WriteMessage("\n Draft");
acDoc.Editor.WriteMessage("\n Low");
acDoc.Editor.WriteMessage("\n Medium");
acDoc.Editor.WriteMessage("\n High");
acDoc.Editor.WriteMessage("\n Presentation");
// Step through and list each of the custom render presets
MentalRayRenderSettings renderSetting = null;
if (namedObjs.Contains("ACAD_RENDER_SETTINGS") == true)
DBDictionary renderSettings = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_SETTINGS"),
acDoc.Editor.WriteMessage("\nCustom render presets: ");
// Set the new render preset MyPreset current
renderSetting = acTrans.GetObject(entry.Value, OpenMode.ForRead) as MentalRayRenderSettings;
else
acDoc.Editor.WriteMessage("\nNo custom render presets available.");
Ex.Message);
finally
acTrans.Abort();
创建或编辑渲染预设本示例创建或编辑名为 MyPreset 的渲染预设。 VB.NET' Standard .NET namespaces
Imports System
' Creates a new render preset - RapidRT example
<CommandMethod("RRTRenderPresetsCreate")> _
Public Shared Sub RRTRenderPresetCreate()
Try
' Check to see if the Render Settings dictionary already exists or not
renderSettings = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_RAPIDRT_SETTINGS"), OpenMode.ForWrite)
Else
acTrans.GetObject(acCurDb.NamedObjectsDictionaryId, OpenMode.ForWrite)
renderSettings = New DBDictionary
namedObjs.SetAt("ACAD_RENDER_RAPIDRT_SETTINGS", renderSettings)
acTrans.AddNewlyCreatedDBObject(renderSettings, True)
End If
' Create the new render preset, based on the settings of the Medium render preset
If renderSettings.Contains("MyPreset") = False Then
Dim renderSetting As New RapidRTRenderSettings
renderSetting.Name = "MyPreset"
renderSetting.Description = "Custom new render preset"
' Set renderer settings
renderSetting.BackFacesEnabled = False
renderSetting.MaterialsEnabled = False
renderSetting.ShadowsEnabled = False
renderSetting.TextureSampling = False
' Set Rendering duration
renderSetting.RenderTarget = RapidRTRenderTarget.Level
renderSetting.RenderLevel = 10
' Set rendering accuracy
renderSetting.LightingModel = RapidRTLightingMode.Simplified
' Material rendering settings
renderSetting.FilterHeight = 5
renderSetting.FilterWidth = 5
renderSetting.FilterType = RapidRTFilterType.Mitchell
renderSetting.DisplayIndex = 20
renderSettings.SetAt("MyPreset", renderSetting)
acTrans.AddNewlyCreatedDBObject(renderSetting, True)
End If
MsgBox(es.Message)
Finally
acTrans.Commit()
End Try
End Using
acDoc.Editor.Command("_-RENDERPRESETS", "_custom", "mypreset")
using System;
// Creates a new render preset - RapidRT example
[CommandMethod("RRTRenderPresetsCreate")]
public void RRTRenderPresetsCreate()
try
// Check to see if the Render Settings dictionary already exists or not
DBDictionary renderSettings;
OpenMode.ForWrite) as DBDictionary;
else
acTrans.GetObject(acCurDb.NamedObjectsDictionaryId, OpenMode.ForWrite);
renderSettings = new DBDictionary();
namedObjs.SetAt("ACAD_RENDER_RAPIDRT_SETTINGS", renderSettings);
acTrans.AddNewlyCreatedDBObject(renderSettings, true);
// Create the new render preset, based on the settings of the Medium render preset
if (renderSettings.Contains("MyPreset") == false)
RapidRTRenderSettings renderSetting = new RapidRTRenderSettings();
renderSetting.Name = "MyPreset";
renderSetting.Description = "Custom new render preset";
// Set renderer settings
renderSetting.BackFacesEnabled = false;
renderSetting.MaterialsEnabled = false;
renderSetting.ShadowsEnabled = false;
renderSetting.TextureSampling = false;
// Set Rendering duration
renderSetting.RenderTarget = RapidRTRenderTarget.Level;
renderSetting.RenderLevel = 10;
// Set rendering accuracy
