使颜色流通过数据库 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 795| 评论: 0|原作者: admin|来自: AutoCAD
使颜色流通过数据库 (.NET)
本示例使用属性设置通过对象的颜色电流。DatabaseCecolor
VB.NET
Imports Autodesk.AutoCAD.Colors
<CommandMethod("SetColorCurrent")> _
Public Sub SetColorCurrent()
    '' Get the current document
    '' Set the current color
    acDoc.Database.Cecolor = Color.FromColorIndex(ColorMethod.ByLayer, 256)
C#
using Autodesk.AutoCAD.Colors;
[CommandMethod("SetColorCurrent")]
public static void SetColorCurrent()
    // Get the current document
    // Set the current color
    acDoc.Database.Cecolor = Color.FromColorIndex(ColorMethod.ByLayer, 256);
GMT+8, 2026-10-27 04:55
