指定 3D 坐标 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 932| 评论: 0|原作者: admin|来自: AutoCAD
指定 3D 坐标 (.NET)
输入 3D 世界坐标系 (WCS) 坐标类似于输入 2D WCS 坐标。除了指定 X 和 Y 值外,还可以指定 Z 值。2D 坐标由对象表示,而使用对象表示 3D 坐标。AutoCAD .NET API 中的大多数属性和方法都使用 3D 坐标。Point2dPoint3d
定义和查询 2D 和 3D 折线的坐标
本示例创建两条折线,每条折线都有三个坐标。第一条折线是 2D 折线,第二条折线是 3D 折线。请注意,在创建 3D 折线时,包含顶点的数组的长度将展开以包括 Z 坐标。该示例最后查询折线的坐标并在消息框中显示坐标。
VB.NET
<CommandMethod("Polyline_2D_3D")> _
Public Sub Polyline_2D_3D()
    '' Get the current document and database, and start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a polyline with two segments (3 points)
        Using acPoly As Polyline = New Polyline()
            acPoly.AddVertexAt(0, New Point2d(1, 1), 0, 0, 0)
            acPoly.AddVertexAt(1, New Point2d(1, 2), 0, 0, 0)
            acPoly.AddVertexAt(2, New Point2d(2, 2), 0, 0, 0)
            acPoly.ColorIndex = 1
            acBlkTblRec.AppendEntity(acPoly)
            acTrans.AddNewlyCreatedDBObject(acPoly, True)
            '' Create a 3D polyline with two segments (3 points)
            Using acPoly3d As Polyline3d = New Polyline3d()
                acPoly3d.ColorIndex = 5
                acBlkTblRec.AppendEntity(acPoly3d)
                acTrans.AddNewlyCreatedDBObject(acPoly3d, True)
                '' Before adding vertexes, the polyline must be in the drawing
                Dim acPts3dPoly As Point3dCollection = New Point3dCollection()
                acPts3dPoly.Add(New Point3d(1, 1, 0))
                acPts3dPoly.Add(New Point3d(2, 1, 0))
                acPts3dPoly.Add(New Point3d(2, 2, 0))
                For Each acPt3d As Point3d In acPts3dPoly
                    Using acPolVer3d As PolylineVertex3d = New PolylineVertex3d(acPt3d)
                        acPoly3d.AppendVertex(acPolVer3d)
                        acTrans.AddNewlyCreatedDBObject(acPolVer3d, True)
                    End Using
                Next
                '' Get the coordinates of the lightweight polyline
                Dim acPts2d As Point2dCollection = New Point2dCollection()
                For nCnt As Integer = 0 To acPoly.NumberOfVertices - 1
                    acPts2d.Add(acPoly.GetPoint2dAt(nCnt))
                Next
                '' Get the coordinates of the 3D polyline
                Dim acPts3d As Point3dCollection = New Point3dCollection()
                For Each acObjIdVert As ObjectId In acPoly3d
                    Dim acPolVer3d As PolylineVertex3d
                    acPolVer3d = acTrans.GetObject(acObjIdVert, _
                                                   OpenMode.ForRead)
                    acPts3d.Add(acPolVer3d.Position)
                Next
                '' Display the Coordinates
                Application.ShowAlertDialog("2D polyline (red): " & vbLf & _
                                            acPts2d(0).ToString() & vbLf & _
                                            acPts2d(1).ToString() & vbLf & _
                                            acPts2d(2).ToString())
                Application.ShowAlertDialog("3D polyline (blue): " & vbLf & _
                                            acPts3d(0).ToString() & vbLf & _
                                            acPts3d(1).ToString() & vbLf & _
                                            acPts3d(2).ToString())
            End Using
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("Polyline_2D_3D")]
public static void Polyline_2D_3D()
    // Get the current document and database, and start a transaction
        // Open the Block table record for read
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a polyline with two segments (3 points)
        using (Polyline acPoly = new Polyline())
            acPoly.AddVertexAt(0, new Point2d(1, 1), 0, 0, 0);
            acPoly.AddVertexAt(1, new Point2d(1, 2), 0, 0, 0);
            acPoly.AddVertexAt(2, new Point2d(2, 2), 0, 0, 0);
            acPoly.ColorIndex = 1;
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
