将线型分配给图层 (.NET)
定义图层时,线型提供了另一种传达视觉信息的方式。线型是虚线、圆点和空格的重复图案,可用于区分一行和另一行的用途。 线型名称和定义描述特定的破折号-点序列、破折号和空格的相对长度,以及任何包含的文本或形状的特征。 使用 Linetype 属性可将线型分配给图层。此属性采用线型的名称作为输入。 注意:必须先在图形中定义线型,然后才能将线型指定给图层。
设置图层的线型以下示例创建一个名为“ABC”的新图层,并为其分配“Center”线型。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SetLayerLinetype")> _
Public Sub SetLayerLinetype()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerName As String = "ABC"
If acLyrTbl.Has(sLayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' Assign the layer a name
acLyrTblRec.Name = sLayerName
Dim acLinTbl As LinetypeTable
acLinTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _
OpenMode.ForRead)
If acLinTbl.Has("Center") = True Then
'' Set the linetype for the layer
acLyrTblRec.LinetypeObjectId = acLinTbl("Center")
End If
'' Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
Else
Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
OpenMode.ForRead)
OpenMode.ForRead)
'' Upgrade the Layer Table Record for write
acTrans.GetObject(acLyrTbl(sLayerName), OpenMode.ForWrite)
End If
End If
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("SetLayerLinetype")]
public static void SetLayerLinetype()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerName = "ABC";
if (acLyrTbl.Has(sLayerName) == false)
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
// Assign the layer a name
acLyrTblRec.Name = sLayerName;
LinetypeTable acLinTbl;
OpenMode.ForRead) as LinetypeTable;
if (acLinTbl.Has("Center") == true)
// Set the linetype for the layer
acLyrTblRec.LinetypeObjectId = acLinTbl["Center"];
// Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
else
LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
OpenMode.ForRead) as LayerTableRecord;
// Upgrade the Layer Table Record for write
acTrans.GetObject(acLyrTbl[sLayerName], OpenMode.ForWrite);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub SetLayerLinetype()
On Error Resume Next
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("ABC")
layerObj.Linetype = "Center"
相关概念父主题: |
GMT+8, 2026-10-26 23:55
