纸张大小和单位 (.NET)
布局的纸张尺寸选择取决于为输出配置的绘图仪或设备。每个绘图仪或设备都有一个可用输出尺寸的标准列表,可以使用对象的方法获得这些输出尺寸。对象的方法可用于返回“打印”(Plot) 或“页面设置”(Page Setup) 对话框中显示的输出大小。可以使用该属性查询分配给布局的纸张大小。GetCanonicalMediaNameListPlotSettingsValidatorGetLocaleMediaNamePlotSettingsValidatorCanonicalMediaName 还可以使用该属性查询布局的单位。此属性返回枚举定义的三个值之一:、 或 。如果绘图仪配置为栅格输出,则输出大小以像素为单位返回。PlotPaperUnitsPlotPaperUnitInchesMillimetersPixels 列出输出设备的可用纸张尺寸本示例列出了 DWF6 ePlot.pc3 输出设备的纸张尺寸。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.PlottingServices
' Lists the available local media names for a specified plot configuration (PC3) file
<CommandMethod("PlotterLocalMediaNameList")> _
Public Shared Sub PlotterLocalMediaNameList()
' Get the current document and database, and start a transaction
Using plSet As PlotSettings = New PlotSettings(True)
Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
' Set the Plotter and page size
acPlSetVdr.SetPlotConfigurationName(plSet, "DWF6 ePlot.pc3", _
"ANSI_A_(8.50_x_11.00_Inches)")
acDoc.Editor.WriteMessage(vbLf & "Canonical and Local media names: ")
Dim cnt As Integer = 0
For Each mediaName As String In acPlSetVdr.GetCanonicalMediaNameList(plSet)
' Output the names of the available media for the specified device
acDoc.Editor.WriteMessage(vbLf & " " & mediaName & " | " & _
acPlSetVdr.GetLocaleMediaName(plSet, cnt))
cnt = cnt + 1
Next
End Using
using Autodesk.AutoCAD.PlottingServices;
// Lists the available local media names for a specified plot configuration (PC3) file
[CommandMethod("PlotterLocalMediaNameList")]
public static void PlotterLocalMediaNameList()
// Get the current document and database, and start a transaction
using(PlotSettings plSet = new PlotSettings(true))
PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
// Set the Plotter and page size
"ANSI_A_(8.50_x_11.00_Inches)");
acDoc.Editor.WriteMessage("\nCanonical and Local media names: ");
int cnt = 0;
foreach (string mediaName in acPlSetVdr.GetCanonicalMediaNameList(plSet))
// Output the names of the available media for the specified device
acDoc.Editor.WriteMessage("\n " + mediaName + " | " +
acPlSetVdr.GetLocaleMediaName(plSet, cnt));
cnt = cnt + 1;
相关概念父主题: |
GMT+8, 2026-10-27 05:30