renderSetting.LightingModel = RapidRTLightingMode.Simplified;
// Material rendering settings
renderSetting.FilterHeight = 5;
renderSetting.FilterWidth = 5;
renderSetting.FilterType = RapidRTFilterType.Mitchell;
renderSetting.DisplayIndex = 20;
renderSettings.SetAt("MyPreset", renderSetting);
acTrans.AddNewlyCreatedDBObject(renderSetting, true);
Ex.Message);
finally
acTrans.Commit();
acDoc.Editor.Command("_-RENDERPRESETS", "_custom", "mypreset");
创建或编辑渲染预设(基于 AutoCAD 2015 及更早版本的产品)本示例创建或编辑名为 MyPreset 的渲染预设。定义了一个名为 GetDefaultRenderPreset 的帮助程序函数,该函数用于重新创建其中一个标准呈现预设的设置。 VB.NET' Standard .NET namespaces
Imports System
' Creates a new render preset - MentalRay example
<CommandMethod("MRRenderPresetsCreate")> _
Public Shared Sub MRRenderPresetCreate()
Try
renderSettings = acTrans.GetObject(namedObjs.GetAt("ACAD_RENDER_SETTINGS"), OpenMode.ForWrite)
Else
namedObjs.SetAt("ACAD_RENDER_SETTINGS", renderSettings)
End If
Dim renderSetting As MentalRayRenderSettings = GetDefaultRenderPreset("Medium")
End If
' Set the new render preset as current with the Render Engine
Application.UIBindings.RenderEngineMR.CurrentRenderPresetName = "MyPreset"
MsgBox(es.Message)
Finally
acTrans.Commit()
End Try
End Using
Private Shared Sub GetDefaultRenderPreset( _
ByRef renderPreset As MentalRayRenderSettings, _
ByVal name As String)
' Set the values common to multiple default render presets
renderPreset.BackFacesEnabled = False
renderPreset.DiagnosticBackgroundEnabled = False
renderPreset.DiagnosticBSPMode = _
DiagnosticBSPMode.Depth
renderPreset.DiagnosticGridMode = _
New MentalRayRenderSettingsTraitsDiagnosticGridModeParameter( _
DiagnosticGridMode.Object, 10.0)
renderPreset.DiagnosticMode = _
DiagnosticMode.Off
renderPreset.DiagnosticPhotonMode = _
DiagnosticPhotonMode.Density
renderPreset.DisplayIndex = 0
renderPreset.EnergyMultiplier = 1.0
renderPreset.ExportMIEnabled = False
renderPreset.ExportMIFileName = ""
renderPreset.FGRayCount = 100
' FGSampleRadius cannot be set, it returns invalid input
renderPreset.FGSampleRadiusState = _
New MentalRayRenderSettingsTraitsBoolParameter( _
False, False, False)
renderPreset.FinalGatheringEnabled = False
renderPreset.FinalGatheringMode = _
FinalGatheringMode.FinalGatherOff
renderPreset.GIPhotonsPerLight = 1000
renderPreset.GISampleCount = 500
renderPreset.GISampleRadius = 1.0
renderPreset.GISampleRadiusEnabled = False
renderPreset.GlobalIlluminationEnabled = False
renderPreset.LightLuminanceScale = 1500.0
renderPreset.MaterialsEnabled = True
renderPreset.MemoryLimit = 1048
renderPreset.PhotonTraceDepth = _
New MentalRayRenderSettingsTraitsTraceParameter( _
5, 5, 5)
renderPreset.PreviewImageFileName = ""
renderPreset.RayTraceDepth = _
3, 3, 3)
renderPreset.RayTracingEnabled = False
renderPreset.Sampling = _
New MentalRayRenderSettingsTraitsIntegerRangeParameter( _
-2, -1)
renderPreset.SamplingContrastColor = _
New MentalRayRenderSettingsTraitsFloatParameter( _
0.1, 0.1, 0.1, 0.1)
renderPreset.SamplingFilter = _
New MentalRayRenderSettingsTraitsSamplingParameter( _
Filter.Box, 1.0, 1.0)
renderPreset.ShadowMapsEnabled = False
renderPreset.ShadowMode = ShadowMode.Simple
renderPreset.ShadowSamplingMultiplier = _
ShadowSamplingMultiplier.SamplingMultiplierZero
renderPreset.ShadowsEnabled = True
renderPreset.TextureSampling = False
renderPreset.TileOrder = TileOrder.Hilbert
renderPreset.TileSize = 32
Select Case name.ToUpper()
' Assigns the values to match the Draft render preset
Case "DRAFT"
renderPreset.Description = _
"The lowest rendering quality which entails no raytracing, " & _
"no texture filtering and force 2-sided is inactive."
