扩展和修剪对象 (.NET)
2024-5-18 16:57| 发布者: admin| 查看: 831| 评论: 0|原作者: admin|来自: AutoCAD
扩展和修剪对象 (.NET)
您可以更改圆弧的角度,也可以更改直线、开放折线、椭圆弧和开放样条的长度。结果类似于延伸和修剪对象。
您可以通过编辑对象的属性来扩展或修剪对象。例如,要延长一条线,只需更改 or 属性的坐标即可。若要更改圆弧的角度,请更改圆弧的 or 属性。更改对象的一个或多个属性后,可能需要重新生成显示才能在绘图窗口中查看更改。StartPointEndPointStartAngleEndAngle
加长一条线
此示例创建一条线,然后更改该线的终结点,从而生成更长的线。
VB.NET
<CommandMethod("ExtendObject")> _
Public Sub ExtendObject()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a line that starts at (4,4,0) and ends at (7,7,0)
        Using acLine As Line = New Line(New Point3d(4, 4, 0), _
                                        New Point3d(7, 7, 0))
            acBlkTblRec.AppendEntity(acLine)
            acTrans.AddNewlyCreatedDBObject(acLine, True)
            '' Update the display and diaplay a message box
            acDoc.Editor.Regen()
            Application.ShowAlertDialog("Before extend")
            '' Double the length of the line
            acLine.EndPoint = acLine.EndPoint + acLine.Delta
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("ExtendObject")]
public static void ExtendObject()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a line that starts at (4,4,0) and ends at (7,7,0)
        using (Line acLine = new Line(new Point3d(4, 4, 0),
                                new Point3d(7, 7, 0)))
            acBlkTblRec.AppendEntity(acLine);
            acTrans.AddNewlyCreatedDBObject(acLine, true);
            // Update the display and diaplay a message box
            acDoc.Editor.Regen();
            Application.ShowAlertDialog("Before extend");
            // Double the length of the line
            acLine.EndPoint = acLine.EndPoint + acLine.Delta;
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub ExtendObject()
    ' Define and create the line
    Dim lineObj As AcadLine
    Dim endPoint(0 To 2)  As Double
    startPoint(0) = 4
    startPoint(1) = 4
    startPoint(2) = 0
    endPoint(0) = 7
    endPoint(1) = 7
    endPoint(2) = 0
    Set lineObj = ThisDrawing.ModelSpace. _
                                AddLine(startPoint, endPoint)
    lineObj.Update
    endPoint(0) = lineObj.endPoint(0) + lineObj.Delta(0)
    endPoint(1) = lineObj.endPoint(1) + lineObj.Delta(1)
    endPoint(2) = lineObj.endPoint(2) + lineObj.Delta(2)
    lineObj.endPoint = endPoint
    lineObj.Update
GMT+8, 2026-10-27 04:50
