为对象分配颜色值 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 771| 评论: 0|原作者: admin|来自: AutoCAD
为对象分配颜色值 (.NET)
下面的示例创建四个圆圈,并使用四种不同的方法为每个圆圈分配不同的颜色。
VB.NET
Imports Autodesk.AutoCAD.Colors
<CommandMethod("SetObjectColor")> _
Public Sub SetObjectColor()
    '' Start a transaction
        '' Define an array of colors for the layers
        Dim acColors(2) As Color
        acColors(0) = Color.FromColorIndex(ColorMethod.ByAci, 1)
        acColors(1) = Color.FromRgb(23, 54, 232)
        acColors(2) = Color.FromNames("PANTONE Yellow 0131 C", _
                                      "PANTONE(R) pastel coated")
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle object and assign it the ACI value of 4
        Dim acPt As Point3d = New Point3d(0, 3, 0)
        Using acCirc As Circle = New Circle()
            acCirc.Center = acPt
            acCirc.Radius = 1
            acCirc.ColorIndex = 4
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
            Dim nCnt As Integer = 0
            While (nCnt < 3)
                '' Create a copy of the circle
                Dim acCircCopy As Circle
                acCircCopy = acCirc.Clone()
                '' Shift the copy along the Y-axis
                acPt = New Point3d(acPt.X, acPt.Y + 3, acPt.Z)
                acCircCopy.Center = acPt
                '' Assign the new color to the circle
                acCircCopy.Color = acColors(nCnt)
                acBlkTblRec.AppendEntity(acCircCopy)
                acTrans.AddNewlyCreatedDBObject(acCircCopy, True)
                nCnt = nCnt + 1
            End While
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
using Autodesk.AutoCAD.Colors;
[CommandMethod("SetObjectColor")]
public static void SetObjectColor()
    // Start a transaction
        // Define an array of colors for the layers
        Color[] acColors = new Color[3];
        acColors[0] = Color.FromColorIndex(ColorMethod.ByAci, 1);
        acColors[1] = Color.FromRgb(23, 54, 232);
        acColors[2] = Color.FromNames("PANTONE Yellow 0131 C",
                                        "PANTONE(R) pastel coated");
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle object and assign it the ACI value of 4
        Point3d acPt = new Point3d(0, 3, 0);
        using (Circle acCirc = new Circle())
            acCirc.Center = acPt;
            acCirc.Radius = 1;
            acCirc.ColorIndex = 4;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
            int nCnt = 0;
            while (nCnt < 3)
                // Create a copy of the circle
                Circle acCircCopy;
                acCircCopy = acCirc.Clone() as Circle;
                // Shift the copy along the Y-axis
                acPt = new Point3d(acPt.X, acPt.Y + 3, acPt.Z);
                acCircCopy.Center = acPt;
                // Assign the new color to the circle
                acCircCopy.Color = acColors[nCnt];
                acBlkTblRec.AppendEntity(acCircCopy);
                acTrans.AddNewlyCreatedDBObject(acCircCopy, true);
                nCnt = nCnt + 1;
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim colorObj(2) As New AcadAcCmColor
    colorObj(0).ColorMethod = acColorMethodByACI
    colorObj(0).ColorIndex = acRed
    Call colorObj(1).SetRGB(23, 54, 232)
    Call colorObj(2).SetColorBookColor("PANTONE(R) pastel coated", _
                                       "PANTONE Yellow 0131 C")
    ' Define the center point of the circle
    Dim centerPt(0 To 2) As Double
    centerPt(0) = 0: centerPt(1) = 3: centerPt(2) = 0
    ' Create a new circle and assign it the ACI value of 4
    Dim circleObj As AcadCircle
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPt, 1)
    circleObj.color = acCyan
    Dim nCnt As Integer
    ' Create 3 more circles
    While (nCnt < 3)
       Dim circleObjCopy As AcadCircle
       Set circleObjCopy = circleObj.Copy
       centerPt(1) = centerPt(1) + 3
       circleObjCopy.Center = centerPt
       circleObjCopy.TrueColor = colorObj(nCnt)
       nCnt = nCnt + 1
    Wend
GMT+8, 2026-11-15 12:28
