创建矩形数组 (.NET)
本示例创建一个圆,然后执行该圆的矩形数组,从而创建五行五列圆。 VB.NETImports Autodesk.AutoCAD.Runtime
Public Shared Function PolarPoints(ByVal pPt As Point2d, _
ByVal dAng As Double, _
ByVal dDist As Double)
Return New Point2d(pPt.X + dDist * Math.Cos(dAng), _
pPt.Y + dDist * Math.Sin(dAng))
End Function
<CommandMethod("RectangularArrayObject")> _
Public Sub RectangularArrayObject()
'' Start a transaction
'' Open the Block table record for read
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle that is at 2,2 with a radius of 0.5
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 0.5
acBlkTblRec.AppendEntity(acCirc)
acTrans.AddNewlyCreatedDBObject(acCirc, True)
'' Create a rectangular array with 5 rows and 5 columns
Dim nRows As Integer = 5
Dim nColumns As Integer = 5
'' Set the row and column offsets along with the base array angle
Dim dRowOffset As Double = 1
Dim dColumnOffset As Double = 1
Dim dArrayAng As Double = 0
'' Get the angle from X for the current UCS
Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d
Dim acVec2dAng As Vector2d = New Vector2d(curUCS.Xaxis.X, _
curUCS.Xaxis.Y)
'' If the UCS is rotated, adjust the array angle accordingly
dArrayAng = dArrayAng + acVec2dAng.Angle
'' Use the upper-left corner of the objects extents for the array base point
Dim acExts As Extents3d = acCirc.Bounds.GetValueOrDefault()
Dim acPt2dArrayBase As Point2d = New Point2d(acExts.MinPoint.X, _
acExts.MaxPoint.Y)
'' Track the objects created for each column
Dim acDBObjCollCols As DBObjectCollection = New DBObjectCollection()
acDBObjCollCols.Add(acCirc)
'' Create the number of objects for the first column
Dim nColumnsCount As Integer = 1
While (nColumns > nColumnsCount)
Dim acEntClone As Entity = acCirc.Clone()
acDBObjCollCols.Add(acEntClone)
'' Caclucate the new point for the copied object (move)
Dim acPt2dTo As Point2d = PolarPoints(acPt2dArrayBase, _
dArrayAng, _
dColumnOffset * nColumnsCount)
Dim acVec2d As Vector2d = acPt2dArrayBase.GetVectorTo(acPt2dTo)
Dim acVec3d As Vector3d = New Vector3d(acVec2d.X, acVec2d.Y, 0)
acEntClone.TransformBy(Matrix3d.Displacement(acVec3d))
acBlkTblRec.AppendEntity(acEntClone)
acTrans.AddNewlyCreatedDBObject(acEntClone, True)
nColumnsCount = nColumnsCount + 1
End While
'' Set a value in radians for 90 degrees
Dim dAng As Double = Math.PI / 2
'' Track the objects created for each row and column
Dim acDBObjCollLvls As DBObjectCollection = New DBObjectCollection()
For Each acObj As DBObject In acDBObjCollCols
acDBObjCollLvls.Add(acObj)
Next
'' Create the number of objects for each row
For Each acEnt As Entity In acDBObjCollCols
Dim nRowsCount As Integer = 1
While (nRows > nRowsCount)
Dim acEntClone As Entity = acEnt.Clone()
acDBObjCollLvls.Add(acEntClone)
dArrayAng + dAng, _
dRowOffset * nRowsCount)
nRowsCount = nRowsCount + 1
End While
Next
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
static Point2d PolarPoints(Point2d pPt, double dAng, double dDist)
return new Point2d(pPt.X + dDist * Math.Cos(dAng),
pPt.Y + dDist * Math.Sin(dAng));
[CommandMethod("RectangularArrayObject")]
public static void RectangularArrayObject()
// Start a transaction
// Open the Block table record for read
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle that is at 2,2 with a radius of 0.5
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 0.5;
acBlkTblRec.AppendEntity(acCirc);
acTrans.AddNewlyCreatedDBObject(acCirc, true);
// Create a rectangular array with 5 rows and 5 columns
int nRows = 5;
int nColumns = 5;
// Set the row and column offsets along with the base array angle
double dRowOffset = 1;
double dColumnOffset = 1;
double dArrayAng = 0;
// Get the angle from X for the current UCS
Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
Vector2d acVec2dAng = new Vector2d(curUCS.Xaxis.X,
curUCS.Xaxis.Y);
// If the UCS is rotated, adjust the array angle accordingly
dArrayAng = dArrayAng + acVec2dAng.Angle;
// Use the upper-left corner of the objects extents for the array base point
Extents3d acExts = acCirc.Bounds.GetValueOrDefault();
Point2d acPt2dArrayBase = new Point2d(acExts.MinPoint.X,
acExts.MaxPoint.Y);
// Track the objects created for each column
DBObjectCollection acDBObjCollCols = new DBObjectCollection();
acDBObjCollCols.Add(acCirc);
// Create the number of objects for the first column
int nColumnsCount = 1;
while (nColumns > nColumnsCount)
Entity acEntClone = acCirc.Clone() as Entity;
acDBObjCollCols.Add(acEntClone);
// Caclucate the new point for the copied object (move)
Point2d acPt2dTo = PolarPoints(acPt2dArrayBase,
dArrayAng,
dColumnOffset * nColumnsCount);
Vector2d acVec2d = acPt2dArrayBase.GetVectorTo(acPt2dTo);
Vector3d acVec3d = new Vector3d(acVec2d.X, acVec2d.Y, 0);
acEntClone.TransformBy(Matrix3d.Displacement(acVec3d));
acBlkTblRec.AppendEntity(acEntClone);
acTrans.AddNewlyCreatedDBObject(acEntClone, true);
nColumnsCount = nColumnsCount + 1;
// Set a value in radians for 90 degrees
double dAng = Math.PI / 2;
// Track the objects created for each row and column
DBObjectCollection acDBObjCollLvls = new DBObjectCollection();
foreach (DBObject acObj in acDBObjCollCols)
acDBObjCollLvls.Add(acObj);
// Create the number of objects for each row
foreach (Entity acEnt in acDBObjCollCols)
int nRowsCount = 1;
while (nRows > nRowsCount)
Entity acEntClone = acEnt.Clone() as Entity;
acDBObjCollLvls.Add(acEntClone);
dArrayAng + dAng,
dRowOffset * nRowsCount);
nRowsCount = nRowsCount + 1;
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub RectangularArrayObject()
' Create the circle
Dim circleObj As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2#: center(1) = 2#: center(2) = 0#
radius = 0.5
Set circleObj = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
ZoomAll
' Define the rectangular array
Dim numberOfRows As Long
Dim numberOfColumns As Long
Dim numberOfLevels As Long
Dim distanceBwtnRows As Double
Dim distanceBwtnColumns As Double
Dim distanceBwtnLevels As Double
numberOfRows = 5
numberOfColumns = 5
numberOfLevels = 0
distanceBwtnRows = 1
distanceBwtnColumns = 1
distanceBwtnLevels = 0
' Create the array of objects
Dim retObj As Variant
retObj = circleObj.ArrayRectangular _
(numberOfRows, numberOfColumns, numberOfLevels, _
distanceBwtnRows, distanceBwtnColumns, distanceBwtnLevels)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-27 01:22
