创建纸张空间视口 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 827| 评论: 0|原作者: admin|来自: AutoCAD
创建纸张空间视口 (.NET)
图纸空间视口是通过创建 Viewport 对象的实例并将其添加到除 Model 之外的布局使用的块引用来创建的。Viewport 对象的构造函数不接受任何用于创建新视口对象的参数。创建 Viewport 对象的实例后,可以使用 和 属性定义其位置。CenterPointWidthHeight
创建 Viewport 对象后,可以设置视图本身的属性,例如查看方向(属性)、透视视图的镜头长度(属性)和网格显示(属性)。您还可以控制视口本身的属性,例如图层 ( 属性)、线型 ( 属性) 和线型缩放 ( 属性)。ViewDirectionLensLengthGridOnLayerLinetypeLinetypeScale
创建并启用浮动视口
本示例将图纸空间设置为活动状态,创建浮动视口,定义视口的视图,并启用视口。
VB.NET
Imports System.Runtime.InteropServices
<DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, _
 EntryPoint:="?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")> _
Public Shared Function acedSetCurrentVPort(ByVal AcDbVport As IntPtr) As IntPtr
End Function
<CommandMethod("CreateFloatingViewport")> _
Public Sub CreateFloatingViewport()
    '' Get the current document and database, and start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
        '' Open the Block table record Paper space for write
        acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.PaperSpace), _
                                        OpenMode.ForWrite)
        '' Switch to the previous Paper space layout
        Application.SetSystemVariable("TILEMODE", 0)
        acDoc.Editor.SwitchToPaperSpace()
        '' Create a Viewport
        Using acVport As Viewport = New Viewport()
            acVport.CenterPoint = New Point3d(3.25, 3, 0)
            acVport.Width = 6
            acVport.Height = 5
            acBlkTblRec.AppendEntity(acVport)
            acTrans.AddNewlyCreatedDBObject(acVport, True)
            '' Change the view direction
            acVport.ViewDirection = New Vector3d(1, 1, 1)
            '' Enable the viewport
            acVport.On = True
            '' Activate model space in the viewport
            acDoc.Editor.SwitchToModelSpace()
            '' Set the new viewport current via an imported ObjectARX function
            acedSetCurrentVPort(acVport.UnmanagedObject)
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
using System.Runtime.InteropServices;
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl,
 EntryPoint = "?acedSetCurrentVPort@@YA?AW4ErrorStatus@Acad@@PBVAcDbViewport@@@Z")]
extern static private int acedSetCurrentVPort(IntPtr AcDbVport);
[CommandMethod("CreateFloatingViewport")]
public static void CreateFloatingViewport()
    // Get the current document and database, and start a transaction
        BlockTable acBlkTbl;
        // Open the Block table record Paper space for write
        BlockTableRecord acBlkTblRec;
        acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace],
        // Switch to the previous Paper space layout
        Application.SetSystemVariable("TILEMODE", 0);
        acDoc.Editor.SwitchToPaperSpace();
        // Create a Viewport
        using (Viewport acVport = new Viewport())
            acVport.CenterPoint = new Point3d(3.25, 3, 0);
            acVport.Width = 6;
            acVport.Height = 5;
            acBlkTblRec.AppendEntity(acVport);
            acTrans.AddNewlyCreatedDBObject(acVport, true);
            // Change the view direction
            acVport.ViewDirection = new Vector3d(1, 1, 1);
            // Enable the viewport
            acVport.On = true;
            // Activate model space in the viewport
            acDoc.Editor.SwitchToModelSpace();
            // Set the new viewport current via an imported ObjectARX function
