编辑填充边界 (.NET)
您可以在对象的边界上追加、插入或删除循环。关联填充将更新以匹配对其边界所做的任何更改。非关联填充线不会更新。Hatch 若要编辑填充边界,请使用下列方法之一:
若要查询填充边界,请使用下列方法之一:
将内环追加到填充物本示例创建一个关联填充。然后,它创建一个圆圈,并将该圆圈作为内环附加到舱口。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("EditHatchAppendLoop")> _
Public Sub EditHatchAppendLoop()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create an arc object for the closed boundary to hatch
Using acArc As Arc = New Arc(New Point3d(5, 3, 0), 3, 0, 3.141592)
acBlkTblRec.AppendEntity(acArc)
acTrans.AddNewlyCreatedDBObject(acArc, True)
'' Create an line object for the closed boundary to hatch
Using acLine As Line = New Line(acArc.StartPoint, acArc.EndPoint)
acBlkTblRec.AppendEntity(acLine)
acTrans.AddNewlyCreatedDBObject(acLine, True)
'' Adds the arc and line to an object id collection
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
acObjIdColl.Add(acArc.ObjectId)
acObjIdColl.Add(acLine.ObjectId)
'' Create the hatch object and append it to the block table record
Using acHatch As Hatch = New Hatch()
acBlkTblRec.AppendEntity(acHatch)
acTrans.AddNewlyCreatedDBObject(acHatch, True)
'' Set the properties of the hatch object
'' Associative must be set after the hatch object is appended to the
'' block table record and before AppendLoop
acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
acHatch.Associative = True
acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl)
'' Create a circle object for the inner boundary of the hatch
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(5, 4.5, 0)
acCirc.Radius = 1
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
'' Adds the circle to an object id collection
acObjIdColl.Clear()
acObjIdColl.Add(acCirc.ObjectId)
'' Append the circle as the inner loop of the hatch and evaluate it
acHatch.AppendLoop(HatchLoopTypes.Default, acObjIdColl)
acHatch.EvaluateHatch(True)
End Using
End Using
End Using
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("EditHatchAppendLoop")]
public static void EditHatchAppendLoop()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create an arc object for the closed boundary to hatch
using (Arc acArc = new Arc(new Point3d(5, 3, 0), 3, 0, 3.141592))
acBlkTblRec.AppendEntity(acArc);
acTrans.AddNewlyCreatedDBObject(acArc, true);
// Create an line object for the closed boundary to hatch
using (Line acLine = new Line(acArc.StartPoint, acArc.EndPoint))
acBlkTblRec.AppendEntity(acLine);
acTrans.AddNewlyCreatedDBObject(acLine, true);
// Adds the arc and line to an object id collection
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
acObjIdColl.Add(acArc.ObjectId);
acObjIdColl.Add(acLine.ObjectId);
// Create the hatch object and append it to the block table record
using (Hatch acHatch = new Hatch())
acBlkTblRec.AppendEntity(acHatch);
acTrans.AddNewlyCreatedDBObject(acHatch, true);
// Set the properties of the hatch object
// Associative must be set after the hatch object is appended to the
// block table record and before AppendLoop
acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31");
acHatch.Associative = true;
acHatch.AppendLoop(HatchLoopTypes.Outermost, acObjIdColl);
// Create a circle object for the inner boundary of the hatch
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(5, 4.5, 0);
acCirc.Radius = 1;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Adds the circle to an object id collection
acObjIdColl.Clear();
acObjIdColl.Add(acCirc.ObjectId);
// Append the circle as the inner loop of the hatch and evaluate it
acHatch.AppendLoop(HatchLoopTypes.Default, acObjIdColl);
acHatch.EvaluateHatch(true);
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub EditHatchAppendLoop()
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define and create the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
Set hatchObj = ThisDrawing.ModelSpace. _
AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 3
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace. _
AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace. _
AddLine(outerLoop(0).startPoint, outerLoop(0).endPoint)
' Append the outer loop to the hatch object
hatchObj.AppendOuterLoop (outerLoop)
' Create a circle as the inner loop for the hatch.
Dim innerLoop(0) As AcadEntity
center(0) = 5: center(1) = 4.5: center(2) = 0
radius = 1
Set innerLoop(0) = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
' Append the circle as an inner loop to the hatch
hatchObj.AppendInnerLoop (innerLoop)
' Evaluate and display the hatch
hatchObj.Evaluate
ThisDrawing.Regen True
相关概念父主题: |
GMT+8, 2026-10-27 04:12