renderPreset.Name = "Draft"
Case ("LOW")
"Rendering quality is improved over Draft. " & _
"Low anti-aliasing and a raytracing depth of 3 " & _
"reflection/refraction are processed."
renderPreset.Name = "Low"
renderPreset.RayTracingEnabled = True
-1, 0)
0.1, 0.1, 0.1, 0.1)
Filter.Triangle, 2.0, 2.0)
ShadowSamplingMultiplier.SamplingMultiplierOneFourth
Case "MEDIUM"
renderPreset.BackFacesEnabled = True
"Rendering quality is improved over Low to include " & _
"texture filtering and force 2-sided is active. " & _
"Moderate anti-aliasing and a raytracing depth of " & _
"5 reflections/refractions are processed."
renderPreset.FGRayCount = 200
FinalGatheringMode.FinalGatherAuto
renderPreset.GIPhotonsPerLight = 10000
renderPreset.Name = "Medium"
5, 5, 5)
0, 1)
0.05, 0.05, 0.05, 0.05)
Filter.Gauss, 3.0, 3.0)
ShadowSamplingMultiplier.SamplingMultiplierOneHalf
renderPreset.TextureSampling = True
Case "HIGH"
"Rendering quality is improved over Medium. " & _
"High anti-aliasing and a raytracing depth of 7 " & _
"reflections/refractions are processed."
renderPreset.FGRayCount = 500
renderPreset.Name = "High"
7, 7, 7)
0, 2)
Filter.Mitchell, 4.0, 4.0)
Case "PRESENTATION"
"Rendering quality is improved over High. " & _
"Very high anti-aliasing and a raytracing depth of 9 " & _
renderPreset.FGRayCount = 1000
renderPreset.Name = "Presentation"
9, 9, 9)
1, 2)
Filter.Lanczos, 4.0, 4.0)
End Select
using System;
// Creates a new render preset - MentalRay example
[CommandMethod("MRRenderPresetsCreate")]
public void MRRenderPresetsCreate()
try
else
namedObjs.SetAt("ACAD_RENDER_SETTINGS", renderSettings);
MentalRayRenderSettings renderSetting = new MentalRayRenderSettings();
GetDefaultRenderPreset(ref renderSetting, "MyPreset");
// Set the new render preset as current with the Render Engine
Application.UIBindings.RenderEngineMR.CurrentRenderPresetName = "MyPreset";
Ex.Message);
finally
// Commit any changes
acTrans.Commit();
// Method used to populate a MentalRayRenderSettings object with the
// same settings used by the standard render presets
private static void GetDefaultRenderPreset(
ref MentalRayRenderSettings renderPreset,
string name)
// Set the values common to multiple default render presets
renderPreset.BackFacesEnabled = false;
renderPreset.DiagnosticBackgroundEnabled = false;
DiagnosticBSPMode.Depth;
new MentalRayRenderSettingsTraitsDiagnosticGridModeParameter(
DiagnosticGridMode.Object, (float)10.0);
DiagnosticMode.Off;
DiagnosticPhotonMode.Density;
renderPreset.DisplayIndex = 0;
renderPreset.EnergyMultiplier = (float)1.0;
renderPreset.ExportMIEnabled = false;
renderPreset.ExportMIFileName = "";
renderPreset.FGRayCount = 100;
// FGSampleRadius cannot be set, it returns invalid input
new MentalRayRenderSettingsTraitsBoolParameter(
false, false, false);