            acedSetCurrentVPort(acVport.UnmanagedObject);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Set the active space to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Create the paperspace viewport
    Dim newVport As AcadPViewport
    Dim center(0 To 2) As Double
    center(0) = 3.25
    center(1) = 3
    center(2) = 0
    Set newVport = ThisDrawing.PaperSpace. _
                                    AddPViewport(center, 6, 5)
    ' Change the view direction for the viewport
    Dim viewDir(0 To 2) As Double
    viewDir(0) = 1
    viewDir(1) = 1
    viewDir(2) = 1
    newVport.direction = viewDir
    newVport.Display True
    ' Switch to model space
    ThisDrawing.MSpace = True
    ' Set newVport current
    ' (not always necessary but a good idea)
    ThisDrawing.ActivePViewport = newVport
注意:若要设置或修改视图的各个方面(视图方向、镜头长度等),必须将 Viewport 对象的属性设置为 ,并且在设置视口当前之前,必须将该属性设置为 。OnFALSEOnTRUE
创建四个浮动视口
此示例以“创建和启用浮动视口”中的示例为例,通过创建四个浮动视口并将每个视口的视图分别设置为顶部、前视图、右侧视图和等距视图来继续执行此示例。每个视口的比例设置为 1:2。为确保在这些视口中可以看到某些内容,您可能希望在尝试此示例之前在模型空间中创建一个 3D 实体球体。
VB.NET
End Function
<CommandMethod("FourFloatingViewports")> _
Public Sub FourFloatingViewports()
                                   OpenMode.ForRead)
                                      OpenMode.ForWrite)
      Dim acPt3dCol As Point3dCollection = New Point3dCollection()
      acPt3dCol.Add(New Point3d(2.5, 5.5, 0))
      acPt3dCol.Add(New Point3d(2.5, 2.5, 0))
      acPt3dCol.Add(New Point3d(5.5, 5.5, 0))
      acPt3dCol.Add(New Point3d(5.5, 2.5, 0))
      Dim acVec3dCol As Vector3dCollection = New Vector3dCollection()
      acVec3dCol.Add(New Vector3d(0, 0, 1))
      acVec3dCol.Add(New Vector3d(0, 1, 0))
      acVec3dCol.Add(New Vector3d(1, 0, 0))
      acVec3dCol.Add(New Vector3d(1, 1, 1))
      Dim dWidth As Double = 2.5
      Dim dHeight As Double = 2.5
      Dim acVportLast As Viewport = Nothing
      Dim nCnt As Integer = 0
      For Each acPt3d As Point3d In acPt3dCol
              acVport.CenterPoint = acPt3d
              acVport.Width = dWidth
              acVport.Height = dHeight
              acVport.ViewDirection = acVec3dCol(nCnt)
              acVport.On = True
              '' Record the last viewport created
              acVportLast = acVport
              '' Increment the counter by 1
              nCnt = nCnt + 1
          End Using
      Next
      If acVportLast <> Nothing Then
          acedSetCurrentVPort(acVportLast.UnmanagedObject)
      End If
      acTrans.Commit()
  End Using
C#
[CommandMethod("FourFloatingViewports")]
public static void FourFloatingViewports()
      Point3dCollection acPt3dCol = new Point3dCollection();
      acPt3dCol.Add(new Point3d(2.5, 5.5, 0));
      acPt3dCol.Add(new Point3d(2.5, 2.5, 0));
      acPt3dCol.Add(new Point3d(5.5, 5.5, 0));
      acPt3dCol.Add(new Point3d(5.5, 2.5, 0));
      Vector3dCollection acVec3dCol = new Vector3dCollection();
      acVec3dCol.Add(new Vector3d(0, 0, 1));
      acVec3dCol.Add(new Vector3d(0, 1, 0));
      acVec3dCol.Add(new Vector3d(1, 0, 0));
      acVec3dCol.Add(new Vector3d(1, 1, 1));
      double dWidth = 2.5;
      double dHeight = 2.5;
      Viewport acVportLast = null;
      int nCnt = 0;
      foreach (Point3d acPt3d in acPt3dCol)
              acVport.CenterPoint = acPt3d;
              acVport.Width = dWidth;
              acVport.Height = dHeight;
              acVport.ViewDirection = acVec3dCol[nCnt];
              acVport.On = true;
              // Record the last viewport created
              acVportLast = acVport;
              // Increment the counter by 1
              nCnt = nCnt + 1;
      if (acVportLast != null)
