创建单行文本 (.NET)
使用单行文本时,每行文本都是一个不同的对象。要创建单行文本对象,请创建对象的实例,然后将其添加到表示模型或图纸空间的块表记录中。创建对象的新实例时,不会向构造函数传递任何参数。DBTextDBText 创建行文本下面的示例在模型空间的坐标 (2, 2, 0) 处创建一个高度为 0.5 且文本字符串为“Hello, World”的单行文本对象。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateText")> _
Public Sub CreateText()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a single-line text object
Using acText As DBText = New DBText()
acText.Position = New Point3d(2, 2, 0)
acText.Height = 0.5
acText.TextString = "Hello, World."
acBlkTblRec.AppendEntity(acText)
acTrans.AddNewlyCreatedDBObject(acText, True)
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateText")]
public static void CreateText()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a single-line text object
using (DBText acText = new DBText())
acText.Position = new Point3d(2, 2, 0);
acText.Height = 0.5;
acText.TextString = "Hello, World.";
acBlkTblRec.AppendEntity(acText);
acTrans.AddNewlyCreatedDBObject(acText, true);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateText()
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Create the text object
textString = "Hello, World."
insertionPoint(0) = 2
insertionPoint(1) = 2
insertionPoint(2) = 0
height = 0.5
Set textObj = ThisDrawing.ModelSpace. _
AddText(textString, insertionPoint, height)
textObj.Update
相关概念父主题: |
GMT+8, 2026-10-27 04:30
