冻结和解冻层 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 761| 评论: 0|原作者: admin|来自: AutoCAD
冻结和解冻层 (.NET)
您可以冻结图层以加快显示更改速度、提高对象选择性能并缩短复杂图形的再生时间。AutoCAD 不会在冻结图层上显示、打印或重新生成对象。冻结您不会长时间使用的图层。“解冻”冻结图层时,AutoCAD 将重新生成并显示该图层上的对象。
使用该属性冻结或解冻图层。如果输入值 ,则图层将被冻结。如果输入值 ,则图层将解冻。IsFrozenTRUEFALSE
冻结图层
本示例创建一个名为“ABC”的新图层,然后冻结该图层。
VB.NET
<CommandMethod("FreezeLayer")> _
Public Sub FreezeLayer()
    '' Start a transaction
        '' Open the Layer table for read
        Dim acLyrTbl As LayerTable
        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                     OpenMode.ForRead)
        Dim sLayerName As String = "ABC"
        If acLyrTbl.Has(sLayerName) = False Then
            Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
                '' Assign the layer a name
                acLyrTblRec.Name = sLayerName
                '' Freeze the layer
                acLyrTblRec.IsFrozen = True
                '' Upgrade the Layer table for write
                acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
                '' Append the new layer to the Layer table and the transaction
                acLyrTbl.Add(acLyrTblRec)
                acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
            End Using
        Else
            Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
        OpenMode.ForWrite)
            '' Freeze the layer
        End If
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("FreezeLayer")]
public static void FreezeLayer()
    // Start a transaction
        // Open the Layer table for read
        LayerTable acLyrTbl;
                                        OpenMode.ForRead) as LayerTable;
        string sLayerName = "ABC";
        if (acLyrTbl.Has(sLayerName) == false)
            using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
                // Assign the layer a name
                acLyrTblRec.Name = sLayerName;
                // Freeze the layer
                acLyrTblRec.IsFrozen = true;
                // Upgrade the Layer table for write
                acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
                // Append the new layer to the Layer table and the transaction
                acLyrTbl.Add(acLyrTblRec);
                acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
        else
            LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
                                            OpenMode.ForWrite) as LayerTableRecord;
            // Freeze the layer
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub FreezeLayer()
    ' Create a new layer called "ABC"
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers.Add("ABC")
    ' Freeze layer "ABC"
    layerObj.Freeze = True
GMT+8, 2026-10-27 04:50