          acedSetCurrentVPort(acVportLast.UnmanagedObject);
      acTrans.Commit();
VBA/ActiveX 代码参考
    Dim topVport, frontVport As AcadPViewport
    Dim rightVport, isoVport As AcadPViewport
    Dim pt(0 To 2) As Double
    ' Take the existing PViewport and make it the topVport
    pt(0) = 2.5: pt(1) = 5.5: pt(2) = 0
    Set topVport = ThisDrawing.ActivePViewport
    ' No need to set Direction for top view
    topVport.center = pt
    topVport.width = 2.5
    topVport.height = 2.5
    topVport.Display True
    topVport.StandardScale = acVp1_2
    ' Create and setup frontVport
    pt(0) = 2.5: pt(1) = 2.5: pt(2) = 0
    Set frontVport = ThisDrawing.PaperSpace. _
                                      AddPViewport(pt, 2.5, 2.5)
    viewDir(0) = 0: viewDir(1) = 1: viewDir(2) = 0
    frontVport.direction = viewDir
    frontVport.Display acOn
    frontVport.StandardScale = acVp1_2
    ' Create and setup rightVport
    pt(0) = 5.5: pt(1) = 5.5: pt(2) = 0
    Set rightVport = ThisDrawing.PaperSpace. _
    viewDir(0) = 1: viewDir(1) = 0: viewDir(2) = 0
    rightVport.direction = viewDir
    rightVport.Display acOn
    rightVport.StandardScale = acVp1_2
    ' Create and set up isoVport
    pt(0) = 5.5: pt(1) = 2.5: pt(2) = 0
    Set isoVport = ThisDrawing.PaperSpace. _
    viewDir(0) = 1: viewDir(1) = 1: viewDir(2) = 1
    isoVport.direction = viewDir
    isoVport.Display acOn
    isoVport.StandardScale = acVp1_2
    ThisDrawing.ActivePViewport = isoVport
    ' Finish: Perform a regen in all viewports
    ThisDrawing.Regen True
创建非矩形视口
本示例创建一个矩形视口,然后使用一个圆作为剪裁边界。
VB.NET
End Function
<CommandMethod("CreateNonRectangularFloatingViewport")> _
Public Sub CreateNonRectangularFloatingViewport()
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a rectangular viewport to change to a non-rectangular viewport
            acVport.CenterPoint = New Point3d(9, 6.5, 0)
            acVport.Width = 2.5
            acVport.Height = 2.5
            '' Set the scale to 1" = 8'
            acVport.CustomScale = 96
            '' Create a circle
            Using acCirc As Circle = New Circle()
                acCirc.Center = acVport.CenterPoint
                acCirc.Radius = 1.25
                acBlkTblRec.AppendEntity(acCirc)
                acTrans.AddNewlyCreatedDBObject(acCirc, True)
                '' Clip the viewport using the circle
                acVport.NonRectClipEntityId = acCirc.ObjectId
                acVport.NonRectClipOn = True
            End Using
            acVport.ViewDirection = New Vector3d(0, 0, 1)
            acVport.On = True
        End Using
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateNonRectangularFloatingViewport")]
public static void CreateNonRectangularFloatingViewport()
            acVport.CenterPoint = new Point3d(9, 6.5, 0);
            acVport.Width = 2.5;
            acVport.Height = 2.5;
            // Set the scale to 1" = 8'
            acVport.CustomScale = 96;
            // Create a circle
            using (Circle acCirc = new Circle())
                acCirc.Center = acVport.CenterPoint;
                acCirc.Radius = 1.25;
                acBlkTblRec.AppendEntity(acCirc);
                acTrans.AddNewlyCreatedDBObject(acCirc, true);
                // Clip the viewport using the circle
                acVport.NonRectClipEntityId = acCirc.ObjectId;
                acVport.NonRectClipOn = true;
            acVport.ViewDirection = new Vector3d(0, 0, 1);
            acVport.On = true;
        acTrans.Commit();
  1. 视口 (.NET)
GMT+8, 2026-10-27 01:24
