对图层和线型进行排序 (.NET)
您可以循环访问“图层”(Layers) 和“线型”(Linetypes) 表格,以查找图形中的所有图层和线型。 循环访问“图层”(Layers) 表下面的代码循环访问“层”表,以收集图形中所有层的名称。然后,这些名称将显示在消息框中。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("DisplayLayerNames")> _
Public Sub DisplayLayerNames()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
OpenMode.ForRead)
Dim sLayerNames As String = ""
For Each acObjId As ObjectId In acLyrTbl
Dim acLyrTblRec As LayerTableRecord
acLyrTblRec = acTrans.GetObject(acObjId, _
OpenMode.ForRead)
sLayerNames = sLayerNames & vbLf & acLyrTblRec.Name
Next
Application.ShowAlertDialog("The layers in this drawing are: " & _
sLayerNames)
'' Dispose of the transaction
End Using
[CommandMethod("DisplayLayerNames")]
public static void DisplayLayerNames()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
string sLayerNames = "";
foreach (ObjectId acObjId in acLyrTbl)
LayerTableRecord acLyrTblRec;
OpenMode.ForRead) as LayerTableRecord;
sLayerNames = sLayerNames + "\n" + acLyrTblRec.Name;
Application.ShowAlertDialog("The layers in this drawing are: " +
sLayerNames);
// Dispose of the transaction
VBA/ActiveX 代码参考Sub DisplayLayerNames()
Dim layerNames As String
Dim entry As AcadLayer
layerNames = ""
For Each entry In ThisDrawing.Layers
layerNames = layerNames + entry.Name + vbCrLf
Next
MsgBox "The layers in this drawing are: " + _
vbCrLf + layerNames
相关概念父主题: |
GMT+8, 2026-10-27 05:24