            // Create a 3D polyline with two segments (3 points)
            using (Polyline3d acPoly3d = new Polyline3d())
                acPoly3d.ColorIndex = 5;
                acBlkTblRec.AppendEntity(acPoly3d);
                acTrans.AddNewlyCreatedDBObject(acPoly3d, true);
                // Before adding vertexes, the polyline must be in the drawing
                Point3dCollection acPts3dPoly = new Point3dCollection();
                acPts3dPoly.Add(new Point3d(1, 1, 0));
                acPts3dPoly.Add(new Point3d(2, 1, 0));
                acPts3dPoly.Add(new Point3d(2, 2, 0));
                foreach (Point3d acPt3d in acPts3dPoly)
                    using (PolylineVertex3d acPolVer3d = new PolylineVertex3d(acPt3d))
                        acPoly3d.AppendVertex(acPolVer3d);
                        acTrans.AddNewlyCreatedDBObject(acPolVer3d, true);
                // Get the coordinates of the lightweight polyline
                Point2dCollection acPts2d = new Point2dCollection();
                for (int nCnt = 0; nCnt < acPoly.NumberOfVertices; nCnt++)
                    acPts2d.Add(acPoly.GetPoint2dAt(nCnt));
                // Get the coordinates of the 3D polyline
                Point3dCollection acPts3d = new Point3dCollection();
                foreach (ObjectId acObjIdVert in acPoly3d)
                    PolylineVertex3d acPolVer3d;
                                                    OpenMode.ForRead) as PolylineVertex3d;
                    acPts3d.Add(acPolVer3d.Position);
                // Display the Coordinates
                Application.ShowAlertDialog("2D polyline (red): \n" +
                                            acPts2d[0].ToString() + "\n" +
                                            acPts2d[1].ToString() + "\n" +
                                            acPts2d[2].ToString());
                Application.ShowAlertDialog("3D polyline (blue): \n" +
                                            acPts3d[0].ToString() + "\n" +
                                            acPts3d[1].ToString() + "\n" +
                                            acPts3d[2].ToString());
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim pline2DObj As AcadLWPolyline
    Dim pline3DObj As AcadPolyline
    Dim points2D(0 To 5) As Double
    Dim points3D(0 To 8) As Double
    ' Define three 2D polyline points
    points2D(0) = 1: points2D(1) = 1
    points2D(2) = 1: points2D(3) = 2
    points2D(4) = 2: points2D(5) = 2
    ' Define three 3D polyline points
    points3D(0) = 1: points3D(1) = 1: points3D(2) = 0
    points3D(3) = 2: points3D(4) = 1: points3D(5) = 0
    points3D(6) = 2: points3D(7) = 2: points3D(8) = 0
    ' Create the 2D light weight Polyline
    Set pline2DObj = ThisDrawing.ModelSpace. _
                                      AddLightWeightPolyline(points2D)
    pline2DObj.Color = acRed
    pline2DObj.Update
    ' Create the 3D polyline
    Set pline3DObj = ThisDrawing.ModelSpace. _
                                      AddPolyline(points3D)
    pline3DObj.Color = acBlue
    pline3DObj.Update
    ' Query the coordinates of the polylines
    Dim get2Dpts As Variant
    Dim get3Dpts As Variant
    get2Dpts = pline2DObj.Coordinates
    get3Dpts = pline3DObj.Coordinates
    ' Display the coordinates
    MsgBox ("2D polyline (red): " & vbCrLf & "(" & _
            get2Dpts(0) & ", " & get2Dpts(1) & ")" & vbCrLf & "(" & _
            get2Dpts(2) & ", " & get2Dpts(3) & ")"& vbCrLf & "(" & _
            get2Dpts(4) & ", " & get2Dpts(5) & ")")
    MsgBox ("3D polyline (blue): " & vbCrLf & "(" & _
            get3Dpts(0) & ", " & get3Dpts(1) & ", " & _
            get3Dpts(2) & ")" & vbCrLf & "(" & _
            get3Dpts(3) & ", " & get3Dpts(4) & ", " & _
            get3Dpts(5) & ")" & vbCrLf & "(" & _
            get3Dpts(6) & ", " & get3Dpts(7) & ", " & _
            get3Dpts(8) & ")")
GMT+8, 2026-10-27 05:46
