创建和命名图层 (.NET)
您可以创建新图层,并为这些图层指定颜色和线型属性。每个单独的图层都是图层表的一部分。使用该函数创建一个新图层并将其添加到图层表中。Add 您可以在创建图层时为其指定名称。要在创建图层后更改图层的名称,请使用该属性。图层名称最多可以包含 255 个字符,并包含字母、数字和特殊字符美元符号 ($)、连字符 (-) 和下划线 (_)。Name 创建一个新图层,为其指定绿色,然后向图层添加对象下面的代码创建一个新的图层和圆对象。新图层被指定为绿色。将圆圈分配给图层,并且圆圈的颜色会相应更改。 VB.NETImports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Colors
<CommandMethod("CreateAndAssignALayer")> _
Public Sub CreateAndAssignALayer()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerName As String = "Center"
If acLyrTbl.Has(sLayerName) = False Then
Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
'' Assign the layer the ACI color 3 and a name
acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByAci, 3)
acLyrTblRec.Name = sLayerName
'' Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
'' Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec)
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
End Using
End If
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle object
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 1
acCirc.Layer = sLayerName
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
End Using
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
using Autodesk.AutoCAD.Colors;
[CommandMethod("CreateAndAssignALayer")]
public static void CreateAndAssignALayer()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerName = "Center";
if (acLyrTbl.Has(sLayerName) == false)
using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
// Assign the layer the ACI color 3 and a name
acLyrTblRec.Color = Color.FromColorIndex(ColorMethod.ByAci, 3);
acLyrTblRec.Name = sLayerName;
// Upgrade the Layer table for write
acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
// Append the new layer to the Layer table and the transaction
acLyrTbl.Add(acLyrTblRec);
acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle object
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 1;
acCirc.Layer = sLayerName;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateAssignALayer()
' Create a new layer and assign it the color red
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Add("Center")
layerObj.color = acRed
' Create a circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2: center(1) = 2: center(2) = 0
radius = 1
Set circleObj = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
' Place the circle on the Center layer
circleObj.Layer = "Center"
circleObj.Update
相关概念父主题: |
GMT+8, 2026-10-27 01:24
