打开和关闭图层 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 653| 评论: 0|原作者: admin|来自: AutoCAD
打开和关闭图层 (.NET)
关闭的图层随图形一起再生,但不显示或打印。通过关闭图层,可以避免每次解冻图层时重新生成图形。当您打开已关闭的图层时,AutoCAD 会重新绘制该图层上的对象。
在对象上使用表示要打开或关闭的图层的属性。如果输入值 ,则图层将关闭。如果输入值 ,则图层处于打开状态。IsOffLayerTableRecordTRUEFALSE
关闭图层
本示例创建一个新图层并将其关闭,然后向该图层添加一个圆圈,使该圆圈不再可见。
VB.NET
<CommandMethod("TurnLayerOff")> _
Public Sub TurnLayerOff()
    '' Start a transaction
        '' Open the Layer table for read
        Dim acLyrTbl As LayerTable
        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                     OpenMode.ForRead)
        Dim sLayerName As String = "ABC"
        If acLyrTbl.Has(sLayerName) = False Then
            Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
                '' Assign the layer a name
                acLyrTblRec.Name = sLayerName
                '' Turn the layer off
                acLyrTblRec.IsOff = True
                '' Upgrade the Layer table for write
                acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
                '' Append the new layer to the Layer table and the transaction
                acLyrTbl.Add(acLyrTblRec)
                acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
            End Using
        Else
            Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
        OpenMode.ForWrite)
        End If
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle object
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 1
            acCirc.Layer = sLayerName
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("TurnLayerOff")]
public static void TurnLayerOff()
    // Start a transaction
        // Open the Layer table for read
        LayerTable acLyrTbl;
                                        OpenMode.ForRead) as LayerTable;
        string sLayerName = "ABC";
        if (acLyrTbl.Has(sLayerName) == false)
            using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
                // Assign the layer a name
                acLyrTblRec.Name = sLayerName;
                // Turn the layer off
                acLyrTblRec.IsOff = true;
                // Upgrade the Layer table for write
                acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
                // Append the new layer to the Layer table and the transaction
                acLyrTbl.Add(acLyrTblRec);
                acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
        else
            LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
                                            OpenMode.ForWrite) as LayerTableRecord;
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle object
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 2, 0);
            acCirc.Radius = 1;
            acCirc.Layer = sLayerName;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub TurnLayerOff()
    ' Create a new layer called "ABC"
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers.Add("ABC")
    ' Turn off layer "ABC"
    layerObj.LayerOn = False
    ' Create a circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2: center(1) = 2: center(2) = 0
    radius = 1
    Set circleObj = ThisDrawing.ModelSpace. _
                                  AddCircle(center, radius)
    ' Assign the circle to the "ABC" layer
    circleObj.Layer = "ABC"
    circleObj.Update
    ThisDrawing.Regen acActiveViewport
GMT+8, 2026-10-28 18:27
