重写维度文本 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 797| 评论: 0|原作者: admin|来自: AutoCAD
重写维度文本 (.NET)
可以使用该属性替换显示的维度值。使用此属性,可以完全替换维度的显示值,也可以将文本追加到该值。要在覆盖维度文本中表示测量值,请在文本中使用字符串“<>”。DimensionText
修改尺寸文本
本示例将一些文本追加到值中,以便同时显示字符串和维度值。
VB.NET
<CommandMethod("OverrideDimensionText")> _
Public Sub OverrideDimensionText()
    '' Get the current database
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create the aligned dimension
        Using acAliDim As AlignedDimension = New AlignedDimension()
            acAliDim.XLine1Point = New Point3d(5, 3, 0)
            acAliDim.XLine2Point = New Point3d(10, 3, 0)
            acAliDim.DimLinePoint = New Point3d(7.5, 5, 0)
            acAliDim.DimensionStyle = acCurDb.Dimstyle
            '' Override the dimension text
            acAliDim.DimensionText = "The value is <>"
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acAliDim)
            acTrans.AddNewlyCreatedDBObject(acAliDim, True)
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("OverrideDimensionText")]
public static void OverrideDimensionText()
    // Get the current database
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create the aligned dimension
        using (AlignedDimension acAliDim = new AlignedDimension())
            acAliDim.XLine1Point = new Point3d(5, 3, 0);
            acAliDim.XLine2Point = new Point3d(10, 3, 0);
            acAliDim.DimLinePoint = new Point3d(7.5, 5, 0);
            acAliDim.DimensionStyle = acCurDb.Dimstyle;
            // Override the dimension text
            acAliDim.DimensionText = "The value is <>";
            // Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acAliDim);
            acTrans.AddNewlyCreatedDBObject(acAliDim, true);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    ' Define the dimension
    point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
    location(0) = 7.5: location(1) = 5#: location(2) = 0#
    Set dimObj = ThisDrawing.ModelSpace. _
                     AddDimAligned(point1, point2, location)
    ' Change the text string for the dimension
    dimObj.TextOverride = "The value is <>"
    dimObj.Update
GMT+8, 2026-11-15 11:59