renderPreset.FinalGatheringEnabled = false;
FinalGatheringMode.FinalGatherOff;
renderPreset.GIPhotonsPerLight = 1000;
renderPreset.GISampleCount = 500;
renderPreset.GISampleRadius = 1.0;
renderPreset.GISampleRadiusEnabled = false;
renderPreset.GlobalIlluminationEnabled = false;
renderPreset.LightLuminanceScale = 1500.0;
renderPreset.MaterialsEnabled = true;
renderPreset.MemoryLimit = 1048;
new MentalRayRenderSettingsTraitsTraceParameter(
5, 5, 5);
renderPreset.PreviewImageFileName = "";
3, 3, 3);
renderPreset.RayTracingEnabled = false;
new MentalRayRenderSettingsTraitsIntegerRangeParameter(
-2, -1);
new MentalRayRenderSettingsTraitsFloatParameter(
(float)0.1, (float)0.1, (float)0.1, (float)0.1);
new MentalRayRenderSettingsTraitsSamplingParameter(
Filter.Box, 1.0, 1.0);
renderPreset.ShadowMapsEnabled = false;
renderPreset.ShadowMode = ShadowMode.Simple;
ShadowSamplingMultiplier.SamplingMultiplierZero;
renderPreset.ShadowsEnabled = true;
renderPreset.TextureSampling = false;
renderPreset.TileOrder = TileOrder.Hilbert;
renderPreset.TileSize = 32;
switch (name.ToUpper())
// Assigns the values to match the Draft render preset
case "DRAFT":
"The lowest rendering quality which entails no raytracing, " +
"no texture filtering and force 2-sided is inactive.";
renderPreset.Name = "Draft";
break;
case "LOW":
"Rendering quality is improved over Draft. " +
"Low anti-aliasing and a raytracing depth of 3 " +
"reflection/refraction are processed.";
renderPreset.Name = "Low";
renderPreset.RayTracingEnabled = true;
-1, 0);
Filter.Triangle, 2.0, 2.0);
ShadowSamplingMultiplier.SamplingMultiplierOneFourth;
break;
case "MEDIUM":
renderPreset.BackFacesEnabled = true;
"Rendering quality is improved over Low to include " +
"texture filtering and force 2-sided is active. " +
"Moderate anti-aliasing and a raytracing depth of " +
"5 reflections/refractions are processed.";
renderPreset.FGRayCount = 200;
FinalGatheringMode.FinalGatherAuto;
renderPreset.GIPhotonsPerLight = 10000;
renderPreset.Name = "Medium";
5, 5, 5);
0, 1);
(float)0.05, (float)0.05, (float)0.05, (float)0.05);
Filter.Gauss, 3.0, 3.0);
ShadowSamplingMultiplier.SamplingMultiplierOneHalf;
renderPreset.TextureSampling = true;
break;
case "HIGH":
"Rendering quality is improved over Medium. " +
"High anti-aliasing and a raytracing depth of 7 " +
"reflections/refractions are processed.";
renderPreset.FGRayCount = 500;
renderPreset.Name = "High";
7, 7, 7);
0, 2);
Filter.Mitchell, 4.0, 4.0);
ShadowSamplingMultiplier.SamplingMultiplierOne;
break;
case "PRESENTATION":
"Rendering quality is improved over High. " +
"Very high anti-aliasing and a raytracing depth of 9 " +
renderPreset.FGRayCount = 1000;
renderPreset.Name = "Presentation";
9, 9, 9);
1, 2);
Filter.Lanczos, 4.0, 4.0);
break;
父主题: |
GMT+8, 2026-10-27 05:46
