分配字体 (.NET)
字体定义构成每个字符集的文本字符的形状。一种字体可以由多种样式使用。使用该属性设置文本样式的字体文件。可以将 TrueType 或 AutoCAD 编译的 SHX 字体指定为文本样式。FileName 设置文本字体下面的示例使用活动文本样式的属性获取当前字体值,然后将字体的字体更改为“PlayBill”。若要查看更改字体的效果,请在运行示例之前向当前图形添加一些多行或单行文本。请注意,如果您的系统上没有 PlayBill 字体,则需要替换您拥有的字体才能使此示例正常工作。Font VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("UpdateTextFont")> _
Public Sub UpdateTextFont()
'' Start a transaction
'' Open the current text style for write
Dim acTextStyleTblRec As TextStyleTableRecord
acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, _
OpenMode.ForWrite)
'' Get the current font settings
Dim acFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
acFont = acTextStyleTblRec.Font
'' Update the text style's typeface with "PlayBill"
Dim acNewFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
acNewFont = New _
Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("PlayBill", _
acFont.Bold, _
acFont.Italic, _
acFont.CharacterSet, _
acFont.PitchAndFamily)
acTextStyleTblRec.Font = acNewFont
acDoc.Editor.Regen()
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("UpdateTextFont")]
public static void UpdateTextFont()
// Start a transaction
// Open the current text style for write
TextStyleTableRecord acTextStyleTblRec;
OpenMode.ForWrite) as TextStyleTableRecord;
// Get the current font settings
Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acFont;
acFont = acTextStyleTblRec.Font;
// Update the text style's typeface with "PlayBill"
Autodesk.AutoCAD.GraphicsInterface.FontDescriptor acNewFont;
acNewFont = new
acFont.Bold,
acFont.Italic,
acFont.PitchAndFamily);
acTextStyleTblRec.Font = acNewFont;
acDoc.Editor.Regen();
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub UpdateTextFont()
MsgBox ("Look at the text now...")
Dim typeFace As String
Dim SavetypeFace As String
Dim Bold As Boolean
Dim Italic As Boolean
Dim charSet As Long
Dim PitchandFamily As Long
' Get the current settings to fill in the
' default values for the SetFont method
ThisDrawing.ActiveTextStyle.GetFont typeFace, _
Bold, Italic, charSet, PitchandFamily
' Change the typeface for the font
SavetypeFace = typeFace
typeFace = "PlayBill"
ThisDrawing.ActiveTextStyle.SetFont typeFace, _
ThisDrawing.Regen acActiveViewport
相关概念父主题: |
GMT+8, 2026-11-15 13:38
